André A.
Fais le job
Produit correspond à la description. Très simple d'utilisation, léger compact bref parfait pour lire ou ripper support....
Luca C.
Panos M.
Its more my personal taste
Customers reviews - There are 19586 reviews.
Philippe s.
Je l’utilise sur une platine Pro-ject et il a indéniablement amélioré ses performances : moins d’électricité statique, moins de bruit moteur. Le son me paraît également meilleur.
Frank j.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
pure battery voltage
just as good battery thanks to the Ultra Capacitor
5 volts
equally good farad super 3 or ifi powerelite
Mika E.
MOONDROP PARA Planar Magnetic Circumaural Open-back Audio Headphone Ø100mm 101dB 8Ω 15Hz-53kHz The Moondrop Para is a high-quality headphone based on Planar Magnetic technology. It has inherited part of the structure of its predecessor, the Moondrop Venus.
Supraṇava
Ordering worked perfectly and delivery was superb fast to Finland. Ten points and a parrot badge:-)
Daniel D.
TINYSINE TSA7804B Class D Amplifier Module TPA3116D2 DSP Bluetooth 5.0 4x50W 4 Ohm The TinySine TSA7804B module is a four-channel Class D amplifier board with integrated DSP and Bluetooth receiver. Its TPA3116D2 chip is capable of developing 4x50W power at...
Nice, but needs noise reduction mod
I've built 2x 2-way active speakers with it and the result is awesome. The only issue was noise, which needed adjusting gain of TPA3116D2 by desoldering resistor 2 and replacing resistor 1 with 5.4kohm smd. They are under the heatsink. Would be nice if that was a default config or at least easy way of adjusting.
Pascal J.
IFI AUDIO ZEN PHONO 3 Phono Preamplifier MM/MC With the Zen Phono 3, Ifi Audio brings us the latest iteration of their renowned range of phono amplifiers. The Zen Phono 3 is a versatile, ultra-quiet phono amplifier with...
Suivi de mon 1er post
Je plussoie et même plus 1 étoile. Nouvel essai avec ma Technics sl-1500c et cellule Denon dl110, une MC haut niveau, le prépré sur le gain 2 : La grosse claque jamais entendu un vinyle sonner aussi bien, on retrouve la dynamique du cd , bien timbré de haut en bas, transparent à souhait, franchement les British ont fait un prépré au rapport Q/P imbattable . Pas étonnant qu'il soit déjà en rupture de stock, soyez patient il vous le rendra au centuple... Bonne écoute à tous...
Incroyable à ce prix !!!
Vu les débats médiatiques sur cet appareil j’ai tenté l’achat pour un équipement de bureau. Je ne suis pas déçu du résultat avec des enceintes TRIANGLE COMÈTE 40TH.
Pour en savoir un peu plus avec un ami nous l’avons connecté et essayé sur du matériel beaucoup plus cher (chacun jugera de la qualité de ces appareils) Préampli ACCUPHASE enceintes B&W série 800 D4 câblage AUDIOQUEST dans une pièce de 35m2 et le résultat est tout simplement impressionnant au regard du prix.
Une écoute très naturelle sur tout les registres pas de limitation de puissance ressentie . Évidemment le niveau d’écoute était modéré mais suffisant.
L’amplification numérique c’est l’avenir. Je serai curieux de tester les blocs mon dans les mêmes conditions. Bonnes écoutes à tous. Philippe.
Raphaël G.
Très bon potar
En remplacement d'un potar classique. Y a pas photo c'est le jour et la nuit. L'image sonore a retrouve sa place (plus besoin de balance) avec beaucoup plus de détails et une bonne séparation des instruments. Pour le prix c'est parfait.
Kai H.
Excellent quality / price ratio with linear power supply
If you want best possible sound from this player you should use a linear power supply. With a cheap sync mode power supply sound was nothing special. With Audiophonics` linear power supply sound was very good. There was like a night and day difference.
Martin K.
Martin Kunchev
I waited a long time, but it's worth it. Thank you Audiophonics. Excellent sound and sensitivity throughout the range. Good strength for its size. They fit perfectly in my quad system. However, a notch filter is needed to cut the frequencies between 900 and 6kHz. Even though they are mounted in a suspended ceiling they sound better than in a box. I strongly recommend
Christopher S.
A superb power amplifier
Purchasing this power amp has delighted and astounded me, with it's performance. Wonderful power with a complete lack of distortion drives my PMC Twenty5/23 floorstanders with ease, I have not heard them sound so good. I prviously used Quad Artera Stereo and Cyrus Stereo 200, this surpasses them both. It is very transparent and highly resolving which was an issue with some music, so I switched my speaker cables to DNM Reson which is a revelation with this amplifier. Clarity, power, with a capability far beyond it's price.
