Jean-louis L.
Jean Michel P.
Hervé R.
Pas si bien que ça !
Customers reviews - There are 19012 reviews.
Ludovic L.
Utilisés pour doubler les sorties d'un préampli, la finition est excellente et l'objet est très qualitatif, aucune perte du signal.
Ludovic L.
J'ai acheté ce préampli pour installer deux amplis Tripath Trends TA 10.2P en blocs mono chacun amplifiant son enceinte. Je ne voulais pas dépenser une grosse somme mais avoir un contrôle de volume et de tonalité.
C'est plutôt pas mal du tout. Pour le moment j'ai juste essayer avec mon baladeur Hi-Res.
Dominique A.
MATRIX X-SABRE PRO MQA FULL DECODER DAC USB I2S ES9038PRO 32Bit/768kHz DSD1024 Black With this updated version of the X-Sabre Pro, Matrix offers us a 32bit DAC based on an ES9038Pro chip. This new version adds support for Master Quality Authenticated (MQA)...
superbe qualité de fabrication et superbe écoute .
Bonjour , livraison rapide , très content et satisfait de ma commande . Produit sérieux , de qualité , construction haut de gamme . Qualité son sublime . Merci AUDIOPHONICS .
A. D.
Sandro R.
One of the best
It will certainly be the most neutral cable I have ever had.
High quality construction
Nice Price
Helmut H.
TOPPING A50 Headphone Amplifier Balanced Silver The Topping A50 is an efficient and affordable sedentary headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing to enjoy a rich and clear...
I also like that Amp..
.. but I'm only a listener, it is my second Headphone-Amp. For me it sounds nice and can drive a Sennheiser HD650 at +9dB loud enough for my ears.
I can't say anything more than the reviewer before, it's all I perceive myself.
The ordering process from Germany was very agreeable. I had one RMA, but it was a problem with the source I connected, not the Amp itself. The RMA was really painless. The concerns ordering a product outside my country are discarded. Thanks for that nice and gentle process!
Kirsch p.
IFI AUDIO HIP DAC Portable Balanced Headphone DAC Amplifier 32bit 384kHz DSD256 MQA iFi Audio presents the HIP DAC, a DAC combo and nomadic symmetrical headphone amplifier, both compact to accompany you in all your travels or on your desk, but also benefiting...
Avis d'un néophytes ^^
Étant mon premier DAC je ne peut pas vraiment être objectif mais cest que je peux dire c'est que j'ai redécouvert mes morceaux il est précis et l'ouverture de scène qu'il apporte est gigantesque (de mon point de vue de débutant^^) il y à un peut trop de basse a mon gout mais je suis un psychopathe du son neutre donc bon... Rien a redire pour moi à si les leds sont sensé changer de couleur en fonction du type de fichier du coup j'ai essayé un fichier en mQa pour le voir s'illuminer d'un magenta mais la couleur n'a pas changé.
Eemeli V.
Automatic Input Selector 4 Stereo RCA Inputs This module automatically switches between 4 stereo sources. The selection of sources is carried out fully automatically from a signal of at least 0.2V.
Not for HI-FI audio!
If your plan is to connect multiple audio sources to active speakers or ampfilther THIS IS NOT THE RIGHT DEVICE! When input is selected a loud "bang" noice is heard from your speakers. And when there is no output the device continously switches between inputs and same sound will be heard again and again.
Michel B.
Très bien mais pourrait encore mieux faire
Mécaniquement il est très bien et robuste.
Ergonomiquement il est facile à souder avec une pin centrale qui permet d'enfiler le câble central profondément, et un corps facile à souder avec un système de serrage du câble par pincement correct. Sur ce point, le OYADE est plus abouti, mais je ne suis pas certain que ce soit mieux en pratique.
Le diamètre du trou de passage du câble est largement suffisant pour tous les câbles utilisés en DC, même si vous utilisez un 4 conducteurs 24-AWG.
Pas loin du sans faute donc pour la partie mécanique et ergonomique.
Parmi les connecteurs DC disponibles, c'est le seul avec le OYADE à indiquer le métal utilisé: Laiton pour les 2 fabricants, mais le OYADE est 2 fois plus cher...
