Jean-louis L.
Presque le sans faute... mais ça Sonne Superbement !
Bon, je commence par la Mise en Service : après avoir vidé un bel emballage très "sécure" mais sans véritable Doc ~...
Jean Michel P.
Fiches bananes exceptionnelles
Ne vous fiez pas à l'apparence et au poids plume de ces fiches bananes mais question transparence elles sont tout à fait...
Hervé R.
Pas si bien que ça !
La qualité audio est bien au rendez-vous, mais mécaniquement le câble fait des boucles des nœuds et il devient très peu...
Power Supply Module A-19 2x3-20V LT1083 - reviews - There are 6 reviews.
Zdenek B.
Very good power supply. Adjustment is stable. Almost no heat dissipation with the right transformer.
Michel a.
fine power module
the module perfectly meets my expectations, is easy to set up and therefore keeps exactly the value, even under load.
despite the corona problems, I quickly had the power module at home.
perfect!
Michalis B.
Great PSU
It works perfect!
This unit replace an old psu with the classic DC regulators LM317 / LM337.
Somebody here at reviews ask if can works as symmetrical + -v power supply. The answer is absolutely YES!
Works for me exactly as i was need. With AC 10V in every side, i have exactly + - 7.5 V OUTPUT!
The only thing you MUST do is to put a jumper from - to + exactly in the middle of the board (at output side), and grounding this point!
Also, no ripple, and imidiatly you can listen your difference from your old power supply!
Thank you Audiophonics for your products!
 (3)
Patrick d.
Great well build product for the money
Great well build product for the money. As far as I was able to measure ripple free output.
Filippo T.
Good PSU
I checked the PSU at 18V output and results are very good, undetectable ripple and stable voltage.
Yannick M.
bonjour,
je voulais savoir si cette alimentation est bien symétrique , + et - 3 à 20V
merci
This power supply module takes a voltage input of between 5V and 25V AC and outputs a voltage of ±3V to ±20V DC, depending on...
