jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
AECO ARP-1512G RCA Connectors Tellurium Copper Gold Plated Ø11mm (Set x4) These high-quality aeco ARP-1512G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity...
Ne pas se laisser surprendre car la partie plastique peur se séparer. Bien maintenir celle ci lors de la brasure. Sinon, transparence et fluidité sont au rdv
Frank j.
DC 9V Jack Filter with Supercapacitor to Jack DC This DC 9V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 5F - 3.0V and an...
clean power with supercapacitor acts as a battery
much better sound, it can be heard,
thanks to the ,supercapacitor.
WARNING: do not use ifi power x it works, not that filter.
use regular plug in power supply of 2 ampere
Transfos pour bloc mono
2 transfos sur mesure pour la fabrication de 2 blocs mono (double PP el84). Après contrôle, belle fabrication, tout est OK avec un encombrement un peu supérieur en diamètre (écran électrostatique ?), sans conséquence pour un projet diy. Livré 11 jours avant la date prescrite.
Je recommande vivement.
Pino M.
VIBORG VS702R Pure Copper Spades OFC Copper / Silver / Rhodium Plated Ø4.5mm (Set x4) The Viborg VS702R are high quality forks, ensuring optimal connection and conductivity. These models are made of pure Copper, with a triple plating of OFC Copper, Silver and...
excellent product
I use them to terminate QED Genesis Silver Spiral , they are the perfect termination allowing the cable to express it's great performances.
They are very well built and finished , 5 well deserved stars!
Serrée et raide
Par trop le choix de gaines pour habiller les câbles de fort diamètre comme le cs361B de chez Elecaudio. Et cette gaine malgré son fort diamètre est très raide et ça reste compliquée pour enfiler le câble à l’intérieur.
Je recommande de faire le passage dans la gaine avec un tube et de talquer le câble, c’est bien plus efficace et plus rapide.
J’utilise pour ma part un élément de canne à pêche et c’est parfait pour détendre la gaine.
Le rendu final est vraiment sympa .
Patrick
Dynamique mais pas que
Je connais ce cable depuis longtemps et à chaque fois il me surprend. Assemblé avec des prises du même fabricant, les fameuses Elecaudio G24 et vous obtenez LE CÂBLE secteur au RQP imbattable.
Laissez le se faire une beauté pendant 20/30 heures et vous serez surpris par l’équilibre entre la dynamique maîtrisée des basses et la finesse cristalline des aigus.
Bref, à moins de 60€ en 1 mètre, c’est l’investissement le plus judicieux du moment.
Foncez vous ne le regretterez pas.
Patrick
Conforme au descriptif et rendu final agréable.
J’aime beaucoup cette gaine qui reste abordable financièrement mais qui techniquement n’a rien à envier aux Viablue.3 a 4 fois plus cher.
Peter Š.
FOSI AUDIO V3 MONO COMBO Pack 2x V3 Mono Amplifier + Power Noise Filter + Power Adapter 48V DC 10A With the Mono Combo Pack, Fosi Audio offers a product pack tailor-made for a dual mono installation. It consists of two V3 Mono amplifiers, a power supply noise reducer, a 48V...
Peter Š.
The sound is very good, with a high heat output.
Very good value for money.
Radek P.
o. k.
a luxury cable for that money
Transparent, clean, and detailed, with slightly more pronounced sibilants for now. I'll see how it sounds when played.
Steve D.
DAYTON AUDIO PA200-8 Speaker Driver Woofer / Midbass 250W 8 Ohm 92.4dB 70Hz - 9kHz Ø20.3cm The Dayton Audio PA200-8 is a professional woofer / midbass speaker capable of supporting high power levels using an open system. The motor structure dissipates the heat from...
Dayton spa300-D
Tres bon haut parleur , avec un bon tweeter et les bon filtre le son est super .
Rastislav K.
Nice
Marc A.
Ethernet RJ45 Cable Cat 8.1 40Gbps Shielded Gold Plated 3m This RJ45 Ethernet cable takes advantage of the recent Cat 8.1 standard, offering a bandwidth of up to 40Gbps. The cable itself has a high quality design with a double shielding...
Un bon cable n'améliorera jamais le son, mais un mauvais cable peut l'endomager.
Celui ci reste fidèle et neutre.