Un stradivarius électronique?
Pour une écoute en fichiers dématérialisés, maillon central du système, l'interface est le coeur de l'installation. A acheter d'urgence . Gustard a créer une électronique digne d'un Stradivarius ! incroyablement musical. Et toujours la performance Audiophonics, au rendez- vous.
EVERSOLO AMP-F2 Amplifier Class D 2x250W 4 Ohm / 1x450W 2 Ohm The AMP-F2, developed by EverSolo in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. As a...
Ça me convient parfaitement.
N'ayant jamais eu de setup "audiophile" auparavant - je viens d'un T-AMP90 - je trouve le son forcément excellent. Associé à des câbles 1877PHONO NOVA-SPK et des "petites" enceintes Elipson Prestige 2i (sans doute le maillon faible de la chaîne), prenant sa source d'un DAC Singxer SDA-6 PRO2 par l'intermédiaire de câbles XLR AUDIOPHONICS OBSIDIAN, j'obtiens un son clair, détaillé et chaleureux associé à une bonne réserve de puissance. Vraiment impressionnant !
À noter également, la présence du trigger et un ploc quasi inaudible à l'allumage.
Impécâble
Très bon câble ; impressionnant.
YANN P.
De la transparence…
Je confirme les commentaires précédents, ce câble de par sa conception UPOCC est hyper transparent, vous allez obtenir un son en 3D avec une scène sonore étagée. Compter une semaine de rodage. Bande passante énorme. À recommander…
Jean Paul T.
AUDIOPHONICS DAW-S250NC Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD Versatile and powerful, we offer you with the DAW-S250NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy your music in the best...
Bluffant
Ampli surprenant, puissance impressionnante, son équilibré, très détaillé. Présence des voix très réaliste, basses quasi sans limites.
Alimente des enceintes "maison" basses de 38 cm et médium aigus large bande de 21 cm, sans faiblir. Rapport qualité prix excellent.
Pascal J.
Evaluation sur la série Cross-cap
Utilisées pour renover les filtres de mes vieilles Elipson Concept 1
dont les valeurs des condos chimiques avaient largement dérivées m'ont fait redécouvrir ces bonnes biblios . donc pour leur rendre justice j'ai remplacé le tweeter Audax par un Monacor
dt28n (en vente ici) = upgrade au top; du coup je refait les filtres de mes dynaudio emit 30 avec les Cross-caps & résistances Mox + câblage interne Canare 4s6 ( en vente ici).
je n'ai pas terminé, vos en dirait + une fois finies mais je n'ai aucun doute sur la qualité de l'upgrade. Merci à Audiophonics pour proposer tout ces composants très utiles pour faire évolué ces produits fabricants pas tout à fait aboutis afin de ne pas concurencer leurs gammes supérieures!!!
Pascal J.
6 étoiles si possible
Aussitôt reçu aussitôt installé avec platine audio technica at lp 120xusb et cellule at 95 basique une galette test que je connais très bien dans différentes configs : Chico Freeman: "The Search".
Effet Waouh! quelle transparence et la dynamique digne de mon lecteur cd (Denon 110 anniversaire). J'ai oublié de préciser que le pré-pré est alimenté sur une batterie Antec 5V,5A et non sur secteur. Cela sur ma platine la plus bas de gamme. Je me propose de l'écouter sur ma Thorens td 126mk3 centenial cellule Sumiko Oyster Pearl, galette Sassy & Quincy "you're mine you", Superbement silencieux ce pré-pré , défini, la merveilleuse voix de Sassie m'envoute. Pour faire court 10 stars et devrait faire de l'ombre à bien des pré-prés +++chers.
Me reste à essayer mes cell. Denon dl-110 & 160 Mc high.
Mille mercis à Audiophonics pour sa célérité d'envoi, 10 stars
pour eux, un vieux client qui a encore de l'oreille!
Vladimír S.
Aladar
Il ne convient qu'aux composants sources. En utilisation avec un amplificateur, on constate une légère diminution de la dynamique, une augmentation des fréquences aiguës et une présentation du chant plus dure (AVR/1000€). Branchez donc l'amplificateur directement sur la prise et utilisez cette multiprise pour les composants sources.
Vadim P.
Unique device
This is really a unique device, classic and solidly constructed, reminiscent of the Japanese from the 60s or 70s.
The sound quality is stunning, just as you would expect from a tube device, incredible resolution and dynamics, deep black in the breaks.
