The 1Mii B08+ is an affordable and powerful amplifier with integrated Bluetooth receiver. Integrating an ATS 2853 chip, it benefits from Bluetooth 5.0 reception with support for AAC and SBCI transmission codecs. Equipped with antennas, it allows long distance transmission, up to 30m without obstacle. A Stereo RCA input is also available.
Its amplification stage allows it to develop a power of 2x50W, ideal for accompanying small passive bookshelf speakers.
On the output connector side, there are of course speaker terminals.
The front of the device has three buttons, allowing you to adjust the volume level, but also to adjust the bass and treble levels.
The amplifier has a TPA3116D chip, allowing an output power of 2x50W, moreover, the ATS2853 Bluetooth chip supports AAC, SBCi codecs.
Tecnical characteristics
| Specifications | |
| Product type | Bluetooth Amplifier |
| Imputs | Bluetooth 5.0 1x RCA stereo |
| Outputs | 1x Speakers terminal |
| Bluetooth version | 5.0 |
| Suported Bluetooth profiles | A2DP AVRCP HFP |
| Suported Bluetooth codecs | ACC SBC |
| Max transmission distance | with out obstacle : 30m |
| Output power | 2x 50W / 4 Ohm |
| Operating temperature range | -10°C / +45°C |
| THD | 0.5% ≤ |
| SNR | ≤ 98db |
| Response frequency | 20Hz - 20kHz |
| General | |
| Supply voltage | DC 12- 24V 4A |
| Dimensions | 136 x 101 x 45mm |
| Weight | 418g |
| Color | Black |
| Package | 1x 1Mii B08+ 1x Power supply 24V 4A |
| Input | RCA |
| Input | Bluetooth |
| Output | Speaker terminal |
| DAC / ADC Chip | NC |
| Max sampling rate | NC |
| Color | Black |
| Channel | 2.1 |
| Class | Class D / T |
| Amplifier chip | N/A |
| Power (W) | 50.0 |
| Remote Control | No |
