Pack Triangle Vinyl Turntable LUNAR 1 + BOREA BR02 Connect Active Speakers Black
We offer you this pack of products from Triangle, comprising the Lunar 1 turntable and BR02 Connect active speakers. This pack lets you enjoy your vinyl library for the most pleasant listening experience, as well as taking advantage of the BR02 Connect speakers' many additional functions.
By buying this product you get 94 loyalty points
Reference : 19647
948,00 €tax incl.
790,00 € tax excl.
Pack content
Photo of Pack Triangle Platine Vinyle LUNAR 1 + Enceintes Actives BOREA BR02 Connect
TRIANGLE LUNAR 1 : Vinyl Turntable 33/45 Tours Ortofon OM-5E Black
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
View complete product page of Triangle Lunar Turntable Lunar 1 turntable picture
TRIANGLE BR02 Connect : Active Speakers Bluetooth 5.0 aptX HD 2x50W 89dB 51Hz-22kHz Black (Pair)
Triangle Borea BR02 Connect active bookshelf speakers provide a complete, versatile stereo sound system. They incorporate a high-performance amplifier, making it easy to add sound to rooms from 8m² to 20m².
The BR02 Connect has been designed for versatile use, adapting perfectly to today's needs. With this in mind, they feature Bluetooth aptX HD reception for remote broadcasting, a phono input for connecting a turntable, an optical and HDMI (ARC/CEC) input for association with a TV, a USB-B input for use with a computer, and even a subwoofer output offering the possibility of associating a subwoofer (not supplied).
A true integrated HiFi system, the BR02 Connect features a Class D amplifier capable of delivering a comfortable 2x50W RMS power. Each speaker is equipped with an EFS fabric dome tweeter and a 13cm diameter bass-midrange driver. As a result, these compact bookshelf speakers are capable of developing a rich sound image, marked by powerful, controlled bass, smooth midrange and precise treble.
View complete product page of Triangle BR02 Connect BR02 Connect picture
Product typeVinyl turntable + Active speakers
Package content1x Triangle Lunar 1
1x Triangle Borea BR02 Connect speakers pair
Lunar 1 vinyl turntable specifications
Turntable typeManual
Drive systemBy belt
Playback speeds33 and 45 RPM
CartridgeOrtofon OM-5E
Diamond typeElliptical
Tone arm typeStraight
Tone arm materialAluminum
Tone arm length21.5cm
Cartridge output voltage4mV
Fréquency response20hZ-20kHz
Output1x Stereo phono RCA (with ground terminal)
CableRCA phono interconnect cable (HP-OCC and gold-plated connectors)
RCA cable length1.2m
Power supply5V DC
Dimensions420 x 330 x 112mm
Weight3.5kg
Package1x Triangle Lunar 1 turntable
1x Flat belt
1x Dust cover
1x RCA Phono interconnect cable
BR02 Connect speakers specifications
Product typeActive speakers
Speaker typeBass Reflex
Number of drivers2
DriversTweeter Ø25mm
Bass-Medium Ø13cm
Sensitivity89dB/W/m
Amplification typeClass D
Power2x50W RMS
Frequency response51Hz - 22kHz
Min/max impedance3.6Ω / 8Ω
InputsBluetooth 5.0
1x Jack 3.5mm
1x Optical Toslink
1x Coaxial
1x Steroe RCA (line / phono MM)
1x HDMI (ARC/CEC)
Output1x Subwoofer output (RCA)
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Supported audio formatsMP3, WMA, APE, FLAC, WAV, Apple Lossless
Dimensions (L x H x P)176 x 310 x 274mm
Weight (pair)13.4kg
Package2x Borea BR02 Connect
1x Remote control
1x Power cable
1x Speaker cable 3m
We offer you this pack of products from  Triangle, comprising the Lunar 1 turntable and BR02...