En terme de rapport Q/P, il me fait l'air bien mieux placé que le OYADE qui propose le même matériau (laiton). Si OYADE proposait du cuivre, l'écart de prix pourrait se comprendre.
Cependant pourquoi ne trouve-t-on aucun connecteur avec contact en vrai cuivre ??
Sans aller jusqu'au UP-OCC, on est légitimement en droit d'espérer un connecteur DC en cuivre !
Les fabricants auraient-ils oublié à quel point la qualité du matériau est essentielle dans un connecteur ?
Robert P.
Nice looking box on a budget
On the plus side the box once assembled looks good for a relatively budget box and is performing the job I required.
On the negative side the small bolts that are used attach the base and the top plate to the side plates are very short and only just catch the nuts they screw into, they are effectively one shot use. If you need to remove the top plate to gain access after assembly the bolts will be scrap and need replacing, fortunately there are some spare bolts in the kit I had.
Another negative is that there is no electrical continuity between the components which if you intend to put mains voltages in the box is potentially dangerous. As I was constructing a power supply one of the main components was a transformer from 240v to 12v so this was an issue for me. To get continuity I had to remove the paint from all the jointing faces in order to get an electrical continuity and enable the box to be earthed, not ideal.
Pierre B.
Etonnant
Pour 45 € vous ne risquez rien saut d'être très agréablement surpris.
Comme constaté sur un avis précédent le gain est faible (28 quand même) mais avec un préampli de qualité , à tube chez moi, le résultat est excellent. Monté en double mono avec des toriques 2 x 30V, les modules d'alimentation 4 x 10.000 µ / 50V; les protections HP 11657 le résultat est bluffant pour du bipolaire.
Bande passante mesurée de 5 HZ à 200 KHz, puissance avant écrêtage 78 V crête à crête pour 2,8 V en entrée ce qui nous fait 95 W efficaces avec une alimentation à +/- 44 V.
Pas un souffle pas une ronflette.
Très bon achat à conseiller.
Photos du montage en du signal carré à 1KHz à disposition.
Pierre B.
Super rapport qualité prix
Rien à dire j'en suis à ma troisième paire, fiable silencieux, bonne réserve de courant même sur un double mono en classe A
Olivier W.
Filtres... Quoi comment pourquoi ?
Ravi d'utiliser ce DAC, mais quelqu'un pourrait-il m'expliquer la signification et l'utilisation des différents filtres présents sur ce DAC ?
En l'absence de notice et d'explications, je suis totalement incapable d'exploiter ces fonctionnalités ajoutées, et cela est bien dommage... Merci pour votre aide à tous !
Voici l'article le plus complet que nous connaissions sur le sujet :
https://www.audiostream.com/content/what-are-digital-filters-and-why-are-they-requried-todays-audio-dacs-resonessence-labs-tech-3
Mikhail I.
Topping DX7 Pro
Great service and fast delivery. Item arrived in perfect condition.
christophe S.
Trés bon rapport prix
Se connecteur et le plus haut de gamme de chez viborg meilleur que la pure cuivre, ou la gold .Elle a une tenue du grave, une aération un timbre plus juste sans coloration ou chaleur superflu pourtant elle n est pas froide ou montante elle sonne juste sans douleur de certaine prise roduim,elle laisse juste couler la musique .( Cable secteur oyade tunami v2 schuko viborg aluminuim roduim et cette iec roduim).Rapport prix de haut niveau.
Clément M.
A-t-on encore besoin de le recommander?...
La référence quasi-absolue dans l'univers du DAC/ampli/preamp.
Reconnue mondialement autant par le milieu professionnel qu'amateur, on sait ce qu'on achète: C'est Made In Germany, c'est garanti 5 ans, ça mesure super bien et c'est utilisé tant en studio, qu'en conception d'ampli... et finalement dans les salons pour une simple utilisation Hi-Fi.
- Matthias Carstens de RME, le concepteur, est ultra actif sur les forums et montre un niveau d’ingénierie et de connaissance technique sans faille.
- Le firmware est régulièrement mis à jour avec des ajouts bienvenus.
- La partie préampli est vraiment un sans faute. En Auto Ref Level, on a juste accès à l'ajustement de volume le plus clean et précis que je connaisse pour driver un ampli de puissance.