David m.
une super prise hifi
cette prise à changé le son de mon purifi 1et400.j'ai gagné en gain,clarté des aigus, les basses sont plus amples et propres.bref tout est plus précis,plus net.je recommande cette prise audiophile!
ps:mon cable d'alimentation est un ludic morpheus occ7n.
merci Audiophonics
Jochen M.
Tout n'est pas parfait
Je pensais à tort que les supercondensateurs fonctionnaient en quelque sorte comme de petites batteries et stockaient de l'électricité pendant une certaine durée. Ce n'est malheureusement pas le cas. Sur mon Pi5, ils se chargent très rapidement, il n'est pas nécessaire d'attendre les 20 à 30 minutes indiquées dans le mode d'emploi pour que la LED 3 s'allume. Quelques secondes suffisent pour le processus de charge. Est-ce normal ?
Après tout, la carte permet d'alimenter le Pi5 avec une batterie externe normale.
Traduit avec DeepL.com (version gratuite)
Richard M.
Truly fantastic amp - but am a bit disappointed: the capacitators in the picture are top Japanese ones - what I actually got were very average Chinese ones (Aishi). Will probably never make a big difference IRL but please update the pictures, it is a bit misleading.
Bernard g.
Excellente Interface
C'est la troisième interface dont je dispose (dont Hiface) et c'est certainement la meilleure. Aucune dureté dans la restitution musicale sur des enregistrements des années 50-60; c'est tout dire.Cerise sur le gateau, c'est la moins chère des 3.Fiabilité a voir.En tout cas, je ne regrette pas mon choix.
Jacques K.
DYNAVOX AMP-S PRO Audio Selector Switch for Speakers / Amplifiers Black The Dynavox AMP-S Pro makes it quick and easy to switch between two amplifiers and two pairs of speakers, without having to make new connections. Ideal for comparative tests...
Etonnant...
Expédition soignée et rapide: bravo!
Mais...commutateur dysfonctionnel : une cosse cassée, dessoudée du contacteur rotatif.. Une fois le contact rétabli les permutations sont aberrantes , il faut en fait brancher les HP sur les cosses amplis et inversement. Le fonctionnement est alors parfait.
naturel et présence sonore
Câblé avec fiches oyaide palladium/ berylium . Connecté à un lecteur laser denon cd 1700 qui ne me donnez pas satisfaction (son trop dur ) . Avec ce nouveau câble le naturel est bluffant ainsi que la matière sonore qui vous implique à l'écoute . Câble pour mélomane . Bien meilleur que le Tunami de la même marque qui équipé auparavant ce lecteur . Peut paraitre cher pour certain mais peut upgrader significativement l'appareil que vous connecterez .
VIBORG XF-202G Female XLR Connector 3 Poles Gold / Silver Plated Pure Copper Ø11mm Black (Unit) Viborg offers with its XF-202G a high-quality 3-pole XLR connector. Its contacts are indeed designed in pure Copper with triple plating Copper OFC, Silver and Gold, to ensure...
Belle surprise
Ça faisait un moment que je voulais essayer ces fiches xlr.
Déjà, elles sont magnifiques, de qualité et la restitution, est très audiophile. La scène est large, précise. Elle laisse le signal s' exprimer sans l'étouffer. Très recommandable pour un jeu de fiche de haute qualité.
Ivan L.
Don't you dare raise the price, ELECAUDIO, I'm looking at you
Don't be hard on me, I went to the lair and counted my banana connectors, 126 pieces,
from cheap ones from eBay to well-known brands for over 200 E per pair.
And some ELECAUDIO came with the cheapest ones I've ever bought.
How on earth can this be the best banana plug I've ever had.
Well, I'm an audiophile, how can I tell my colleagues with the same disease that the
speakers are connected for a few euros, so I'm lying, I got them through some guy who knows a guy
who does it by hand only for acquaintances and lives in some far, far away country,
I got them at a discount, 500 euros each! Look, I said, and I took the speaker cables and
walked two 45kg speakers around the room dragging them by the cables. Wow, everyone shouted.
Jokes aside, excellent construction, top-notch connection. Crimped, not soldered. Even made an effort
to harden the inevitably thinned crimped part a little.
Really surprised by the quality of the end result.
Ivan L.
Ivan L.
Tighten!!!
Other "khm Viborg khm" should look at how to make a simple but high-quality plug,
especially how to tighten the wires so that everything doesn't fall apart.
A little chemistry on the tightening screws to prevent unscrewing is a nice addition.
