HAT flat mounting for 3.7V cell / Battery Management System Raspberry Pi 2 / 3 / 3B+
HAT RPI Inverter / BMS & Support for 3.7V battery with ON / OFF button, overload / discharge protection.
Reference : 13537
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 16-12-2025.
HAT Inverter Battery Management System for Raspberry Pi
Battery Management System 3.7V / Protection against overcharge & overdischarge / Charge on micro-USB
BMS battery management board for Raspberry PI SBC
This inverter is designed to be mounted on a Raspberry Pi or any other SBC sharing its GPIO pinout. The HAT is equiped with a two-way GPIO port that allows chain mounting other modules and HATs above and below.
Its form-factor and spacers are scaled on the RPI (works with all models including 2-3-3B +). It can be easily integrated to different types of installation with minimal need for additionnal space.
The circuit handles fast charge / discharge of the batteries (2A input and output) during operation for a comfortable and safe use. Once mounted, it is possible to add a software indicator as to virtually display the remaining battery. Moreover it is possible to program an automatic shut-down when the battery is too low.
Please note, only the inverter board is included to this item: the Rasbperry Pi nor the battery are provided.
Battery Raspberry Pi with overload and discharge safety
Ease of integration
HAT inverter has a top slot for flat lithium-ion battery 3.7V.
The batteries can be stacked to increase battery duration; however, it requires the use of cells less than 9mm thick.
It is not mandatory to use a flat battery format. The interconnection between the inverter and the battery is made thanks to a PH 2.0mm port that can connect to any lithium battery pack or even a holder with removable batteries, as long as the card receives 3.7V and the batteries can handle 2A.
ON / OFF
The HAT inverter board is equipped with an ON / OFF button located on the short edge of the circuit. Once mounted on the RPI, the button side falls close to the Micro-SD card slot
Still on this same side, the PH 2xpin connector connects the inverter to the battery. This proximity allows a lasting connection with extremely short cable length.
Three LEDs indicate that the charging cycle is still active and may indicate the remaining battery level as well.
External battery manager inverter for raspberry pi with on / off button
Passthrough
The charging circuit is independent of the RPI power circuit. That is to say that it is possible to charge the battery while the RPI is running.
The board has all the essential protection against battery excessive discharge and overload.
Safety Notes
Caution this HAT BMS UPS can not operate while the HDMI port is active. The module is not intended for this use.
The Micro-USB port on the inverter is designed to charge the battery only. Do not connect it with your Raspberry Pi own micro-USB input.
The charge / discharge manager and the protections can handle any types of Lithium Battery as long as it delivers 3.7V with a discharge current of at least 2A.
If you want to add batteries with one another (with a battery cradle or in a custom assembly) make sure that the cells are connected in parallel (and especially not in serie).
Dimensions and distances
line dimensions drilling hat UPS RPI
This module is not compatible with the Raspberry Pi 4
Typeinverter
Battery Support
charge / discharge Manager
Dimensions65 x 55mm
Charging Portmicro USB
Port batteryPH 2-pin 2mm Male
cable provided
Connection to SBCGPIO
ON / OFF buttonYes
ProtectionsExcessive load
Excessive discharge
Battery compatibilityLithium - 3.7V
Maximum intensityLoad: 2A
Déchage 2A
Package Contents
Inverter Map HATx1
PH cable 2mm / 65mm 2 Poles with female housing to bare sonx1
InputType I Main Plug
InputAES/EBU
InputI2S via HDMI
InputS/PDIF
InputI2S
InputIEC C14
InputJack DC 5.5/2.1mm
InputI2S via RJ45
InputIEC C8
InputSATA
InputPCI
InputJack 3.5mm
InputLightning
InputType C Main Plug
InputJack DC 5.5/2.5mm
InputRJ45
InputOptical Fiber
InputXLR
InputSD Card
InputType A Main Plug
InputGPIO
InputPhono
InputPH 2.0mm
InputSpeaker terminals
InputPCI Express
InputBNC
InputIEC C16
InputI2C
InputI2S
InputJack DC 3.4/1.4mm
InputWiFi
InputType E / F Main Plug
InputOptical Mini-Toslink
InputMicro SD
InputJack 2.5mm
InputJack 6.35mm
InputACSS
InputType G Main Plug
InputScrew terminals
InputHDMI
InputXH 2.54mm
InputDIN 5
OutputGPIO