- Les parties ampli casque et IEM ne sont pas en reste avec une transparence sans faille (et "suffisamment" de puissance pour 90% des casques)
- Les possibilités de DSP sont exceptionnelles, même si personnellement, je l'utilise en réglages "stock".
- Inutile de vous prendre la tête sur la "sonorité": C'est d'une neutralité et d'une transparence parfaite. Point barre.
L'avantage, c'est que quand on en possède un, inutile d'aller voir ailleurs, la concurrence est littéralement larguée. Oubliez les marques pseudo-audiophiles et leur discours marketing douteux. Oubliez l'idée qu'à deux ou trois fois plus cher, vous pourriez avoir mieux. Ici, on joue à un autre niveau... celui des pros.
Michel B.
Des connecteurs excellents à tous points de vue !
Des connecteurs XLR il en existe des dizaines, mais lorsque l'on cherche des connecteurs de qualité, cela devient beaucoup plus difficile.
Concernant le matériau utilisé pour les contacts, ces YARBO sont les seuls où le mot "cuivre" est prononcé, au travers de l'appellation "alliage de cuivre". C'est imprécis mais c'est mieux que pas d'indication du tout, ou une indication "laiton".
Certes cela ne vaut pas le cuivre UP-OCC des NEOTECH haut de gamme, mais ces derniers valent 3 fois plus cher.
Entre le prix de ces YARBO et celui des NEOTECH, il y a de la place pour des connecteurs en cuivre de haute qualité, ce qu'aucun constructeur ne propose (en tout cas pas trouvé).
Pour le reste, ces YARBO affichent un sans faute: la construction mécanique est exceptionnelle, d'une solidité à toute épreuve !
Même la partie foncée (par où rentre le câble) est en métal et pas en plastique.
La vis qui sert à verrouiller le connecteur une fois monté est en métal et le filetage dans lequel elle se visse est lui aussi en métal !
Enfin, la pièce qui tient les 3 contacts est indestructible: contrairement à ce que l'on peut lire sur d'autres connecteurs, vous pouvez souder et chauffer, elle ne fondra pas d'un yota.
Voici des connecteurs XLR mécaniquement exemplaires, et avec des contacts comportant du cuivre (ce qui est devenu rarissime).
Il reste à espérer que YARBO ou d'autres sortiront un connecteur en vrai cuivre, à un tarif à mi-chemin entre celui et le NEOTECH UP-OCC.
zeev m.
n'hésitez pas... c'est probablement le meilleur
La qualité FDA (full digital) est impressionante.
Malgré certaines mesures de la distortion (audiosciencereview...) l'AD18 reproduit les sons de manière exceptionnellement naturelle et on entend les plus aigus des sons aigus (guitars, pianos percussions...).
pas de distortion audible, cela s'explique par:
1. le volume d'écoute habituelle ne produit pas trop de distortion
2. notre oreille n'entend pas des différences si minimes.
3. j'ai plein a'autres hypothèses...
MAIS ATTENTION : sur le line-in l'ad18 n'est pas très bon mais pour moi aucun intérêt, l'AD 18 n'est pas fait pour analog et on écoute actuellement surtout sur bluetooth.
Pour ceux qui hésitent avec le SA300, l'AD18 est nettement meilleur (j'ai comparé, mais pas d'avantage sur line-in)
Nicolas C.
Petit boitier
Je l'utilise pour rendre une enceinte Muse connecté au réseau, afin de mettre des histoire à ma fille. Ca fonctionne parfaitement. Le boitier est visible sur BubbleUpnp , spotify (et d'autres que je n'ai pas testé).
Attention au premier paramétrage. bien lire la notice, pour l'associer au réseau WIFI il faut appuyer sur le bouton WPS, ceci afin que le logiciel Audicast le reconnaisse et que l'on puisse le paramétrer.
Ce M5 fonctionne comme borne WIFI avec son propre réseau, ce qui peut être pratique si vous perdez le réseau principale. Ce n'est pas du gros débit, environ 2-3 mbits.
Nicolas C.
Cable Male USB-C 3.1 to Female Jack stereo 3.5mm 10cm This cable consists of a USB-C male connector (3.1) and a Jack 3.5 female plug. It will therefore allow you to connect a 3.5mm jack device to a device that does not have this...
