Manque d 'info
Cette carte doit sûrement valoir le coup. Je ne le sais pas car l'opération de montage de la carte de régulation ainsi que...
Alexandru Ovidiu A.
Magic
Robert C.
En alu et complète avec...
Customers reviews - There are 18992 reviews.
Thomas L.
MINIDSP ADEPT ADC ES9842 Phono Preamplifier with DSP 32bit 192kHz miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to convert analog signals up to...
Using it with Audacity on Linux to transfer from MD. Care to be taken to have project sample rate matching the source, and the system not loaded with other tasks during recording.
Balázs A.
SMSL DO200 PRO Balanced DAC 12x CS43131 XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA/MQA-CD With its DO200 PRO, SMSL breaks new ground and unveils an ultra-high-performance DAC incorporating no less than twelve Cirrus Logic CS43131 DAC chips and an XMOS XU316 USB...
Had a Topping E50 before. This is way more natural sounding, especially in the highs and the mids. Instruments have a realistic timbre. Also has better details and a bigger, more precise soundstage. This is the sound that I wanted. Fantastic DAC!
Gérard M.
DAYTON AUDIO H6512 Wave Guide High Frequencies 16.5 x 30.5cm This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures...
Belle qualité de fabrication avec un insert en laiton pour le filetage. Aspect de surface très agréable et bien fini.
Résultat très probant. Utilisé avec une compression Perless pas d'effet de projection.
Je recommande !
ISOACOUSTICS GAIA III Vibrations Absorbers Isolators 32kg Ø43x39mm (Set x4) IsoAcoustics Gaia III vibration absorbers improve clarity and soundstaging for speakers or subwoofers weighing 32kg or less. They feature a machined stainless steel body with an...
Depuis que je les ai Installés sous un caisson SVS 3000 la fusion du registre grave avec les enceintes est absolument parfaite , sans aucune modification des réglages ,on peux dire qu'ils ont fait disparaitre le caisson !
robert m.
Robert M
I bought this product for the HDMI-ARC connection. With this SMSL box I could not control the volume level with the remote control of my LG TV. When I checked the small user manual, it is indeed stated that it is not possible to control the volume level with this box. It would be nice if Audifonics could give a more complete description of the products they sell.
Daniel M.
TOPPING PRE90 Balanced / Single-Ended Preamplifier NFCA Black Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator...
Pre90
Transparent, dynamic, neutral and easy to listen to with nice strong bass.
One thing that gets in the way is the remote control
Vadim P.
Amazing, unique device
The Topping LA90D amplifier impresses with its excellent sound quality and solid construction. With its powerful features and precise sound reproduction, it is a real asset for every hi-fi enthusiast. What is particularly impressive is the wide sound space and the clear bass reproduction, which takes the listening experience to a new level. It is truly one of the best amplifiers in the world. Recommendation !
DIMOKRITOS D.
Dynamic and very detailed but excessively bright in midrange and highs
It’s a very good option for powered subwoofers, due to its powerful and very well controlled bass, and that is the only reason I gave it three stars. Otherwise, it is a disappointment. Overly bright in the midrange and high frequencies, in an unnatural and unpleasant way, even after long braking-in period. For general use, better go for the Elecaudio CS-361B which remains the emperor of the affordable power cords, being much more balanced, very detailed but in a natural and pleasing way and with phenomenal 3D imaging.
Marcus L.
SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a...
Amazing value
The performance of this DAC is exceptional for the price - amazing value! It beats most of the DAC’s I’ve either owned or auditioned with the previous generation ESS 9038 Pro. Gone is the hardness in the treble and flat soundstage the held many of them back. Superb!
Just a couple of years ago the performance of this SMSL DO100 Pro would have been associated with exclusive DAC’s from established ”audiophile” brands. If you have a high performance system but with an older DAC or CD you owed to yourself to try this SMSL DO100 Pro. ;-)
Konstantinos L.
TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Black The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and Bluetooth receiver. An ideal model for...
Another happy customer
After 30 years of enjoying my father's premium JVC amplifier for my home PC setup, I finally decided it was time for an upgrade. After about a week of researching products, reading reviews, and watching videos, I settled on the MX3s. It offered exactly what I was looking for at a great price.
The package arrived in-time and well-protected in a larger box with extra-thick paper cushioning, and everything was in perfect condition. Once installed, the difference in sound quality was immediately noticeable! I could hear details in my favorite tracks that I had never noticed before—the audio quality truly feels like a whole new level.
