IAN CANADA UCPI 2025 Universal Ultracapacitor Power Supply Board for Raspberry Pi
Ian Canada's UcPi 2025 is a high performance and affordable 5V supercapacitor power supply module designed specifically for audio applications using a Raspberry Pi to get the best possible sound quality from a clean and stable power signal. The module uses spring contacts to power the Raspberry Pi via its GPIO connector, making installation quick and easy.
Reference : 16717
99,90 €tax incl.
83,25 € tax excl.
Shipping date: 02-09-2025.
Ian Canada UcPi 2025 Universal Ultracapacitor Power Supply Board for Raspberry Pi
Key features :
  • 5V power supply using two 100F 2.7V supercapacitors. ESR less than 10mΩ.
  • Gold-plated spring contacts to power the Raspberry Pi from its GPIO, without the need for additional connections.
  • Input voltage: 5V 2.5A via USB-C.
  • Integrated ON/OFF button. The switch can also be removed from the module.
  • Ultra-low ESR MOSFETs controlled by optical isolators to eliminate leakage current and ripple.
  • On-board balancing circuit for supercapacitor protection.
UcPi 2025 New Features
  • Optimized for the new RaspberryPi 5 and all other RaspberryPi generations.
  • Hybrid Ultracapacitor and Polymer capacitor power supply cleaning/filtering technology.
  • Upgraded to higher performance 120F/3V ultracapacitors for 20% greater capacity than the previous version.
  • 20% lower ESR for higher current applications.
  • Higher current output terminal connector.
  • Input power supply wires other than USB-C can be soldered directly to the PCB.
The Ian Canada UcPi 2025 module is delivered alone. The Raspberry Pi is sold separately.
Ian Canada UcPi module d'alimentation à supercondensateurs pour Raspberry Pi
Product typePower supply module for Raspberry Pi
Output voltage5V
Input voltage5V 2.5A via USB-C
Dimensions127 x 92mm
Mounting holes spacing113 x 78mm
OutputGPIO
7 reviews
Tout n'est pas parfait
Je pensais à tort que les supercondensateurs fonctionnaient en quelque sorte comme de petites batteries et stockaient de l'électricité pendant une certaine durée. Ce n'est malheureusement pas le cas. Sur mon Pi5, ils se chargent très rapidement, il n'est pas nécessaire d'attendre les 20 à 30 minutes indiquées dans le mode d'emploi pour que la LED 3 s'allume. Quelques secondes suffisent pour le processus de charge. Est-ce normal ?
Après tout, la carte permet d'alimenter le Pi5 avec une batterie externe normale.
Traduit avec DeepL.com (version gratuite)
This review has been posted for IAN CANADA UCPI 2025 Universal Ultracapacitor Power Supply Board for Raspberry Pi
pure battery voltage
using supercapacitor and ultra low mosfet
using it for my singxer su2
gives 5% better sound
and better most high-end power supply
Good value
I did a review of Ian Canada TransportPi and this was added to it. It subtly improved my overall perception of sound quality of that board. Not sure how it actually measures for noise, which is something I am interested in. But I do think the ability to run a device purely off an ultracapacitor to decouple from a direct mains supply is worthwhile.
Powersupply
Incredible good
Perfect for a PI streamer
No question, perfect for a Pi streamer with a good PSU
Ian Canada's UcPi 2025 is a high performance and affordable 5V supercapacitor power supply module designed specifically for audio applications...