A recommander
Câble tel que je l'attendais, fonctionnel, prix correct. Ne pas s'attendre à un DAC. Je l'utilise pour connecter mon téléphone sur des enceintes (kit 2.1 pc) que j'ai installé dans mon garage. Parfait.
Nicolas C.
Jean-Francois C.
Super!
Achetées pour remettre en état mon AUDIOMAT "Prélude" de 1994... Incroyable, ce sont les mêmes que celles d'origine! Une fois encore merci à Audiophonics pour la sélection rigoureuse de leurs produits (en l'occurence MONACOR)...
Pas très pratique à utiliser
Ma note ne concerne pas la qualité du son puisque celui-ci est équivalent à un câble coaxial Wireworld Ultraviolet en ma possession.
Ce câble-ci est beaucoup trop rigide et donc difficile à utiliser sans causer une pression sur les connecteurs.
Connecteurs qui ne sont pas de bonnes qualités à mon avis. Dans l'ensemble, je ne recommande pas ce câble.
Un câble coaxial blindé et par définition plus rigide que tout autre conducteur, dans votre cas je m’inquiéterais plutôt du manque de rigidité du votre.
Concernant les connecteurs ce sont l'une des rares référence de vrai connecteurs 75 ohm sur le marché.
Ils ont éprouvés depuis des dizaines d'années dans le milieu audio et vidéo sans le moindre soucis.
Sami M.
Very Good
Very good amplifier. Im using this with hifiman edition xx
Sami M.
Best dac that i have ever own
this dac is good and have features that competitors can only imagine at this price point
Istvan J.
Un bon rapport qualité / prix
À ma grande joie, j'ai reçu la livraison du Topping D50S la semaine dernière. Je l'ai inséré dans mon système audio. Le résultat confirme pleinement les opinions lues jusqu'à présent, il a une excellente voix, et même dans les graves, les médiums et les aigus. La dynamique du médium est étonnamment bonne, les chanteurs se font entendre devant les haut-parleurs. Mon système appartient à la catégorie moyenne, j'ai deux amplificateurs, un Cambridge Audio - Azur 640R, et un tubulaire (2X15 W, fabriqé par moi). Les haut-parleurs sont Tannoy (Dual Concentric) 635 Black Ash D50. J'ai beaucoup d'enregistrements DSD, ils sonnent trés bien, j'utilise le lecteur audio Foobar2000. Fait intéressant, l'entrée coaxiale ne reconnaît pas les signaux de mes deux excellents anciens lecteurs CD Philips (CD608 et CD614), mais je ne suis pas déçu car le lecteur DVD Pioneer DV-2850 et le lecteur CD Cambridge Audio 640C se comprennent parfaitement.
Xavier B.
Retour après quelques mois d'utilisation
Preamp très efficace pour le prix, le schéma électronique est simple et efficace, pour à peine quelques dizaines d'euros j'ai recapé l'ensemble avec de bon composants, la métamorphose est impressionnante on gagne de manière très importante en précision, donc au final très satisfait surtout pour les possibilités de tweking de l'objet sans arrière pensées.
CLAUDE S.
Il fait le boulot !
Matériel : PC ASUS K750J ; casques Sennheiser HD-25, Audiotechnica ATH-A1000Z, Fostex 7BB, Beyerdynamic DT-770 250 ohms. Musiques : principalement, jazz et classique.
Le Fiio K5 PRO a été rodé une semaine (allumé jour et nuit ; je n'ouvre pas un débat, je le fais à chaque fois). L’appareil est simple d'emploi. Il est solide. A l’écoute, il se révèle un parfait auxiliaire du son. Tout y est : soundstage, détails, basses, médiums, aigus non agressifs. Bon rendu des voix. Naturellement, moyennant un portefeuille plus garni, on peut sans nul doute trouver mieux. Mais il fait le boulot et dispose d'une bonne réserve de puissance. Le reste est affaire d’affinités. Ainsi, je dispose également d'un ampli-dac Fiio K10 dont la puce PCM5102 donne peut-être un son plus rond, plus chaleureux que la puce AKM AK4493. Mais là, c'est comparer un Bourgogne à un Bordeaux : une question de goût. En achetant le K5 PRO, le but était de pouvoir driver en toute quiétude un futur casque comme le Fostex T50rp MKIII. On verra ça. L'aventure ne fait que commencer. NB : merci à Audiophonics qui a livré sans problème le boîtier après un long temps d'attente pour les raisons que l'on connaît et indépendantes de sa volonté et qui m'a rassuré quand le temps me semblait long.
