QUESTYLE M12I Portable DAC Headphone Amplifier
-57%
The Questyle M12i is a compact, high-performance portable DAC/headphone amplifier. It incorporates high-end components such as an ES9281AC USB DAC chip with integrated headphone amplifier. This DAC chip enables the M12i to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512 for quality sound reproduction.
Reduced price!
Reference : 19561
Limited special offer
159,00 €tax incl.
-57%
69,00 €tax incl.
57,50 € tax excl.
Questyle M12i Portable DAC Headphone Amplifier ES9281AC 32Bit 768kHz DSD512
QUESTYLE M12i picture
The Questyle M12i is a compact, high-performance portable DAC/headphone amplifier. It incorporates high-end components such as an ES9281AC USB DAC chip with integrated headphone amplifier. This DAC chip enables the M12i to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512 for quality sound reproduction. The integrated class G headphone amplifier delivers line-level output power of up to 2Vrms. As a result, the M12i is capable of driving a wide range of headphones and IEMs available on the market. Its compact form factor and transparent face make it both aesthetically pleasing and easy to use. Coupled with a smartphone, tablet or computer, this little DAC headphone amplifier proves an ideal ally for enjoying your music library or streaming services.
The Lightning cable is not supplied, but is available as an accessory.
QUESTYLE M12i compatibility
Questyle M12i: DAC ES9281AC
The ES9281AC DAC chip is a DAC chip with extended functionality since it also integrates a class G headphone amplifier, jack detector and ADC function. It benefits from QUAD DAC™ HyperStream® II architecture, enabling the M12i to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. The G-class amplifier supports up to 2Vrms output for considerable power levels.
Photo du QUESTYLE M12i
Questyle M12i: considerable output power
The Questyle M12i is able to drive a large number of headphones and IEMs thanks to its substantial output power:
  • 19mW (RL=16Ω)
  • 21mW (RL=32Ω)
  • 12.26mW (RL=300Ω)
The M12i will adapt according to load impedance. Indeed, with an impedance of less than 70Ω, the M12i will automatically switch to low gain while with an impedance of more than 70Ω, the M12i will automatically switch to high gain and with an impedance of 600Ω and more, the M12i will automatically switch to a line level output at 2Vrms.
Questyle M12i: MFI certification and high compatibility
The M12i benefits from MFi certification, guaranteeing full compatibility with IOS devices. It is also optimized for Android version 5.1 and higher, driverless Windows 10 (version 18.3 and higher) and MAC OS environments.
Questyle M12i overview
QUESTYLE M12i overview
1CNC-machined aluminum body
2Sampling rate indication LED (1 LED = sampling rate below 48kHz (PCM) / 2LEDs = sampling rate above 48kHz (PCM or DSD))
3SiP current-mode amplifier module
4TOREX power management module
53.5mm stereo jack output (CTIA compatible)
6USB-C input
7Gain level indicator LED (1 LED = low gain | 2LEDs = high gain)
8ES9281AC DAC chip
9Impedance detector
Product typeDAC / Headphone amplifier
DAC chipES9281AC
InputUSB-C
Output3.5mm stereo jack (TRRS - CTIA compatible for microphones)
Supported sample rates32bit 768kHz and DSD512
Output power19mW (RL=16Ω)
21mW (RL=32Ω)
12.26mW (RL=300Ω)
2Vrms (RL=600Ω)
Frequency response±0.1dB(20Hz - 20kHz)
±2dB(20Hz - 80kHz)
THD+N0.0003%
Dimensions57 x 20 x 9mm
Package1x Questyle M12i
1x USB-C to USB-C cable
1x USB-A to USB-C cable
Mesure du QUESTILE M12i
OutputJack 3.5mm
DAC / ADC ChipES9281AC
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
QUESTYLE M12I Portable DAC Headphone Amplifier ES9281AC 32Bit 768kHz DSD512
The Questyle M12i is a compact, high-performance portable DAC/headphone amplifier. It incorporates high-end components such as an ES9281AC USB DAC...
