TANCHJIM SPACE Portable USB DAC 2x CS43131 Balanced 32bit 384kHz DSD256
The TANCHJIM SPACE portable DAC is a compact and efficient portable DAC. It adopts a high-end finish with a CNC machined aluminum alloy frame and a transparent window revealing the internal structure. The aluminum chassis provides resistance to potential external interference. In addition, it has a button to control the volume.
4.7 / 5
Reference : 17668
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 13-05-2025.
TANCHJIM SPACE
TANCHJIM SPACE DAC USB Portable 2xCS43131 32bit 384kHz DSD256 Argent
The Tanchjim Space is a compact and efficient portable DAC. It adopts a high-end finish with a CNC machined aluminum alloy frame and a transparent window revealing the internal structure. The aluminum chassis provides resistance to potential external interference. In addition, it has a button to control the volume.
TANCHJIM SPACE
TANCHJIM SPACE LIGHT
DAC chip
2* CS43131
1* CS43131
Ouput
1* Single-ended Jack 3.5mm
1* Balanced Jack 4.4mm
Volume control
Yes
No
Dynamic range
132dB
126dB
2x CS43131 DAC
Space's digital-to-analog conversion stage uses not one but two Cirrus Logic CS43131 DAC chips. High-performance, these support high-resolution audio streams up to PCM 32bit 384kHz and DSD256, while offering precise and neutral reproduction. The two chips allow a balanced structure of the internal circuit.
Two outputs for maximum compatibility
The Tanchjim Space has a single-ended Jack 3.5mm output as well as a balanced Jack 4.4mm output. This allows it to be compatible with most of your headphones for daily use.
Interchangeable OTG cable
The Space is equipped with a USB-C socket allowing you to change the cable in order to be compatible with a large number of devices such as your smartphone or your computer.
The supplied cable is shielded and adopts two strands of monocrystalline copper and silver plated.
Good performance
This portable DAC offers a dynamic range of 132dB on its balanced output. The THD+N is less than 0.00017%. It therefore features low distortion with low noise and will let you enjoy a rich and clean listening experience.
Tanchjim Space review by AudioScienceReview (Amir)
" Performance is just stunning. Use of dual DACs and excellent engineering has translated into a top of the line desktop class DAC but in a container that is the size of an America quarter! Functionality is excellent with nice tactile volume controls. And the thing manages to look attractive to boot! Other than finding out why it won't produce 4 volts, it is the most perfect headphone adapter I have tested! "
Test du Tanchjim Space par AudioScienceReview (Amir)
Product typePortable DAC
Input1* USB-C
Output1* Single-ended Jack 3.5mm headphone output
1* Balanced Jack 4.4mm headphone output
DAC Chip2* CS43131
Output power230mW @ 32 Ohm
54mW @ 300 Ohm
Output voltageBalanced output: 4Vrms (High) / 2Vrms (Low)
Single-ended output: 2Vrms (High) / 1Vrms (Low)
Frequency response6Hz - 85kHz
THD+NBalanced: 0.00017%
Single-ended: 0.00019%
Background noiseBalanced: 1.3µV
Single-ended: 1µV
Dynamic range132dB
127dB (AES17 20Khz, A-Weighted)
Supported samples ratesPCM up to 32bit 384kHz
DSD up to DSD256
Dimensions410*210*120mm
Weight14.8g
ColorSilver
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
6 reviews
Mmmmwouaiiiiiiiii
Définitivement, il est meilleur que le DAC de mon téléphone, de ma tablette ou encore du PC.
Mais de 1, la différence entre le light et le space, ... il n'y en a pas au niveau du son.
De 2, je ne suis pas transcendé par des bass plus basses et des aigues plus aigres ou même des voix plus voisses (je déconnes c'est pour la blague) malgré les stats améliorés par rapport au lite.
L'avantage est sur les boutons, et il ne faut pas se mentir sur le style aussi.
Je ne dis surtout pas que le son est mauvais mais il sera au niveau CD niveau retranscription sonore pour les i audiophiles et niveau salsa/dance des canards pour ceux qui cherchent le fun dans la musique coté mélomane.
Donc il y a mieux mais plus cher, sur cette échelle de prix, le Lite et le space dominent. A savoir si cela est suffisant pour votre écoute. Perso j'ai testé avec 3 casques :
Sennheiser HD 400S (bof),
Sennheiser - HD 569 (Brrrrrr bof),
Beyerdynamic DT 770 PRO (ah! Manque un truc...),
Focal Elegia (un peu gluant mais appetissant),
Focal Celestee (ca va ya les infos sur le DAC, c'est les casques qui sont nuls).
This review has been posted for TANCHJIM SPACE Portable USB DAC 2x CS43131 Balanced 32bit 384kHz DSD256
Excellent produit
Bon produit, prix très correct.
Utilisé avec un casque Sennheiser HD660S. Ca fonctionne tres bien en symétrique et en asymétrique.
Sur smartphone j'ai eu besoin de mettre un player spécifique car le driver system d'Android ne fonctionne pas mais bon j'utilise e/os sur un Fairphone. De toute facon je pense que l'utilisation d'un player dédié est conseillé. Sinon de pas aussi hésiter à installer l'application de Tanchjim pour vérifier les settings du DAC et/ou les changer.
Small but great
A very handy volume control, top sound, no interference and beautiful to look at.
bien lire la notice
super dac ampli casque une fois le gain réglé sur haut en appuyant sur les deux boutons du volume en même temps ey un rodage de 8 heures, à noter que je n'ai eu aucune interférences contrairement à la concurrence fosi fiio ou shanling, je l'ai couplé en bi perfect avec des final audio e5000 un régale avec de bon fichiers bien sûr la puissance et largement suffisante pour moi
Petit bijoux de puissance et de qualité sonore
Alors la je reste scotcher devant ce petit appareil audio. Puissant robuste, qualité sonore au rendez vous, rien à redire, excellent.
The TANCHJIM SPACE portable DAC is a compact and efficient portable DAC. It adopts a high-end finish with a CNC machined aluminum alloy frame and a...
