I'm having a hard time finding the words to describe how good these amps sound. They just do everything right. Period. ( powering martin logan electrostatic speakers)
By buying this product you get 64 loyalty points
This product has been replaced by the new version, the AUDIOPHONICS AP300-M400ET Power Amplifier Class D Mono Purifi.
Power amplifier PURIFI 1ET400A 1x400W 4 Ohm
We are proud to present AUDIOPHONICS MPA-M400ET, a class D mono power amplifier based a PURIFI 1ET400A module. This ready-to-use version is designed for audiophiles needing a foolproof amplification solution, with a considerable power reserve as well as impeccable linearity. The PURIFI module is indeed among the most rigorous Class D amplification solutions on the market, with simply exceptional measured performance.
This device offers high level sound reproduction which will be suitable to drive demanding speakers, to sonorize large listening rooms or for studio applications requiring a considerable headroom without compromising on the precision and richness of the audio message.
All of the components are integrated in a sober and robust 100% Aluminum housing with openings and heatsinks to help heat dissipation. Its design also allows it to block signal interference.
SMPS600N400 switching power supply is a model with very high maximum output power of 600 Watts. It has been specifically designed and developed by Hypex to provide 2 x 65V voltage required for operation of the most demanding amplifier modules.
This low noise high quality Power supply, meets every energy needs of the amplification modules. Furthermore, the amplifier modules themselves have an excellent ability to reject power supply noise. The MPA-M400ET has lowest sensitivity to the variations of your electrical network liable to cause parasitic noise.
The amplifier module Purifi is driven by a controller module of our design.
A Texas Instrument LM4562 OPA per channel is used, these are very low distortion AOPs offering the greatest transparency with a very low THD. They are mounted on socket allowing their replacement if necessary
To suit all uses we opted for 3 gain settings, adjustable by jumper on the interface card :
Designed for easy integration, the MPA-M400ET has a balanced mono (XLR) and unbalanced mono (RCA) input. A bipolar selector make it easy to change the input source and even allow independent channel control when paired to another MPA.
Output side, BP-209 terminal blocks Ø5.5mm acrylic / 24K gold insulated terminal blocks ensure an excellent connection with the speakers and supporting bare cables (5.4mm), banana plugs and spades.
The MPA-M400 ET has a 5-12V trigger input integrated in a low consumption circuit (5ma). Your amplifier blocks can thus easily reach your High Fidelity installations with remote power on control.
Type | Power Amplifier |
Output power (max) | 8Ω @1%THD : 227W 4Ω @1%THD : 425W 2Ω @1%THD : 450W |
THD+N | PO=1W, f=1kHz 0.0007 % PO=10W, f=1kHz 0.00026 % PO=100W, f=1kHz 0.00015 % PO=1W, f=20-20kHz 0.0007 % PO=10W, f=20-20kHz 0.00029 % PO=100W, f=20-20kHz 0.00017 % |
IMD (CCIF) | PO=1W, f=18kHz+19kHz 0.00025 % PO=10W, f=18kHz+19kHz 0.00022 % PO=100W, f=18kHz+19kHz 0.00027 % |
IMD (DIM) | PO=1W, DIM30 0.002 % PO=10W, DIM30 0.002 % PO=100W, DIM30 0.002 % |
Idle noise | A-weighted 11.5 µV |
Dynamic range | A-weighted 4Ω 131 dB |
SNR | A-weighted 4Ω 131 dB |
Frequency response | RL= 8Ω, f= 20-20kHz ±0.01 dB RL= 4Ω, f= 20-20kHz ±0.01 dB RL= 2Ω, f= 20-20kHz ±0.01 dB |
Output impedance | 1kHz, Iout=1A 0.07 mΩ 20-20kHz, Iout=1A <0.65 mΩ |
Input impedance | RCA: 47kΩ / XLR: 94kΩ Bypass: 2.2kΩ / 4.4 kΩ |
Power supply | AC 110 / 230V (Automatic detection of the input voltage) |
Dimensions | 141 x 357 x 65mm |
Weight | 1.8 kg |
Power cable | Included |
Input | XLR |
Input | RCA |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Hypex Ncore |
Power (W) | 400.0 |
Average votes 5.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Yngve I.
Joris V.
Piotr K.
Philippe S.
Constantin N.