Bravo BALS, the cheapest connector I've bought and I'm the most satisfied with the quality.
Ivan L.
OK
Ok connector, a little more wobbly than the original one for the amplifier,
but it doesn't fit all the way in either because the slot on the amplifier doesn't have a
"normal" depth, go figure.
Patrick H.
SMSL A100 Amplifier Class D Infineon MA12070 Bluetooth 5.0 2x80W 4 Ohm SMSL offers with the A100 a compact and affordable but nevertheless powerful Class D amplifier, based on an Infineon MA12070 chip allowing it to develop 2x80W under 4Ω....
Peu à dire
Profitant du débit de la fibre et d'un dac de la même marque mon installation délivre un son bien supérieur à mes attentes.
Un seul regret: l'ampli se cale en bt à l'allumage sans autre possibilité. La perte de qualité est flagrante.
Ce n'est pas bloquant mais dommage.
fabrice d.
Adapter Male Jack 4.4mm to Neutrik Female XLR 4 Pins This adapter consists of a 4.4mm male jack and a 4-pin female XLR connector. It can be used to connect symmetrical high-end headphones to symmetrical amplifiers. The adapter...
pareil
Idem pour moi
Deux casses
Malheureusement une fois sous garantie et pas la deuxième
Dommage
Comme je l'écris souvent mieux c'est quoi :=)
Pour ce tarif mais ne retenais pas que le prix ce cable est simplement excellent.
Merci Audiophonics
Rachid C.
J'en rachète, donc très bon produit.
Rachid C.
WONDOM JAB3+ AA-JA32173 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 2x50W 4 Ohm The Wondom JAB3+ is an amplifier module capable of developing a power of 2x50W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio...
Petit mais costaud
Petit ampli, 2x50W, DSP. Très versatile. Rapport qualité/prix des plus intéressant. Je l'ai acheté pour expérimenter avec les DSP et je ne regrette pas mon achat.
Rachid C.
L'interface pour s'amuser avec son DSP
Utilisée depuis un moment avec les JAB3 et JAB4. Mise en œuvre ultra simple. Que dire de plus? Indispensable si vous aimer les DSP.
Rachid C.
Au top
Devant remplacer un transformateur peu commun, celui livré respecte totalement les spécifications voulue.
Rachid C.
WONDOM JAB4 AA-JA33285 Amplifier Board 4 Ways TPA3118 Bluetooth 5.0 DSP ADAU1701 4x30W 8 Ohm The JAB4 is a 4-channel amplifier module featuring Bluetooth 5.0 and an ADAU1701 DSP for an all-in-one audio solution. Based on a TPA3118 amplifier chip, the JAB4 can deliver...
Utilisé sur un projet 2.1 avec caisson de basse. Il est possible de bridger deux sortit pour le caisson, et d'utiliser deux sortie en stéréo pour les médium aigue. Un petit programme avec SigmaStudio pour le crossover. Et voilà!
Utilisé aussi pour faire de l'amplification active avec filtrage sur des enceintes deux voie à titre expérimental. Très prometteur dans cette configuration.
Rachid C.
Très robuste. Attention il est assez dur à manipuler.
Rachid C.
DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4...
Bon rapport qualité/prix
Je cherchais un petit subwoofer et je ne suis pas déçu. Pour le prix et le faible encombrement, c'est très bien pour faire un petit caisson.
johan s.
Un bon niveau pour un petit prix
J'ai changé les tubes et ça fait déjà un grand pas pour 20€ de plus. Juste mon soucis avec ce préampli je n'ai aucune idée de la position à mettre pour le réglage de basse et trebble afin de ne pas influer sur le son et le garder neutre comme un préampli sans modification de fréquence. Je ne veux même pas choisir à l'oreille ma préférence, je veux laisser neutre! Je ne pense pas que c'est position mini... peut être que je me trompe aussi! Le service après vente ne m'a pas répondu sur ce sujet et je n'ai pas de matériel pour faire ces mesures ni démonter ! Les vidéos ne parle pas de ça non plus... j'espère un jour avoir une réponse basée sur des mesures ou la réponse du constructeur.
Marc S.
MINIDSP FLEX HTx Audio DSP Processor 2x8 Balanced Channels SHARC ADSP21489 HDMI ARC eARC Big brother of the Flex HT, the Flex HTx from MiniDSP is a 2x8-channel multichannel audio processor perfect for integration into a home theater or multichannel sound system.
