Adapter Portable DAC ES9281C OFC Copper / Silver MQA 32bit 384kHz DSD128
Hidizs offers with its S3 Pro a powerful portable DAC to accompany you in all your travels. Ideal to work in association with a smartphone without a 3.5mm headphone output, it is equipped with an ESS ES9281C Pro digital/analog conversion chip ensuring an accurate reproduction and supporting high sampling rates as well as MQA files.
Although it is compact, the S3 Pro is no less powerful and versatile. Ideal companion for listening on your smartphone, it will allow you to enjoy your music in high quality, supporting PCM streams up to 32bit 38kHz, DSD Native up to DSD128 and even MQA. In addition, its careful design allows it to reveal a rich and musical sound reproduction.
Based on an ESS ES9281C Pro DAC chip, the S3 Pro benefits from low power consumption, extremely low distortion and support for high sample rates and MQA.
MQA (Master Quality Authenticated) technology is supported by the Hidizs S3 Pro, allowing these files to be played back to enjoy sound quality as close as possible to the original recordings.
An audio playback / streaming service supporting MQA must be installed on the source device (HiBy Music, TIDAL) to take advantage of MQA.
The S3 Pro offers a choice of 3 predefined equalizers, to suit your listening and your headphones. The first one favors clear highs for a precise and detailed reproduction. The second develops balanced and neutral timbres. Finally, the last one emphasizes deep and powerful bass.
The S3 Pro is equipped with a central LED, illuminating to indicate the sample rate of the file being played:
With its 20mm diameter, the S3 Pro is smaller than a one euro coin. It fits everywhere, in a pocket or in a bag, to accompany you without cluttering you.
The Hidizs S3 Pro, designed for mobility, is compatible with the controls and microphones built into the cables of some headphones and earphones. This means that all controls are within easy reach, without having to take your phone out of your pocket.
No detail is left to chance for this S3 Pro. Thus, the cable making the link between the DAC itself and the USB-C connector benefits from a magnificent design, totally optimized for an optimal signal transmission. This one is composed of 4 braided conductors: two in pure silver and two in OFC copper!
" The S3 Pro provides good objective performance. Combined with that you get a cute package at average price for premium dongles. "
Product type | Portable DAC |
DAC Chip | ESS ES9281C Pro |
Input | 1x Male USB-C |
Output | 1x Female Jack 3.5mm |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD128 MQA 8x |
THD+N | 0.0008% |
SNR | 117dB |
Channels separation | 70dB |
Frequency response | 20Hz - 40kHz (±0.1dB) |
Output power | 2x 55mW @ 32Ω |
Compatible OS | Windows 10, Mac OS, iPad OS, Android, iOS (With Lightning OTG cable, not included) |
Dimensions | 20 x 10 x 90mm |
Weight | 6g |
Color | Black |
Input | USB |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9281C Pro |
Max sampling rate | 384kHz |
Max sampling rate | MQA |
Max sampling rate | DSD128 |
Color | Black |
Networking | No |
Remote Control | No |