I'm using it with my two 4ohm 30Wrms diy monitor speakers in a nearfield setup, and it’s simply perfect. The MX3s not only delivers exceptional performance but also looks sleek and stylish. I couldn’t be more satisfied with this upgrade!
LHY AUDIO LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8 The LPS-A8 linear power supply module, developed by LHY Audio, has been specially designed to improve the power supply stage of EverSolo DMP-A8 network players by replacing the...
Aide au montage kit
Une (voire plusieurs) vidéo de montage existe sur YouTube dont celle-ci : https://youtu.be/EMOg57Ogp2M?si=zPhZQrFUvQWlmw92
Laurent M.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
Excellent et implantation ingénieuse pour projet dual mono
Pratique à installer sur la face arrière de votre boitier DIY
Moi j'utilise une carcasse d'amplificateur en panne ey donc les orifices des anciens borniers HP. Pour utiliser les borniers proposés par Audiophonics il faut les démonter complètement, ils sont faciles à adapter sur les cartes ensuite. Je suis très satisfait de mon acquisition. Laurent
Laurent M.
Excellent registre aigu
Par rapport aux L20V10 d'Audiophonics je trouve un manque de basses flagrants et un medium trop dans la retenue. Par contre l'aigu est fabuleux ! Les essais ont été faits exactement dans la même configuration en interchangeant les modules avec la même alimentation. Peut-être qu'un amateur éclairé pourra m'expliquer comment compenser le manque de basses en modifiant des composants... Laurent
Marko M.
AP310-PREAMP
The preamplifier is simple and practical, the design matches the rest of the AP300... series. I am satisfied with the functionality and connection options, perfect for those who need a bridge between the sound source and the power amplifier...Excellent service, fast processing and delivery of the product. Heartily recommended!
Marko M.
AP300-M450ET
Excellent service, fast processing and delivery of the product. Hearty recommendation for anyone looking for a simple, powerful, high-quality amplifier without unnecessary philosophy ;).
norman p.
Top ;)
fonctionne bien pour un canapé 3 places
David S.
Excellent cable interconnect RCA
Associé à des connecteurs NEUTRIK NF2CB2 et soudé à l'étain avec 4% d'argent, enterre mon câble RCA à 350 EUR soit disant audiophile. Un exemple de neutralité sur toutes les fréquences. Attention un peu rigide et très long à dénuder pour retrouver proprement les 3 petits conducteurs à chaque fois, mais l'effort est mérité. J'ai utilisé le fil rouge pour l'âme centrale, le blanc pour la masse et le blindage connecté coté source. De plus le câble est fléché donc je reconnais facilement le coté ou le blindage est branché sur la masse. Du coup je vais remplacer 1000 EUR de RCA par ces câbles DIY!
Jean Pierre b.
Excellent !!!
Après écoute , ce câble remplace avec brio un câble HP 7x plus cher, d'une marque américaine dont je ne siterai pas le nom et qui sonne à côté de lui comme "légèrement plus étouffé" avec une bande passante plus large, plus propre, plus réussit en faveur du Ludic.
Ce qu'il y a de rassurant, c'est que dans les 2 cas nous sommes dans la même esthétique sonore mais désolé le Ludic va plus loin.
J'entends plus de détails aussi.
Pour moi, le rapport qualité/prix est juste bluffant.
Je conseille vivement!
Michel V.
FOSI AUDIO T3 Amplificateur à Tubes Class AB 2x 6F2 Bluetooth 5.0 2x50W 4 Ohm The Fosi Audio T3 is a small tube amplifier allowing to enjoy the sound signature of this round and warm type of amplification at a low price. It is thus equipped with two 6F2...
Surprenant petit ampli.
Il est léger et a une puissance moyenne.
La réception BT est de bonne qualité.
Comme audiophile, en général je ne choisis pas des amplis qui ont des réglages de tonalité. Mais, là je m'y retrouve en l'utilisant avec avec mes HP large-bande que j'ai fait avec des Alpair. Ils ne font que 88dB, mais j'arrive quand même bien à sonoriser mon séjour avec ce Fosi T3.
FX-AUDIO TUBE-02 PRO 5725 Tube Preamplifier / Headphone Amplifier Class A With the Tube-02 Pro, Fx-Audio offers a small tube preamplifier and headphone amplifier in a compact and affordable format. Its preamplifier stage uses a pair of 5725 tubes,...