A secret type. I would just like a more stable cover (like the Cayin devices) for the tube and non-slip feet.
Martin K.
Ich bin sehr zu Frieden!
Bei der ersten Lieferung waren die Cinch nicht dabei. Nach dem ich 2 mal geschrieben habe, sind die Teile am nächsten Tag schon da (kann überall passieren, hier aber sehr schnell reagiert).
Die Cinch sind wirklich erstaunlich gut gefertigt. Ich hab in der Preisklasse noch nichts besseres gesehen (und gehört). Auch von den Toleranzen sehr gut gefertigt. Ich habe keinen Stecker gefunden der nicht passt.
Bis zur nächsten Bestellung
Alain C.
USB 5V Supercapacitor Filter USB-C to USB-C / USB-A This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer...
Sur Raspberry Pi 4 avec hat Hifiberry Digi + et tournant sous gentoo player : l'apport est notable. Indéniable même.
Le RP4 était déjà alimenté sur une alimentation linéaire Tomanek, mais en intercalant ce filtre, le gain est notable.
Éclaircissement de la scène, recul du bruit de fond, meilleure définition des instruments.
A conseiller donc, notamment pour ceux qui utilisent un RPi comme steamer.
seul bémol : tous les deux utilisant le même principe d'intercaler des condensateurs sur le flux DC, un peu cher en comparaison d'un filtre FX-Audio Susie, par exemple, qui embarque lui des condensateurs Nichicon pour 1/3 du prix.
Adam S.
NEOTECH NEI-3002 MKIII Interconnect Cable UP-OCC Copper Dual Shielded Ø10.7mm Neotech NEI-3002 MKIII is a twisted conductor cable combining UP-OCC single-crystal copper strands and silver-plated UP-OCC single-crystal copper strands. Each of the two...
wow this is brilliant
maybe the best interconnects i have tried yet ,very transparent and big musical sound ,lots of air and 3d
Bruno F.
ARYLIC UP2STREAM AMP 2.1 Amplifier Module 2.1 WiFi Bluetooth 5.0 Tone Control 2x50W + 100W The Arylic Up2Stream Amp 2.1 is a 2.1 channel amplifier with full wireless connectivity. It will allow you to use a subwoofer while enjoying the convenience of audio streaming....
Good sound, unstable Wi-Fi, both with Wi-Fi and cable. Volume changes on its own, I didn't understand why, I change volume and it's never instantaneous, the device appears and disappears on the iPhone's Airplay even when connected by cable, I have to turn it off and on to make it appear, there is no anti-pop function, it pops when it is turned on and off power supply, lots of bugs just consult the forum, good for those who like to look for problems.
lionel l.
Une tres belle qualité de fiches Banane
Bonjour ,
Très content de ces fiches dont le rapport qualité / Prix est plus que raisonnable.
Salutations.
lionel l.
Une tres belle finition de cable
Bonjour ,
Vous recherchez un embout séparateur pour vos câbles , audiophonics là.
Très content de mon achat.
Salutations.
Nathan B.
magique !!
j'ai le premier modèle depuis 1 ans et ceului là est sorti ....arrivé a la maison je le branche et constate effectivement une belle amélioration et pis le premier modèle je le range et ...par curiosité au bout d'un moment ....je rebranche le premier avec celui là ( pour voir ) ....bennnn ....ça marche encore mieux ducoup exactement comme les purificateur de secteur d' iFi trop bien
iFi c'est super comme marque ...ultra quali et leur produit son très efficace
Nathan B.
LITTLE DOT MKIII SE Tube Balanced Class A Headphone Amplifier The Little Dot MKIII SE, the successor to the MKIII, is a tube headphone amplifier that offers excellent audio performance with a signature specific to tube devices, namely a...