Perf et fonction incroyables
Ce FlexHTx est incroyable en terme de performance et de fonctionnalité loin de tout AV grand public même (T)HDG. Alors d'accord il ne gère que 8 canaux, à savoir donc, mais sur cette base toutes les configurations sont possibles. Couplé à mon Processeur Marantz 8805A sur lequel j'ai désactivé Audyssey pour laisser place à Dirac dans Flex l'écoute a largement gagnée en Impact, effacement des enceintes, détails, graves (propres)...
Par contre il faut du temps pour l'appréhender correctement car sa fonction de Bass Managment est très poussée et la procédure de calibration pas évidente à cause du LFE. Heureusement sur leur site le manuel en ligne est complet et bien fait.
Produit qui mérite d'être mieux connu et ses 5 étoiles +.
Andrius S.
Andrius
High quality audio cable, nothing to complain about. Excellent!
Andrius S.
3E AUDIO A7 Class D Stereo Amplifier PBTL 2xTPA3255 2x250W 4 Ohm 3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7 amplifier is based on two TI TPA3255...
Andrius
The amplifier body is high-quality, robust, heavy and the power supply is solid. The amplifier has a lot of power and freely drives my JBL L100 Classic MK2 speakers, I have never even turned up the volume to full. I use the amplifier together with a Wiim Ultra streamer and after adjustment the system sounds great. To adjust the frequency response in the room I used a Mini DSP Umik2 microphone and the PEQ program, the settings of which I transferred to the Wiim Ultra peq mode. I also use an XTZ 10.17 Edge subwoofer in the system. Thanks 3E Audio for perfect amplifier!
Marius G.
AUDIO-GD R-1 NOS R2R Discrete DAC DSP FPGA USB Amanero HDMI I2S32bit 384kHz DSD512 Black The NOS version of the Audio-GD R-1 benefits from new features and a number of improvements, with the aim of providing ever more precise and rich sound reproduction.
Beautiful quality DAC
I bought this DAC as an addition to my system following an advice from one of the most experienced audiophiles of my country. I asked for the best DAC around 1000 euro.
My setup: Spendor A7 speakers, Unison Research Unico Secondo amp with Sylvania NOS tubes, Eversolo DMP A6 streamer, AQ Rocket 44 speaker cables, Synergistic Research Basik XLR.
I replaced the internal DAC of Eversolo A6 by this Audio-gd R1 NOS hoping to get a better sound than the detailed but thin sound and the bloated bass. I bought also a Neotech Neub-1020 OCC silver USB cable to connect the new DAC.
I listened for three months and the conclusions are:
-much fuller bodied sound
-clear on all frequencies from deep bass, superb medium to highest hights
-natural voices like real singers
-tight round bass
-scaled music from delicate to blow your speaker rock
-sense of dark silent back
-sense of space between instruments
-sense of big sound.
Of course, good sound is obtained only when the speakers are proper positioned and angled, beside good gear.
Totally happy with this DAC. Audio-gd is not about marketing but about real quality.
Recommended.
Yohann S.
AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex...
Heureux!
Je viens de recevoir mon AUDIOPHONICS HPA-DM750ET, et sincèrement… aussitôt branché, aussitôt le voile s’est levé. Un vrai waouh immédiat à la première écoute. La scène sonore s’est ouverte, tout est devenu plus lisible, plus tendu, plus vivant.
Niveau mesures : distorsion ultra-faible, bande passante droite comme un i, dynamique énorme… mais ce n’est pas que des chiffres : à l’écoute, c’est incroyable.
C’est neutre, transparent, ultra précis, mais sans froideur. Chaque détail est à sa place, les graves sont d’une autorité rare, les aigus filent haut sans sécheresse, et les médiums sont super fluides.
Pour info, l’ampli alimente des Jenzen Illuminator de Troels Gravesen, donc des enceintes très révélatrices — et il les tient avec une aisance déconcertante.
Et pour situer son niveau : comparé directement à l’étage de puissance d’un Marantz Model 10 à 15 000 €…
Et honnêtement, le HPA-DM750ET s’en sort admirablement bien. On n’est pas loin du sommet.
Un mot aussi sur Audiophonics : service client sérieux, réactif, pro, avec un super contact humain. Franchement, c’est devenu rare et ça mérite d’être souligné.
Un rapport qualité/prix juste exceptionnel, une fabrication française de haut niveau, et une écoute qui dépasse largement les attentes à ce tarif.