EXCELLENT PREAMPLI A TUBE
Ce préampli est très bon, il donne un son typé tube mais non caricatural. La rigueur est de mise, la transparence excellente et l'imagerie vraiment spacieuse. On peut changer les tubes si on souhaite plus de chaleur (accepte les 5654 et le 6J1).
Yannick S.
LQSC Class AB 4.0 Amplifier Board TDA7850 4x50W 4 Ohm This high quality Class AB amplifier module with 4 channels is capable of developing a power of 4x80W under 4Ω, thanks to a TDA7850 chip offering what is more a rich and...
2 entrées - 4 canaux
je l'ai pris pour Alimenter les tweeter et medium d'une paire d'enceinte 3voies à 3ampli avec filtration active par DSP. Ne chauffe pas en 12V.
le rendu sonore me parait meilleur qu'avec les 2 ampli 2x50W de class D qu'il remplace.
Michal D.
AUNE S17 PRO EVO Discrete Class A Balanced Headphone Amplifier Preamplifier 7500mW 32Ω Silver With its S17 Pro EVO, Aune unveils a powerful Class A headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features...
I like it
This + ESS dac + brighter linear (studio, reference) sounding mid-high end 300/600 Ohm brighter headphones:
Powerful (300Ohm upto volume 40, 600Ohm upto volume 55 is very loud from 60 total). Detailed. Clean sound - not bright, not cold, with just touch of added warmth, but I would not say it sounds warm. It adds some body to sound (perfect amount). It has smooth sweet lush mids. It does not increase fastness of music - it is touch on the slower relaxed side of sound presentation, but not too much - speed is almost in perfect middle.
Highs are not muffled - they keep the lushness of mids. Bass is nicely shaped and increasedly dynamic. Bass is not too soft. Slam is nicely defined. Bass does not bleed in mids. All frequencies are well balanced but listening attraction goes to mids and later to the balance of everything. Highs are as nicely defined as bass, but everything is lush. You can focus on music itself, not on aspects of sound. The lushness means that it is not overly analytical, but meant for enjoyment.
Space is nicely drawn. Seems natural and wide. Sound placement is nicely recognizable and it is not flat but there is sense of depth. Not too tall.
Canzar V.
Good value cable
after I changed the location of my hifi system, I needed a long speaker cable and I wanted to try Mogami.. considering that I use over 100 times more expensive silver cables from renowned manufacturers, I did not expect any spectacle in the sound. Mogami turned out to be a great cable for the value and I am pleasantly surprised by the sound quality.. after all we are talking about a wire that costs 11€/m..
Adrien B.
DAYTON AUDIO PC105-8 Speaker Driver Full Range 40W 8 Ohm 86dB 80Hz - 15kHz Ø10.7cm A full range speaker, compact and beautiful finishes. Ideal for building / repairing a small audio system or as a building block for more complex assemblies requiring multiple...
Ok
Bon haut parleur. Utiliser en médium dans un 3 voies. Fait le boulot mais un vrais médium aurait été plus performant. Attention pas top dans les aigu. Bon pour un 2 voies avec tweeter mais ne le remplace pas.
Adrien B.
DAYTON AUDIO DC25T-8 Speaker Driver Tweeter 50W 8 Ohm 93dB 3000Hz - 20kHz Ø10cm The Dayton Audio DC25T-8 is a dome tweeter with a ferrofluid-cooled aluminum coil and rubber suspension. The 1" titanium dome and precision phasing lens ensure very natural...
Bon tweeter
Aigu très distinct. Remplace mes jamo. Rien à voir avec les précédents. Parfois un peu "piquant" mais pour le prix je suis content du résultat
Adrien B.
DAYTON AUDIO DC160-8 Speaker Driver Woofer 50W 8 Ohm 86dB 30Hz - 4000Hz Ø16.5cm The Dayton Audio DC160-8 Classic Series 6-1/2 can be used as a woofer, midbass or small subwoofer.
Très bon HP. Remplace mes jamo défectueux. Belle différence. Grave beaucoup plus clair et moins brouillon. Je suis agréable étonné.
Guy L.
FURUTECH ALPHA 4.1T
Pour les personnes qui hésitent encore, allez y , j’utilise ce câble depuis plusieurs années et il est tout simplement incroyable. Ça marche de partout grave, médium, aigu. Des micros détails incroyables, un grave ferme et qui descends très très bas . Le vocal est également magnifique.
