Balanced DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Black
The iBasso DC04Pro portable DAC and headphone amplifier combines carefully selected components with advanced technologies to provide excellent performance and a sound reproduction that is as rich and precise as it is transparent. The DC04Pro can be used both at home and on the move to enjoy high quality music listening at all times.
The digital to analog conversion part of the DC04Pro is entrusted to a pair of Cirrus Logic CS4313 DACs and has their Master HiFi™ technology on board, offering incredible performance and very high sound quality.
As the quality of the power supply has a direct impact on the sound reproduction, the DC04Pro is equipped with a DC-DC converter and a high speed, low noise LDO to provide a clean and stable electrical signal to all the circuits.
The DC04Pro also embeds two TR6863 OPAs, forming a fully balanced amplifier with very low distortion. This one is capable of delivering 280W of power under 32Ω.
iBasso uses its own FPGA algorithm for the first time in a portable device in dongle format. In combination with a KDS femtosecond oscillator, the jitter is perfectly controlled and the sound reproduction benefits from a greatly reduced distortion level.
The iBasso UAC Android mobile application has been completely revised and improved for the release of the DC04Pro. It allows, via a graphical interface, to easily control the various settings of the device: volume, digital filters, gain, output mode, balance or even power saving mode.
The iBasso DC04Pro provides two outputs. The first one is in Jack 3.5mm format for the use of single-ended headphones, the second one in Jack 4.4mm format, allowing the connection of a balanced listening device.
The iBasso DC04Pro features a linear LED indicator, changing color depending on the status of the device and the audio format being played: red if it is in standby, blue for DSD format and green for PCM streams.
Product type | DAC and portable headphone amplifier |
Inputs | 1* USB-C |
Outputs | 1* Single-ended Jack 3.5mm 1* Balanced Jack 4.4mm |
DAC chips | 2* Cirrus Logic CS43131 |
Supported sampling rates | PCM up to 32bit 384kHz Native DSD up to DSD256 |
THD+N | Balanced: 0.00013% @ 300Ω Single-ended: 0.00018% @ 300Ω |
Output level | Balanced: 3Vrms @ 32Ω / 4Vrms @ 300Ω Single-ended: 2Vrms @ 32Ω / 2Vrms @ 300Ω |
SNR | Balanced: 131dBA Single-ended: 127dBA |
Dynamic range | Balanced: 128dBA Single-ended: 126dBA |
Frequency response | Balanced: 20Hz~40kHz ±0.5dB Single-ended: 20Hz~40kHz ±0.5dB |
Output impedance | Balanced: < 0.4Ω Single-ended: < 0.2Ω |
Dimensions | 59*23.4*12.1mm |
Weight | 21g |
Color | Black |
Package | 1* iBasso DC04 Pro 1* USB-C cable 1* USB-C to USB-A cable |
Input | USB |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
DAC / ADC Chip | CS43131 |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Black |
Class | Class D / T |
Networking | No |
Remote Control | No |