Bravo Audiophonics
Je recommande sans la moindre réserve !
Martin Å.
AUDIOPHONICS MUSES8920A Dual OPA DIP8 (Unit) Audiophonics is proud to present its MUSES8920A AOP in DIP8 format. This dual AOP is based on a high quality JRC (Nisshinbo Micro Device Inc.) chip, features JFET inputs and is...
Great for the price!
Zacharias L.
TANCHJIM ZERO ULTIMA In-Ear Monitors Dynamic 30 Ohm 123dB Jack 3.5mm Tanchjim Zero Ultima in-ear monitors offer exceptional performance at an affordable price. Each earphone features a DMT 4 Ultra dynamic driver with titanium-plated composite...
Very good but...
Nice design and operates well instead of my first views that the sound was linear, after a few more tests with another aet that is proven to be linear or neutral, it was fond to have less bass and more trebles with standard audio spatiality as expected. This means this is an overestimated low-price product, even if the quality is very good
Pavol B.
DYNAVOX SDS4 Absorbeurs de Vibrations Aluminium / Silicone 40 x 18mm Silver(Set x4) This set of 4 SDS4 pads from Dynavox for hi-fi equipment and speakers effectively absorbs vibrations from your equipment. They feature a silicone pad encircled by an anodized...
Absorbers looks good, nice made, easy to use, little bit small, but because rubber is slightly stronger, harder, is possible to use them for more heavy devices. Work it? Yes, for very small vibrations and etc. It will help fr sound? Slightly...is indipendent for which device is used.
Pavol B.
XANGSANE XS-R13 RCA Connectors 24k Gold Plated Ø7mm (Set x4) These XS-R13 RCA connectors from Xangsane are high quality connectors. The contacts are made of copper alloy and are 24k gold-plated, for enhanced conductivity and optimum...
Moderate plugs
These RCA plugs looks good, quality made, aluminum body, good plast /no melting/, easy work with them. Pins and etc look genuine copper. But one thing - they don´t hold strong enough in RCA socket! Although I gently soldered the metal plates in the connector to make them hold better, since nothing is pressing them against the connector, it is only mediocre, temporary. If your RCA connectors are fat, modern strong, it may work.
Pavol B.
High Purity Silver Plated OFC Copper Wiring Cable PTFE Sleeve 0.5mm² Ø 3mm Transparent This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent conductivity while being resistant to...
Perfect wire with strong isolation
I use this wire for many thing, from cables, to internal wiring, and etc. Always perfect. Isolation is quite fat and strong, what sometime hel, sometime been hard. But it work perfect. Wire by him self is perfect. Recommend!
Pavol B.
XANGSANE XS-DIY1 Pure Silver Wire 99.99% FEP 0.08mm² Ø0.62mm The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission....
Good wire
Wire is good, price is perfect. Just i guess, is more thin than have to be. Teflon isolation is thin and hold very strong, i can´t take it out, just burn it. Silver is very fragile, be carefull. But sound is perfect.
Pavol B.
Good wire
Good wire, great price, just i guess is more thin than have to be, teflon isolation is hard to put out /i has to fire it only/, and very fragile /is silver/. But sound is perfect.
Claude G.
Super !!
J'étais sceptique avant de l'acheter, j'avais peur que ça impacte sur la qualité du son, et bien Non !!! Audiophonics m'avait rassuré a ce sujet avant l'achat, je n'ai ressenti aucune différence, le son reste intact et de bonne qualité, il allume et éteins mes amplis sans problème, je suis pleine satisfait de ce boitier, je ne peux que vous le recommander sans souci. Merci Audiophonics
Remy C.
Simple et efficace
NEOTECH NEI-2002 Interconnect Cable UP-OCC Pure Silver Triple Shielded Ø11mm Neotech's NEI series is a range of high-end cables. The NEI-2002 cable features two pure silver single-core conductors, both with a diameter of 0.58mm...
Lacking
I shouldn't have bought this cable- I swapped out with the Nemoi 1220 within about 2 weeks. The NEI 2002 is pure silver, not UPOCC and has the associated brightness/harshness that goes with it. I couldn't tolerate it even being aware it hadn't burnt in at all.
The best
These are a little difficult to work with due to the hollow pins, but they are the best sound wise. Have used Viborg and others that don't come close for build quality and sonic finesse.