J’ai déjà conseillé ce câble à des collègues et l’avis est unanime.
J’ai même recablé plusieurs enceintes avec la version 2 x. 2,5 carré, pareil , les enceintes littéralement méconnaissable dans le bon sens.
Et pour les plus septiques et médisants, oui ce câble nécessite un rodage , je n’y croyais pas lues de l’achat de mon premier câble il y a plusieurs années de cela, et j’étais tellement dessus à la première mise en route que j’avais arrêté de suite l’utilisation du câble. Un jour pour rôder une paire d’enceintes je l’ai réutilisé afin de ne pas piquer celui de mon installation, j’ai laissé tourné sans être présent pour faire le rodage des enceintes, 8hoo après en rentrant je suis allé écouter, surprise Ça marchait vraiment bien avec ce câble sur une enceinte même pas rodée. Afin de vérifier cette impression, j’ai branché ce câble sur mes enceintes que j’écoutais habituellement, et là, magique , ça marchait très fort. Depuis ce jour, je n’ai plus jamais utilisé d’autre câble et j’ai Récemment encore acheté ce câble pour équiper une deuxième installation .
Alors au démarrage, par pitié, laissez tourner quelques heures vos nouveaux câbles, n’écoutez pas, allez faire autre chose en attendant que la magie opère. Alors ne me demandons pourquoi ces câbles sont tellement brouillons au démarrage et que ces derniers évoluent de façon incroyable en les rôdant.
Voilà, j’arrête là mais encore une fois , oui il est très bon après rodage.
Laurent M.
Bon rapport qualité prix.
Le Jantzen bleu me sert de base pour mes filtres dans le médium aigu depuis longtemps.
C'est une assurance d'un son équilibré avec des timbres naturels.
On peut bypasser l'aigu avec un petit condensateur de qualité supérieure pour peaufiner.
De part sa taille compacte il remplace avantageusement les condos parfois agressifs d'origine dans les enceintes du commerce.
Il y a un temps de stabilisation de quelques jours afin que le son soit vraiment agréable .
FILIPPO A.
SPARKOS GEMINI Hybrid Headphone amplifier / Preamplifier Tube 6922 and AOP SS2590 This Gemini headphone amplifier/preamplifier from Sparkos is a jewel of hybrid technology, whose main feature is the possibility of customizing it to suit your listening...
Ottimo amplificatore e altrettanto ottimo venditore!!
Ho alle spalle curca 45 anni di passione per l'ascolto in cuffia e ho avuto tantissimi sistemi dedicati. Ascolto prevalentemente musica classica. Ho voluto provare questo piccolo amplificatore e sto notando che è veramente apprezzabile, sia per l'aspetto e il senso di affidabilità costruttiva che incute, ma soprattutto per le sue prerogative soniche che lo pongono a un livello ben superiore rispetto a quello che la fascia di prezzo lascerebbe prevedere. Inoltre è ampiamente versatile dando la possibilità di cambiare la valvola di pre con agilità ed efficacia.
Consigliatissimo!!
Marc S.
AUDIOPHONICS HPA-Q450ET Power Amplifier Class D Four Channel Purifi 1ET6525SA 4x450W 4 Ohm The Audiophonics HPA-Q450ET power amplifier is based on a Class D architecture, using four Purifi 1ET6525SA amplifier modules, two Hypex SMPS1200A400 power supplies and an...
Superbe ampli
Enfin les sensations que je recherchais depuis un moment pour le Homecinéma. L'ampli révèle des performances que je ne soupçonnais pas de la part de mon Processeur Marantz 8805A : les impacts surtout avec beaucoup de micro détails et nuances et le tout avec une grande finesse et placement des objets dans l'espace.
En Hifi ? Pour l'instant le passe par mon Marantz pour écouter Qobuz via Audirvana. Je vais évoluer avec un DAC dédié mais pour le moment c'est déjà très bien. Impressionnant cette foultitude de détails à bas volume et un silence parfait ! Sans oublier cette maitrise totale des basses ! Attention du coup à la source car c'est très transparent et "sec ?" mais j'atteins là surement les performances du DAC du Marantz en mode Hifi qui n'est pas sa vocation première.
En comparaison, j'avais acheté cet ampli 4 canaux pour mes surround, centrale et une seule surround Back (mode 6.1) mais finalement je l'utilise sur mes colonnes principales au lieu des surrounds à la place de mon Denon PMA 110. Ces colonnes sont des Dynaudio Evoke50 pilotées sans problème. J'ai connecté une colonne par alimentation du HPA comme si j'avais 2 blocs séparés.