Méchant !! ^^
Mdr au début je voulais le refourgué car c'étais vraiment pas terrible et pis je me suis fais une raison ( patience du rodage ) au moins 150 / 200 h et pfiouf ( avec de bon tube (gold lion dans mon cas )
Mon intérêt pour cet ampli l'a emporter en comparaison avec le Xduoo ta 20 plus dans les paramètre de fourchette de prix , puissance , lampe , hybride , full symétrique ; sinon LD meilleur en réponse de fréquence ; meilleur thd et surtout dans mon cas .....pouvoir profité de merveilleux intra ( j'aime pas les casque ) parceque cet ampli gère incroyablement bien avec même une impédance de 16 hom ....ok y'a un peu de bruit mais dés que je monte le son na pu de bruit....mais un orgasme auditif ^^
donc dans mon cas il est couplé avec un fiio k9 ess pro en symétrique lol banché sur audirvana et dans les oreilles un merveilleux fiio fh9 plus tout un tas d'accessoire occulte d'audiophile histoire de bonifier ça ;)
pis c'est la claque ..y'a un peu plus de vie et de chaleur avec les lampes mais c'est gentil ....rien a voir avec les ampli full lampe donc ...par contre il envoi méchamment la purée et y'a rien de mou pour les style de son électro de fou furieux ( quand le kick tape je suis entre l'enclume et le marteaux c'est du pur délire )
meilleur imagerie espacement de la sène sonore ...puissance général incroyable il est trés clair rien rédhibitoire en terme de saturation disto sur les intra et pis par contre omg cette basse et se son générale saturé... plein...beaucoup de corp il amène une super texture et définition du son... vive la classe a
et merci a l'équipe d'auiophonics
Jacques T.
Ce produit est très bien conçu, performant et améliore nettement les performances de mon preamplificateur phono Musical Fidelity V90 LPS, par rapport au petit adaptateur secteur fourni d'origine. Le souffle est diminué, la scène sonore plus large, c'est un plaisir. Je recommande ce produit.
Cordialement.
Jacques
Thibault G.
Quelle efficacité !
Un ampli très compact pour la puissance qu’il délivre. Quel plaisir d’avoir un amplificateur en classe D.
Les entrées sont forcements numériques.
Un ampli de qualité qui rivalise et dépasse, en termes de qualité sonore, avec des amplis 2,5 fois plus chers (CAMBRIDGE EVO 150 par exemple).
L’ampli n’est pas spécialement beau, mais sobre et très efficace. Utilisé avec des Focal ARIA 936.
Audiophonics a su écouter les utilisateurs, le firmware a été mis à jour et la façade a été changée. Il n’y a donc plus de problème de « clac » (firmware) ni de son très aigu provenant de la façade lorsqu’elle était allumée (remplacement de la façade gratuitement que j’ai pu faire moi-même sans renvoyer l’ampli).
Un produit qui est simple, efficace et fonctionnel.
Pour les bricoleurs il est possible de prendre la version DA-S250NC (sans wifi) et d’y accoler un Raspberry Pi.
Je recommande ce produit et le service d’Audiophonics. C’est vraiment très agréable d’avoir un service support qui fait confiance à ses clients.
Excellente alimentation
Connectée sur un streamer WIIM à la place d'une alimentation 5v type smartphone, le résultat est bien supérieur. C'est plus doux, mieux articulé, plus naturel sur tout le spectre.
Très efficace immédiatement !!
J'ai déménagé d'une maison vers un appartement en résidence.
Mon ensemble hifi est donc devenu trop puissant pour mes voisins.
Je pensais acheter un préampli passif Khozmo pour calmer la dynamique de mon ampli à tubes Octave V40 avec son alim black box intégrée.
Le changement des tubes KT88 pour des EL34 n'a pas suffit.
Ni même en plaçant des tubes 6V6 de 15 watts, toujours trop puissant, trop de dynamique.
Mes enceintes sont des Cabasse Caravelle d'un rendement élevé de 94 db.
Mon préampli phono est un clone Audio Note à tubes et mon lecteur CD un Sonic Frontiers SF-CD1 à tubes aussi.
Après recherche, je suis tombé sur ces atténuateurs passifs à petit prix.
Et ben, je vais économiser l'achat de l'excellent Khozmo !!
Placés 2 paires directement sur les entrées de mon ampli RCA phono et RCA CD, réglés à -10db le changement est instantané.
Je peux désormais manipuler le bouton de volume avec une amplitude plus importante.
Peut-être le réglage se fera finalement sur -15db.
Le plus important : le son, aucune perte de qualité, pas de ronflement, pas de perte de bande passante ni de dynamique.
Pas d'altération du timbre, c'est exactement ce qu'il me fallait.
Bravo à Audiophonics de proposer de tels articles, petit prix et livraison éclair comme d'habitude.
David C.
TINYSINE TSA3118B SMA Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture....
Petit mais costaud!
J'en possède 2 pour utilisation différentes et j'ai fais plusieurs test avec des systemes stéréo très différents. Ce petit ampli est difficile a mettre en défaut.
Klipsch r41m, parfait.
Focal SIB, parfait.
Focal aria 905, parfait.
Focal opal 8ti, parfait.
En gros il ira parfaitement avec n'importe quelle enceinte de type bibliothèque.
Maintenant on passe aux colonnes.
