KHADAS TEA Portable DAC Headphone Amplifier Grey
The Khadas Tea is an ultra-compact, high-performance portable DAC headphone amplifier. Featuring an ES9281AC Pro DAC chip and a QCC5125 Bluetooth receiver chip, it is capable of supporting high-resolution PCM 32bit 384kHz, DSD256, Apple Lossless (ALAC) and MQA rendering via its USB-C input, as well as Bluetooth codecs such as SBC, AAC, aptX, aptX LL, aptX HD and LDAC.
Reference : 18786
139,00 €tax incl.
115,83 € tax excl.
Last items in stock !
Shipping date: 05-08-2025.
KHADAS TEA Portable DAC Headphone Amplifier ES9281AC Pro 32bit 384kHz DSD256 MQA Grey
KHADAS TEA picture
The Khadas Tea is an ultra-compact, high-performance portable DAC headphone amplifier. Featuring an ES9281AC Pro DAC chip and a QCC5125 Bluetooth receiver chip, it is capable of supporting high-resolution PCM 32bit 384kHz, DSD256, Apple Lossless (ALAC) and MQA rendering via its USB-C input, as well as Bluetooth codecs such as SBC, AAC, aptX, aptX LL, aptX HD and LDAC. The output power of the Khadas Tea also makes it compatible with the vast majority of headphones on the market, whether they have an impedance of 8 ohms or 300 ohms. One of the strong points of the Khadas Tea is also its ultra-slim form factor, making it easy to carry around, as it will fit comfortably in your pocket.
Khadas Tea: DAC ES9281AC Pro
This portable DAC headphone amplifier is equipped with an ESS Technology ES9281AC Pro DAC chip offering excellent performance with an SNR of 116dB and a dynamic range of 115dB. This chip enables it to support high-resolution PCM 32bit 384kHz, DSD256, Apple Lossless (ALAC) and MQA renditions as well as using specialised applications such as Foobar2000, Tidal and Roon Audio.
Photo de la puce DAC ES9281AC PRO
Bluetooth
Khadas Tea: Bluetooth QCC5125
A Qualcomm QCC5125 Bluetooth receiver chip enables the Khadas Tea to support Bluetooth SBC, AAC, aptX, aptX LL, aptX HD and LDAC codecs. Thanks to aptX Low Latency, you can use the Khadas Tea to play games or watch films without the risk of audio-video lag.
Khadas Tea: plug and play headphone compatibility
The Khadas Tea's 3.5mm jack output adapts to any headphone with an impedance between 8 ohm and 300 ohm, all in plug and play. In other words, the Khadas Tea automatically adapts its output power to suit your headphones, with no need for you to adjust it manually.
Mise en situation de l'utilisation du KHADAS TEA
Assistants vocaux KHADAS TEA
Khadas Tea: voice assistant compatibility
Press the Khadas Tea power button for 2 second to wake up your voice assistant, such as Siri, without taking your mobile out of your pocket. What's more, two built-in microphones mean you can answer your incoming calls directly.
Khadas Tea: Dedicated application
The Khadas app, accessible for free via your smartphone, lets you control the Khadas Tea and adjust various parameters such as gain level, EQ and filters.
Photo de l'application KHADAS AUDIO APP
Khadas Tea: an ultra-slim form factor
The Khadas Tea fits easily into your pocket thanks to its thickness of just 6.25mm and its weight of 73.5g. In addition, integrated magnets allow you to attach the khadas one to your Apple mobile phone, with the magnets arranged to match the Apple Magsafe power supply on iPhones 12/13.
Un facteur de forme Ultra-Slim
Photo de la batterie du KHADAS TEA
Khadas Tea: a high-performance battery
The Khadas Tea's built-in battery has a capacity of 1160mAh, giving it a battery life of up to 8 hours. So you can enjoy your music in high resolution all day long.
Product typePortable DAC headphone amplifier
DAC chipES9281AC Pro
Bluetooth chipQCC5125
Amplification chipRT6863D
Inputs1x USB-C input
Bluetooth
Outputs1x 3.5mm jack headphone output
Supported sample rates32bit 384kHz PCM, DSD256 and MQA rendering
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
THD+N0.000355 (-109dB) @ 1kHz, 300Ω
DNR115dB
Frequency response20Hz-20kHz (0.05dB)
Noise floor< 3.2uVrms
Max. output power20.8mW (@300Ω)
41.7mW (@ 150Ω)
165mW (@ 32Ω)
130mW (@16Ω)
System compatibilityAndroid (OTG support)
IpadOS
macOS
Windows 7 / 8 / 10 / 11 (with ASIO USB driver)
Linux
Power supply5V DC via USB-C
Battery life1160mAh (8h)
Dimensions95.5 x 63.8 x 6.25mm
Weight73.5g
ColorGrey
Package1x Khadas Tea portable DAC headphone amplifier
1x USB-C to USB-C cable
1x Lightning to USB-C cable
OutputJack 3.5mm
DAC / ADC ChipES9281C Pro
Max sampling rateDSD256
Max sampling rate384kHz
Max sampling rateMQA
ColorGray
ClassN/A
The Khadas Tea is an ultra-compact, high-performance portable DAC headphone...