Didier G.
Mundorf 50+50uf
Produit finalëment reçu avec pas mal de retard lié au covid 19,
Mais trés satisfait
zeev m.
comparé à AD18
J'ai hésité pour le nombre de stars...
il n'est pas si mauvais mais comparé à AD18 ..... on comprend pourquoi AD18 est si récompensé...
J'ai attendu deux mois (corona) mais était impatient de recevoir cet ampli... justement pour comparer à mon AD18, et surtout puisque les mesures de la distorsion paraissent exceptionnels.
Mais l'AD18 gagne en marchant
la raison est probablement la qualité FDA (donc full digital) de l'AD18.
MAIS ATTENTION : Comparaison faite uniquement sur Bluetooth, sur le line-in l'ad18 n'est pas bon donc rien à comparer là (et c'est probablement là où le SA300 est meilleure, mais pour moi aucun intérêt à comparer cela, l'AD 18 n'est pas fait pour analog cela et on écoute actuellement tout par bluetooth).
Malgré les critiques des chiffres (audiosciencereview...) l'AD18 reproduit les sons de manière exceptionnellement naturelle et on entend les plus aigus des sons aigus (guitars, pianos percussions...). Ce n'est pas le cas avec le SA300, dont la sonorité est "plus douce" (mais pour mois moins "réaliste").
pas des différences audible concernant la distortion, cela s'explique par:
1. le volume d'écoute habituelle ne produit pas des large différences
3. plein a'autres hypothèses...
Donc la sonorité de SA300 est probablement plus " traditionnelle " mais cela signifie plus étouffée et plus loin des vrais sons des instruments/chant (j'ai quelques instruments de musique à la maison, ça se sent tout de suite)
Bluetooth également moins réactif pour SA300
J'ai fait des tests aveugles avec plusieurs membres de ma famille qui étaient tous d'accord avec moi...
Les haut parleurs était Davis colonnes ( les plus simples... sont excellents)
Andre P.
Tres bon cable
Pour en finir avec l'idiophilie consistant à payer ses câbles audio une fortune !
Celui là est très bon, et lorsque l'oscillo numérique est incapable d’afficher une différence entre ce câble et un autre vendu à 500€ le mètre, triplement blindé, cri-oxygéné et doublement spiralé dans l'espace intersidéral, alors personne ne me fera croire que la différence s'entend ...
Ça s'appelle l'effet placébo...
Investissez plutôt dans un DSP capable d’effectuer de la correction de pièce, et là vous allez gommer des trous et des bosses de +- 10 dB
Andre P.
excellent !
Tout est prêt, monté, la carte SD avec la distrib dessus ...
En fait, il n'y a plus qu'à brancher !
Je l'utilise dans ma chambre en wifi, la sortie coax va sur un FDA SMSL Q5, relié à des clones de LS3-5.
Mes fichiers audio sont sur un NAS (qu'il reconnait du premier coup), et j'utilise Spotify (grâce aux Plug-In de Volumio).
L'ensemble est géré à distance par n'importe quel smartphone ou tablette.
Pas un plantage depuis son installation (qui d'ailleurs s'est déroulée sans aucun problème).
Au vu de l'encombrement ridicule et le prix extrêmement modéré du boitier, je ne vois pas comment il serait possible d'avoir mieux comme serveur audio.
L'ensemble (Allo Digione Player + FDA + Clone Rogers LS3-5) est à la fois extrêmement performant, bon marché et prend peu de place
Les seuls point critiquables sont :
- le Rasp 4 a tendance à chauffer (mais ça reste raisonnable)
- il n'y a pas d'interrupteur pour mettre le boitier hors tension.
- quelques soucis avec le transporteur (livraison GLS), mais Audiophonics est au courant et fait le nécessaire
Emmanuel R.
OPA1611 AOP Simple DIP8 (Unité)
oublié au 1er envoi, renvoyé gratuitement immédiatement. service impeccable!
Frank B.
Ecellent, mais...!
Excellent, mais...!
