This 24-position digital incremental encoder features a D Shaft for mounting a knob. It can be used as a volume control, or to adjust the level of audio, video or computer devices with a suitable programming chip (not supplied). The encoder also acts as a push-button, so it can also be used as a source selector, for example.
| Specifications | |
| Type of product | Mechanical Encoder |
| Pulses per revolution | 24PPR |
| Number of notches | 24 |
| Orientation | Vertical |
| Shaft length | 12mm |
| Shaft diameter | Ø6mm |
| Operating temperature | -10°C / +70°C |
| Supply Voltage Max | 5V DC |
| Termination | Solder Pin |
| Push Switch | With push-button switch |
| Encoder output | Quadrature |
| Encoder technology | Mechanical |
| Encoder type | Incremental |
| Encoder mounting | Through Hole |
| Number of channels | 2 |
| Shaft Type | D Type Flatted End |
