FOSI AUDIO P4 Preamplifier
The Fosi Audio P4 preamplifier is a compact and versatile solution. With its three stereo RCA inputs, volume control with motorised potentiometer, tone control, gain selection and neat design, it offers a high-quality sound experience.
Reference : 20518
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 10-04-2026.
Fosi Audio P4 Preamplifier
Fosi Audio P4: Front view
Fosi Audio P4: Key features
Fosi Audio P4: Motorised potentiometer
Fosi Audio P4: Motorised volume potentiometer
The Fosi Audio P4 features a motorised volume control. As well as providing smooth volume control, this solution also reduces noise and distortion, delivering a better-defined soundstage.
Fosi Audio P4: Three gain level
The Fosi Audio P4 features a gain selector, allowing you to choose from three levels of gain to suit the output levels of different sources.
Fosi Audio P4: Gain selector
Fosi Audio P4: Tone control
Two buttons on the front of the Fosi Audio P4 allow you to adjust the bass and treble levels over a range of ±12dB. This makes it possible to adjust the output of the device to suit your system, your music and your listening style.
Fosi Audio P4: Tone control bypass
If you're not interested in the tone control offered by the Fosi Audio P4, it can be completely disabled using the bypass switch on the back of the unit. So you can enjoy the purest listening experience of the P4.
Fosi Audio P4: Tone control bypass switch
Fosi Audio P4: Pre-out
The Fosi Audio P4 features a pre-out on a 3.5mm jack, allowing you to expand your system, in particular by adding an active subwoofer.
Fosi Audio P4: Aluminium alloy chassis
The Fosi Audio P4 is housed in a compact, precision CNC-machined aluminium alloy enclosure. As well as giving the device a modern look, this limits the impact of electromagnetic interference on the signal.
Fosi Audio P4: Aluminum alloy case
Overview of the Fosi Audio P4
Fosi Audio P4 : Schéma de présentation
1ON-OFF / Input selection button
2Bass control
3Treble control
4Input indicator
5Volume control
6IR receiver
7Tone control bypass
8RCA inputs
9RCA output
10Jack 3.5mm pre-out
11Jack DC 12V power input
12Gain switch
Fosi Audio P4 remote control overview
Fosi Audio P4 : Schéma télécommande
1ON-OFF button
2Volume +
3Input button
4Mute
5Volume -
6P4 mode activation button
Buttons with no indication are not assigned.
Fosi Audio P4: Measurement and performance
Test du FOSI AUDIO P4 par Audio Science Review
"The Fosi P4 surprises with incredibly low cost while providing features such as motorized volume control and excellent performance. It simply has no weak point, other than absence of trigger. I am happy to recommend the Fosi P4 to many of you who need to switch between multiple unbalanced/RCA sources."
Logo Audio Science Review
Product typePreamplifier
ChannelsStereo (2.0)
Inputs3x Stereo RCA
Outputs1x Stereo RCA
1x Jack 3.5mm pre-out
SNR≥ 110dB
Dynamic range≥ 110dB
THD+N≤ 0.003%
Crosstalk≥ 103dB
Noise floor≤ 9µV
Tone control (bass / treble)±12dB
Frequency response20Hz - 20kHz (±0.1dB)
Supply voltage12VDC 1.5A
Weight470g
Dimensions114 x 162 x 43mm
Package1x Fosi Audio P4
1x Remote control
1x Power supply
OutputJack 3.5mm
Channel2 (Stereo)
ClassN/A
Remote ControlYes
5 reviews
Very good little preamp. Excellent sound.
This review has been posted for FOSI AUDIO P4 Preamplifier
Petit mais ...
très bon préamplificateur, simple " transparent ". Rapport qualité prix imbattable. A voir si le potard motorisé tiens le coup dans le temps .
Excellent petit préampli
3 entrées qui me suffisent largement , mon lecteur CD ma platine vinyle et Fip radio via mon ordi . utilisation d'une grande simplicité grâce notamment a sa télécommande agréable a manipuler .Et surtout pour 99 euros c'est presque un petit miracle .
Excellent preamplifier
incredible value for the money investment. I was searching for a neutral preamplifier and reading the ASR review got me ordering it. Have been into vintage equipment and also big expensive brands. Getting retired and having time enough to spend with my system opened my eyes for simple is beautiful and sounds excellent.
petit mais costaud
je regrette juste le peu de place qu'il y a entre les connecteur rca, sinon tout va bien , mon vieil arcam dont la partie preampli etait out le remercie
The Fosi Audio P4 preamplifier is a compact and versatile solution. With its three stereo RCA inputs, volume control with motorised potentiometer,...
