Pack WiiM Ultra Gray + Audiophonics AP300-S250NC + Audiophonics Wire RCA 30cm + Trigger Cable
We offer you a WiiM x Audiophonics product pack comprising the Wiim Ultra Network Player, an AP300-S250NC amplifier, a pair of RCA modulation cables and a trigger cable. This pack will give you a connected system with plenty of power reserve and excellent sound quality.
By buying this product you get 89 loyalty points
Reference : 19806
899,00 €tax incl.
749,17 € tax excl.
Instead of 985,40 €
Pack content
Pack WiiM x Audiophonics WiiM Ultra Gray + Audiophonics AP300-S250NC + Audiophonics Wire RCA 30cm + Trigger Cable
WiiM x Audiophonics pack photo
Wiim Ultra : Streamer DAC ES9038Q2M Bluetooth WiFi 32bit 384kHz
The WiiM Ultra sets a new benchmark in the world of audio streamers, thanks to a design conceived to deliver an unrivalled audio experience. It lets you enjoy your music library and favorite streaming services in a perfectly intuitive way, thanks in particular to a 3.5" color touchscreen and physical navigation button. With its extensive connectivity including WiFi and Bluetooth, you can access your music quickly and easily, whether it's stored on a NAS, computer, smartphone or via a streaming service. What's more, the WiiM Ultra boasts a rich selection of audio inputs and outputs to integrate easily into the vast majority of audio setups.
View complete product page of Wiim Ultra Wiim Ultra
Audiophonics AP300-S250NC : Class D Stereo Power Amplifier Ncore NC252MP 2x250W 4 Ohm
The Audiophonics AP300-S250NC is a stereo amplifier based on an amplification module Hypex Ncore NC252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message. All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
View complete product page of AP300-S250NC Audiophonics AP300-S250NC
Audiophonics Wire RCA : Interconnect Cable Stereo RCA OFC Copper Gold Plated 30cm
The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a Mogami Neglex W2549 modulation cable and Amphenol ACPR male RCA connectors, providing excellent conductivity and durability for efficient audio signal transmission.
View complete product page of Audiophonics Wire RCA Audiophonics Wire RCA
Trigger cable : Male Jack 3.5mm to Male Jack 3.5mm Mono Cable 0.4m
This 3.5mm mono jack cable is ideal for connecting mono audio devices or triggers. It features a 40cm length.
View complete product page of the Trigger cable Câble trigger
Product typeNetwork player + Amplifier + RCA modulation cables + Trigger cable
Package content1x WiiM Ultra
1x Audiophonics AP300-S250NC
1x AUDIOPHONICS WIRE RCA
1x Trigger cable
WiiM Ultra Specification
Product typeAudio streamer
Inputs1x Stereo RCA
1x Phono input (RCA)
1x Optical Toslink
1x HDMI ARC
1x USB-A
1x Ethernet RJ45
Outputs1x Stereo RCA
1x Coaxial
1x Optical Toslink
1x Subwoofer output (RCA)
1x Jack 3.5mm headphone output
ConnectivityWiFi 6E 802.11 g/b/n/ax 2.4GHz, 5GHz, 6GHz
Ethernet 10M/100Mbps
Bluetooth 5.3
DAC chipES9038Q2M
Bluetooth versionBluetooth 5.3 BLE / BT LE Audio
A2DP, AVRCP, HID receiver and transmitter support
Works with WiiM voice control
Supported sampling ratesInput: PCM up to 32bit 384kHz
Output: PCM up to 24bit 192kHz
Supported Bluetooth codecsSBC, AAC
Max output level (line out)2.1Vrms
SNR (line out)121dB(A)
THD+N (line out) (1kHz)0.00018% (-115dqB) from 44.1kHz to 192kHz
FR curve±0.05dB
USB transmission modeAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (driver required)
Mac OSX10.6+
Linux
EQGraphic 10 bands
Parametric 10 bands
Independent for each source
Subwoofer outputBass management
Adjustable latency, phase, level and filter
TriggerOutput (12V)
Touchscreen3.5"
Supply voltage100-240VAC
Dimensions205 x 205 x 73mm
Housing materialAluminum
ColorSpace Gray
Package1x Wiim ULTRA
1x Power cable C7
1x Télécommande
Audiophonics AP300-S250NC Specification
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Input1x Unbalanced Stereo RCA
1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax Power at 1.66V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Dimensions300 x 220 x 65mm
Weight2080g
Package1x Audiophonics AP300-S250NC
1x Power cable
Audiophonics Wire RCA Specification
Product typeStereo RCA cable
ConnectorsMale RCA
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Amphenol ACPR connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialNickel
InsulationPA66
trigger cable Specification
Product typeJack cable
Length40cm (excluding connectors)
Connectors2x 3.5mm male mono jacks
Package1x 3.5mm mono jack cable
Pack WiiM Ultra Streamer Grey + Audiophonics AP300-S250NC amplifier + Audiophonics Wire RCA Cables 30cm + Trigger Cable
We offer you a WiiM x Audiophonics product pack comprising the Wiim Ultra Network Player, an AP300-S250NC amplifier, a pair of RCA modulation...