Pour finir sur Audiophonics, beaucoup de choses on été dites et je confirme leur sens du service client et les échanges quasi instantanés avec leur service support. Merci !
Frederic D.
Christophe L.
FURUTECH DAS-4.1 Balanced Interconnect Cable OCC DUCC Copper Ø10mm This Furutech DAS-4.1 balanced interconnect cable offers an absolutely outstanding design quality that will allow you to design your own high-end audio cables. It features two...
L'aboutissement
Déjà détenteur des DPS et dss j'avais hâte de remplacer mon fa.as 22 par le das . Mon câble est monté entre un master 10 et un he7 connection acss que j'ai modifié de Mini xlr passé en xlr ,Monté avec des cf 601 et 602 . Le résultat est génial mon système était déjà très silencieux mais la je trouve que la restitution à changer on veut toujours plus de détails mais la j'ai trouvé de la chaleur une âme pour faire simple j'ai gagné partout mais ce qui ressort c'est l'intention des chanteurs et des instruments il y a plus d'émotions. Pas facile à expliquer. C'est toujours trop cher mais c'est mon plaisir.
gilles C.
Cet adaptateur est très qualitatif ; la commande a été traitée et expédiée très rapidement
André G.
ATAUDIO POLARIS Power Cable Schuko IEC C15 Shielded Silver Plated OFC Copper 1m The ATAudio Polaris power cable is of exceptional quality and uses extremely pure conductors. Of the six insulated conductors in the Polaris, three are made of OFC 7N copper and...
Câble secteur ATAUDIO POLARISÉ 1 m
Ce magnifique câble secteur très bien fini devrait donné tout son potentiel musical mais pour mon utilisation il est trop rigide et me semble coloré dans le médium aiguë. Je ne l ai pas gardé ayant préféré mon câble actuel d un prix quasi équivalent
Sébastien D.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
TB mais qqes ajustements au début
J'utilisais déjà un autre DAC de Topping qui fonctionne très bien depuis de longues années, mais suite à un changement d'install j'avais besoin de la partie préampli du DX3 pour raccorder à un ampli de puissance, dans un bureau. LE DX3 est très bien dans cette config, super son, j’ai juste deux réserves. J'ai d'abord eu un bourdonnement très audible (à 2-3m) dans les HP (boucle de masse ?) que j'ai pu régler d'abord en éloignant l'appareil de l'ordi / écran (ce qui n'est pas très pratique pour un DAC de bureau !), ensuite en prenant un RCA mieux blindé que celui que j’avais au départ (le bourdonnement est toujours là mais vraiment très faible). L’appareil est branché à un écran-hub DELL, et le pb est bien pire si je le raccorde directement à l’ordinateur. Je ne sais pas si ce souci est propre à mon install cependant, mais prévoir un peu de patience au départ (et peut être les filtres RCA / USB nécessaires). Deuxième point, il ne faut pas trop compter sur la télécommande dans une installation normale type salon, elle doit pointer pile dans l’alignement de l’appareil pour fonctionner.
Philippe H.
Bonjour j ai acheté cette basse pour un simulateur
De courses monté sur la pzdake de frein on ressent bien le freinage..
Archie A.
Wonderful Upgrade
I have been listening to the amp daily since I received it a few days ago. The sound is open driving an Apogee Centaur (minor) which needed a more dynamic ampt. The AP300 amp fits the bill nicely. The reverb, echo and delay in the recording creates a realistic presentation of the music. Well done audiophonics.
Gaetan P.
C'est une découverte ces câbles
Ils sont faciles à dénuder et la matière du cable est très agréable
reste à voir comment ils transmettent le signal audio ... je n'ai pas trop d'inquiétures à ce sujet
Merci Audiophonics pour cette marque que je n'avais jamais vu
Gaetan P.
DYNAVOX Banana / Spades Jumpers OFC Copper 2x2.5mm² 25cm (Set x4) These top-of-the-range Dynavox jumpers are perfect for linking your audio installation in bi-wiring or for series connection. Each jumper is 25cm long, with two 79-strand 0.2mm...
Parfaits mais ... attention vous choisissez bananes ou fourches ... trop court pour les faire des cables hybrides (c'est un détail)
Ils sont parfaits et respirent la qualité
Merci Audiophonics
George R.
