This adapter allows you to connect devices with a C19 connector with a power cord with a C14 connector 10A much more common.
The connector C19 is a specific format that can be found on some Stereo devices, as is the case for example of the amplifier tubes Audio Research VS115.
Each pole is indicated by a marking.
| Characteristics | |
| Type | C14 Adapter - C19 |
| Current rating | 10A |
| Dimensions | 67 x 29 x 21mm |
| Section wire | 46g |
| Connectic | Male & Female |
| Connector | IEC C14 |
| Connector | IEC C19 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