Tout d'abord & je n'y suis pas habitué, un problème, l'un des canaux donne des grésillements désagréables...!
Ensuite lors de l'écoute manque de basses profondes...!
Toutefois, généreusement compensé par une clarté & transparence sonore proche d'un ampli classe A.
Avec un tarif abordable bien haut-delà de toute concurrence...!
Beaucoup vont être surpris pour l'écoute que j'ai faite sur des enceintes "Malone PW 1522" très surprenantes en qualité et pourtant avec les modèles Smsl Q5 Pro (Vidéos*, clé USB*) & FX Audio D502 le basses sont beaucoup plus profondes.
Connecté en USB* sur PC avec l'USB Micro Wireworld Starlight 7
Vidéos* : https://youtu.be/wd8X0BbhrvY - https://youtu.be/izSFd8ujBOc
Dès son retour, je l'essaye sur mes JBL Control avec mon sub Triangle, le résultat sera probablement meilleur, je vous tiens au courant...!
François G.
Préamplificateur passif
Remplace avantageusement la partie préamplificateur de mon intégré Yamaha AX-570 qui a des problèmes de contacts sur le sélecteur d'entrée.
Parfait équilibre entre les voies et me sert pour le rodage, la mise au point et le contrôle de mes enceintes.
Rui B.
My excellent Office Amplifier!!
First a word to Audiophonics: excellent communication and service until now.
Regarding SMSL SA300, the perfect companion to my desktop and my Iphone. Connected to my Asus motherboard by SUB and to my Iphone by Bluetooth delivers quality sound through my KEF Cresta 1 speakers (2x40W @ 8 ohms).
Very happy with it. Regards.
Romain O.
C est mon troisieme
Suite à ma première impression il m avait plu et je l ai mis au bureau. Tellement bien que j en ai acheter un deuxième pour ma mère qui voulais changer sa chaîne des années 70 et avoir un tout en un. Ce troisième est pour ma petite pièce, une chambre d amis, modifiée en bureau de confinement. Avec des monitor audio bronze 2 c est juste parfait. J avais un ampli marantz qui était tout mou et pas de dac. L alientek a tout les avantages, clair précis, dac correct, entree usb au top, télécommande qui prend bien sans devoir être devant l ampli, bref très content.
Erik T.
câble USB
Utilisé entre un PC et un ampli-dac casque FX-AUDIO, il me donne entière satisfaction. Bel emballage et impression de qualité et de solidité. Rien à redire
Erik T.
Utilisé au sortir de mon PC pour lecture de mes fichiers FLAC. Le son est bien sûr incomparable. L'appareil est un vrai plug & play, pas de pilote à installer. On branche le câble USB, on allume, et on écoute ! Un vrai plaisir.
Jean-Michel P.
Belle musicalité
J'ai trouvé la musicalité, neutre, précise et détaillée, exactement ce que je j'aime.
Il y a des "filtres" (6) configurables. Je n'ai entendu aucune differences tant au casque qu'en line out ... !? Leur utilité est un mystère pour moi, je n'utilise pas ce genre de fonction en général, ce n'est donc pas gênant.
L’accès au menu "setting" est plus qu'original !!
La portée (récepteur) de la télécommande est très faible, à peine deux / trois mètres ... ça c'est franchement gênant.
Le support LDAC pour du bluetooth occasionnel est un vrai plus.
En conclusion, je suis très satisfait par l'audio et je reste sincèrement sur ma faim concernant l'experience utilisateur.
Michel S.
Smsl a300
Produit envoyé et reçu en un délai express
On retrouve toute notre discothèque grâce à la musicalité de ce minuscule ampli
Couplé au logiciel AUDIRVANA c’est un régal ...
Alain R.
VIABLUE STONE Braided Sleeve 5-13mm This Viablue Stone braided sleeving accepts cables from 5mm to 13mm in diameter, providing effective protection against mechanical stress. Its fine braiding ensures a totally...
C'est tellement plus joli !
J'utilise toutes les couleurs de ces gaines tressée pour distinguer la nature des câbles Cette couleur, ce sont les câbles optiques. J'ai profite pour mettre les câbles à la bonne longueur.
Résultat : pas de fils qui trainent, tout est identifiable d'un seul coup d'oeil, et c'est tellement plus joli.
