With the UA6, Shanling offers a balanced portable DAC that lets you enjoy a high-resolution stream in all circumstances at a contained price. The UA6 uses four Cirrus Logic CS43131 DAC chips to support PCM up to 32bit 768kHz and native DSD up to DSD512. The UA6 offers two headphone outputs, one balanced and one single-ended, for respective output powers of 360mW and 110mW at 32Ω.
The Shanling UA6 portable DAC has 3 buttons for adjusting the volume and play/pause of your audio tracks. Its aluminium body houses a 1.3-inch colour screen that lets you navigate the settings menu and display information about the track currently playing.
The heart of the UA6 is based on 4 Cirrus Logic CS43131 DAC chips, enabling it to support PCM up to 32bit 768kHz and native DSD up to DSD512, while maintaining an incredibly low harmonic distortion level of 0.00025%.
The UA6 offers two headphone outputs: a balanced 4.4mm jack output offering 360mW output power at 32Ω and a single-ended 3.5mm jack output offering 110mW output power at 32Ω that can also be used as a coaxial SPDIF output.
The UA6 features a 220 mAh battery combined with an all-new hybrid system that allows the DAC to adjust the energy drawn from the smartphone in real time, ensuring highly efficient operation and stable audio performance. Furthermore, the UA6 features a battery buffer system so that it is compatible with phones with limited USB output power, such as iPhone and Samsung devices.
To ensure the most crystal-clear sound reproduction possible, the UA6 is fitted with a low voltage drop regulator, giving an exceptional signal-to-noise ratio of 132dB.
To ensure broad compatibility, including with games consoles, the UA6 offers the option of activating a UAC 1.0 mode, so you can enjoy it in every possible situation.
To control the UA6's many options, such as gain level, digital filters and channel balance, you can download the Eddict Player application available on Android. Note that the application is also available on iOS, although Apple's limitations prevent any modification of the DAC's parameters.
| Specifications | |
| Product type | Portable DAC |
| DAC chip | 4x CS43131 |
| Input | 1x USB-C |
| Output | 1x Single-ended jack 3.5mm 1x Balanced jack 4.4mm |
| Supported sample rates | PCM up to 32bit 768kHz DSD natif up to DSD512 |
| Battery capacity | 220mAh |
| Digital filters | 5 options |
| Sampling rate LED indicator | Blue : 32kHz / 44.1kHz / 48kHz Green : 64kHz / 88.2kHz / 96kHz Yellow : 128kHz / 176.4kHz / 192kHz Pink : 352.8kHz / 384kHz / 705.6kHz White : DSD64 / DSD128 / DSD256 / DSD512 |
| 3.5MM JACK OUTPUT MEASUREMENT | |
| Low gain | 1V @ 32Ω (31mW @ 32Ω) |
| High gain | 1.9V @ 32Ω (112mW @ 32Ω) |
| Frequency response | 20Hz-40kHz (-0.5dB) |
| Total harmonic distortion more noise (THD+N) | 0.00025% |
| Dynamic range | 128dB |
| Channel separation | 68dB |
| Signal-to-noise ratio (SNR) | 127dB |
| Output impedance | 0.6Ω |
| 4.4MM JACK OUTPUT MEASUREMENT | |
| Low gain | 1.8V @ 32Ω (101mW @ 32Ω) |
| High gain | 3.4V @ 32Ω (361mW @ 32Ω) |
| Total harmonic distortion more noise (THD+N) | 0.0006% |
| Dynamic range | 133dB |
| Channel separation | 129dB |
| Signal-to-noise ratio (SNR) | 132dB |
| Output impedance | 1.2Ω |
| General | |
| Dimensions | 68 x33.5 x 13.6mm |
| Weight | 35g |
| Color | Black |
| Package | 1x Shanling UA6 1x USB-C to USB-C cable 1x USB-A to USB-C adapter |
| Input | USB |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| DAC / ADC Chip | CS43131 |
| Color | Black |
| Networking | No |
| Remote Control | No |