Excellent sound & exceptional value for money
What an impressive amplifier! Dead silent - both mechanically and electrically. Well-constructed. Detailed, open & dynamic sound. More power than needed for my Proac speakers. I have owned many amplifiers over the years and this has to be the best value for money!
George R.
Exceptional sound quality
I also have an "LPA-S600NCX" stereo power amplifier and wanted to compare the two concepts. I really struggle to determine if there is a repeatable difference between the two amplifiers. On certain tracks I feel that the Purifi is slightly more relaxed & natural and on others feel that the Hypex is a bit punchier in the bass. However, I am not confident that these subjective observations are repeatable. Both amplifiers are neutral (in a positive way), musical & silent. The one noticeable / repeatable difference is that the Purifi is cooler to the touch. Save a bit of money and buy the Hypex ncx? You cannot go wrong with either - both are exceptional amplifiers!
Michael M.
Burson v7 vivid
This opamps are amazing. I installed a pair in my musical fidelidy trivista dac and the detail that they gave to the sound is extraordinary!!!
Alain M.
Livraison dans les temps et emballage soigné.
Je suis bluffé par l'apport sur la qualité de l'écoute.
Précision, netteté et ouverture de la scène sonore.
Câble de très belle fabrication.
Merci Audiophonics pour votre sérieux
Pierre P.
BURSON AUDIO V7 VIVID PRO Dual OPA (Unit) As an evolution of the V6 VIVID, the V7 VIVID Pro stands out for its clarity, precision and high dynamic range. It is particularly recommended for...
le compromis ideal, à considérer avant toute velléité de changer d'appareil!
j'en ai fait l'acquisition pour tester sur un Dac Burson Conductor 3XP et je ne regrette absolument pas cet achat. l'appareil est littéralement transfiguré par rapport aux précédentes générations V6V. Plus de précision, de définition, disparition des sonorités métalliques qu'on reproche généralement à certains DACs (notamment vis a vis des puces ESS... légende urbaine). on est pour mon système sur un compromis définition/image/matière absolument parfait. pour info, mon système consiste en: Enceintes Martin Logan ESL13a, Ampli Accuphase E650, Mac mini avec Audirvana studio. la transparence des Martin Logan met en évidence le moindre défaut, la moindre trace d'agressivité, et là je me trouve après quelques heures d'utilisation sur une sonorité qui combine enfin un très grand naturel de rescision avec une précision sans agressivité. en bref, avant de céder à la tentation de changer votre sac/lecteur réseau pour une sonorité qui vous paraitrait trop fatigante la longue, et notamment si ce dac est équipé d'une ou plusieurs puces ESS, vous devez absolument essayer ce petit investissement, dont la mise en place ne requière pas de connaissances particulières. la liste des AOP compatibles est très bien renseignée sur le site Audiophonics et vous pouvez faire l'opération de changement sans avoir besoin d'autre chose que d'un bon tournevis ou d'une clé 6pans pour enlever le capot de votre appareil. toutes les opinions colportées sur les puces ESS et leur prétendu manque de naturel sont balayées par la mise en place de ces AOP. et si votre système vous parait vraiment trop agressif, vous pouvez également opter pour la version V7 Classic, qui vous apportera encore plus de douceur, de matière et de chaleur sur les timbres, au détriment peut-être d'une définition moindre et d'une image stéréo moins profonde. en tous cas, je tire mon chapeau aux ingénieurs de chez Burson pour avoir conçu ces petites merveilles, et aux gens de chez Audiophonics pour les livrer avec une qualité de service irréprochable.
Eero M.
TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Black Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a...
Great unit
I use it primarily as a dac/preamp for my Genelec monitors and as a dac/hp amp for my Beyerdynamic headphones. Does both jobs well and the unit is pretty compact. No complaints
Jean François N.
Très efficace. j'en ai acheté plusieurs pour mes 2 installations
Jean François N.
Un rapport performance très bon dans cette gamme
De très bonnes performances musicales et très complet.
Les DACs ont fait des progrès énormes il y a 10 ans il aurait fallu sortir 5 à 6 fois d'argent sans compter l'inflation
Jean François N.
Super Produit
Bien fabriquer très bonne restitution entre Audiolab 6000 CDT et SMSL D6S
Jean François N.
Produits bien fabriqué simple et efficace
Jean François N.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 15V 1.5A 50VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Super Produit
Alimente un Zen Ifi Streamer. parfait