Attention de prendre un peut plus long de tresse que la longueur du câble si vous utiliseé cette tresse dans ses diamètres maximum, 1m de plus tous les 4m. C'est logique si le diamètre du câble est important, la gaine ne s'allonge pas beaucoup.
De la gaine tressée, deux bouts de gaines thermorétractable, un décapeur thermique et un peu d'huile de coude.
Excellent produit.
Alain R.
Ce câble relie ma TV à mon lecteur réseau Cambridge.
Le son de la TV sur la Hifi, ça change tout.
J'ai écouté un replay d'un concert de Queen.
Quel bonheur.
Comme à mon habitude, j'ai recouvert ce câble d'une tresse de couleur, celle que j'ai attribuée aux câble optique.
La finition fait pro.
Simon M.
Woofer full range efficaces
Woofer efficace pour mon premier projet. Je n'ai pas fait de crossover pour cet essai mais il mérite une légère atténuation des mediums (dans mon cas) et une augmentation des graves. (baffle step).
Je recommande pour les débutants dans mon cas !
Jean Louis L.
Étonnants !
Je connais le sorbothane depuis très longtemps mais j'avoue que je l'avais un peu oublié. J'ai donc souhaité le redécouvrir sur mon système audio actuel. J 'ai alors passé commande des petits modèles puis, en constatant les résultats obtenus, des gros.
L'effet sur le résultat sonore est très important. Il agit en apportant un naturel confondant sur les voix et tous les timbres médium aigu, en les débarrassant aussi en partie des sifflantes, duretés. Les voix et les timbres sont comme purifiés.
Il agit aussi grandement sur l'effet 3D de l'image sonore, lorsque le système audio est capable de la produire, l'image devient plus profonde et bien plus précise, le tout avec une grande douceur, avec un effet un peu "analogique" .
Mais il y a comme souvent, une contre partie dans le grave et l'extrême grave qui peut devenir moins précis, un peu mou, mais pas toujours ! C'est pourquoi il faut faire de nombreux essais, si possible, sans parti pris au départ et ne pas éviter de les utiliser en mixant cônes/pointes et sorbothane, dans certains cas.
Chez moi, les effets les plus marqués ont eu lieu sous les enceintes et sous mon Elekit TU-8200-DX, qui est un ampli à tubes Single Ended.
Sous les enceintes, le meilleur résultat s'obtient avec 2 grands cône de sorbothane à l'avant et 2 pointes à l'arrière. Pour l'ampli, 3 petits cônes de sorbothane à l'avant (sous les tubes) et 2 cônes en acier à l’arrière (sous les transformateurs de sortie).
La source est un PC Fanless Hystou (Daphile) alimenté par une alimentation stabilisée. J'ai ressortis mes vieux pieds sorbothane d'une autre marque et obtenu de très bons résultats avec 3 sorbothanes uniquement, meilleur ici que 2 + un cône d'acier) et enfin, sous 2 alimentations stabilisées, 2 sotbothanes + 1 cône acier à l'arrière, sous les transformateur secteur.
Dans certains cas, je ne pensais même pas que, par exemple sous le PC sans alimentation, ce serait audible. Grave erreur !
Ce que je peux dire après tout çà, c'est que l'écoute musicale est globalement devenue vraiment meilleure. C'est très étonnant. Mais il faut expérimenter élément par élément, avec patience. Le plus gros gain a été obtenu sous les enceintes. Là, c'est juste énorme. Compte tenu du tarif somme toute modeste, le jeu en vaut largement la chandelle.
Romke A.
True tube sound for a budget price
Excellent product. I like it very much!
Romke A.
High Quality
This phono preamps had me amazed with its high build and sound quality. A true giant killer!
Francis B.
cable utilisé pour les connections entre les différents maillons de mon installation,trés souple, aucun soucis, même sans rodage...(Lol)
Francis B.
imbattable
rapport qualité/prix au top, difficile de faire mieux à ce prix
Martin P.
Perfect box
The box exactly what I needed.
Miltiadis M.
Does what it says on the box
Bought this for the 4.4m balanced connector and it is proven to be a perfect amp for my HD 660s. It is clean, the software works nicely and it has tons of other functionality which is easy to access. I am so happy with my choice.
And a big thanks to this website for the timely delivery and overall good service.
