MUSICIAN MONOCEROS Preamplifier Balanced Class A Black
The Musician Monoceros is a beautiful, high-end balanced preamplifier with a high performance Class A architecture and a completely discrete line input stage. Its volume control uses relay-controlled R2R resistors for constant output impedance and exceptional sound quality.
4.8 / 5
By buying this product you get 134 loyalty points
Reference : 15225
1 349,00 €tax incl.
1 124,17 € tax excl.
Musician Monoceros
Preamplifier Balancer Class A Black
Musician Monoceros Préamplificateur Symétrique Class A Noir
Class A balanced preamplifier
The Musician Monoceros uses a 60 step volume control, based on the use of a microprocessor and a relay control. The precision resistors used allow a perfect balance between the channels and ensure a THD+N of only 0.0003%.
Discrete power supply stage
The Musician Monoceros' discrete power supply stage features a 60W toroidal copper coil transformer. This carefully designed power supply ensures low noise and deep bass, while providing a rich, accurate sound with a wide soundstage.
Non-destructive volume control
The sound quality of a conventional potentiometer can vary with the volume level, due to a non-constant impedance. Here, the device uses a high-end, non-destructive volume control and correction algorithm.
DC coupling
The signal path takes advantage of DC coupling, without the use of coupling capacitors that can affect the sound quality. This design allows for a very low DC output voltage so that the signal loop can reach an ideal state.
Simple but complete connectivity
The Monoceros reveals a simple but complete connectivity, to adapt to most audio systems. There are two balanced XLR inputs and one unbalanced RCA input. For the outputs, the device also offers balanced stereo XLR and unbalanced stereo RCA.
Remote control
The Musician Monoceros comes with a CNC machined aluminum remote control, allowing you to control the unit remotely. All the functions of the device are thus accessible, directly from your sofa.
Product typePreamplifier
ClassClass A
Inputs2x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo XLR
Frequency response10Hz - 100kHz (-1dB)
THD+N0.0003%
SNR120dB
Dyanmic range> 120dB
Crosstalk-110dB
Input resistance20kΩ
Output impedance200Ω
Dimensions330 x 320 x 60mm
Net weight7kg
Supply voltage110/240VAC, 50/60Hz (Power cable NOT included)
ConsumptionStandby : 1W
Operating : 20W
Housing materialCNC machined aluminum
Package1x Musician Monoceros
1x Remote control (CR2032 battery NOT included)
InputXLR
ClassClass A / AB
Remote ControlYes
6 reviews
Fantastic!
I ordered this preAmp in for replacing my old pass clone. The warmth, but also velocity and transients are great. Furthermore there is NO noisefloor. It is black and quiet and so it shows perfect dynamics. The build quality is also great with a cnc metal housing. Great product and great service from audiophonics, as always!
This review has been posted for MUSICIAN MONOCEROS Preamplifier Balanced Class A Black
précis et chaleureux
Formidable preampli. Très belle organisation spatiale ,vigueur et impact dans le grave sans la moindre lourdeur.bonne télécommande. Un peu surpris par la progression du volume
A noter:il est preferable de ne pas l éteindrecar le temps de chauffe pour son meilleur fonctionnement est très long.mais typique des preamplis en classe A.
Très bon
Je voulais tester une configuration pre ampli ampli
J'ai vu les bonnes critiques du musician le cote R2R la classe a/ab
J'ai acheté
Je l'utilise avec un ampli élément en vente ici avec la technologie ICE rock
Le couple joue fort bien et on a pas l'impression d'un son class D
Il mérite un bonne ampli de puissance
Excellence Sonore
Préampli MONOCERO Musician
très belle écoute, avec beaucoup de présence, mais aussi de belles basses. Equilibre spectral avéré. Naturel, et précision s'apprécient à chaque audition. Ne cherche pas à en "rajouter"
mais bien à respecter le message musical. Il lui manque juste une deuxième entrée RCA . (2 entrées XLR + 1 seule RCA)
Bon achat.
Very good choise
Beautiful sound with a bit of tube-like warmth, maintaining high resolution, wide stage, space and detail, very good bass. Great synergy with my Purifi Audiophonics HPA-S400ET power amplifier. As usual, service and delivery at the highest level. I highly recommend.
 (3)
The Musician Monoceros is a beautiful, high-end balanced preamplifier with a high performance Class A architecture and a completely discrete line...