Klipsch r28-f, la encore parfait! Sur ces colonnes a au rendement (98db), il fait le même boulot que mon Denon x3700h.
Cabasse baltic Evo, la encore extrêmement surpris du résultat sur ces colonnes haut de gamme, le rendu est au moins identique a des ampli de plusieurs milliers d'euros qui doivent habituellement ces colonnes!
Le dernier essai et le seul décevant à été effectué sur des Focal chorus 826V W, modèle particulier comportant des membranes très rigides de la gamme electra, difficiles a driver pour ce petit ampli, mais ne lui n'en voulons pas.
Aucun des ces test n'a fait chauffer l'ampli, il reste quasiment a température ambiante en permanence.
J'ai monté mes 2 amplis dans des boîtes aluminium, l'un alimenté sur secteur par une alim 24v achetée ici, et l'autre avec une batterie de ma confection 21v 5000mah, je suis extrêmement ravis de ces petites bestioles! Le son est précis et toute la dynamique de vos enceintes sera mis en valeur.
Son rapport prix/performances est imbattable!
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Parfaite
5 volts parfaitement régulé, ne chauffe absolument pas y compris sur des Super Capa qui réclament largement les 2 ampères au démarrage.
Je possède maintenant deux de ces alim LHY en 5 volts ainsi que d'autres productions LHY qui est un fabricant très recommandable.
Sandy G.
bon fonctionnement
Bon fonctionnement constaté.
Sandy G.
bon fonctionnement.
ce câble de liaison asymétrique RCA remplit correctement sa tâche.
Je ne porte pas de jugement particulier, car cela reste subjectif.
Manuel G.
Tout simplement stupéfiant
L’amélioration sonore apportée par ce câble est tout simplement stupéfiante, ahurissante. Cela revient à changer de dac pour une gamme supérieure.
J’utilisais déjà les câbles ramm audio pour mes enceintes et mes alimentations. Je savais à quoi m’attendre, mais là on atteint un sommet.
Toutes les facettes de la reproduction sonore atteignent un niveau de réalisme incroyable (scène sonore, grave, médium, aiguë, détails, profondeur de scène, dynamisme…).
J’aime aussi les bagues de serrage qui assurent un contact parfait des connecteurs.
Il est beau également.
Seule ombre au tableau : j’ai reçu des câbles en vrac dans un sac en toile, mais les connecteurs n’étaient pas protégés… Étrange pour des câbles de cette gamme. L’impression d’avoir reçu du matériel reconditionné n’est pas très agréable…
Laurie P.
Shanling EC3 Player.
Im not going to get technical, and just simply say Wow, this is a Superb CD Player. Fantastic quality, worth every penny. Very happy with it.
BIZARRERIES APRES UN CERTAIN TEMPS D'UTILISATION...
L'enthousiasme suscité par ce petit préampli lors des premières utilisations a laissé place aujourd'hui à des doutes, en effet mes deux lampes neuves Jan 5654 se sont brutalement dégradées après seulement deux mois d'utilisation (à raison d'une heure de musique par jour), l'aigu est devenu hyper acide, insupportable, et le médium maigre, sans saveur. Je se sais pas si c'est le préampli qui a détérioré prématurément les tubes et je n'en écarte pas la possibilité car le niveau de sortie de cet FX-Audio Tube 03 est quand même très élevé (trop?). En remplaçant les tubes par des 6J1 (ceux d'origine) la restitution n'est pas vraiment bonne avec un aigu certes doux mais un grave manquant sérieusement de définition et de transparence. Bref je suis revenu à une liaison directe DAC-Ampli.
Johan D.
Great DAC for a small price
I was looking for a small DAC for my surround installation. I was considering the Chord Qutest, but to my surprise this little DAC cleaned up the sound. Especially the voices were much more natural, the bass more thighter and also the instruments are renderend very clean.
PS I lost the DAC in the new TV box, since it’s only digital. I’am glad i lost it, because i already wanted to upgrade the Center speaker, because the voices were not clear enough, I have an NAD surround connected to upgraded Focals and Kef 5005. As stereo amplifier i have the Audionet WATT + DNC connected to the upgraded focals.
All by all i recommend this DAC absolutely and can’t wait to try other supposedly better DAC’s
Super.
Excellent en montage parallèle pour mes filtres HP.
Livraison éclair, merci Audiophonics !
JANTZEN AUDIO COMPACT MKT 001-8040 Axial MKT Capacitor 160V 3.3µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Super.
Livraison éclair, merci !
Laurent M.
PSVANE KT88-Z Tetrode Tubes (Matched Pair) PSVANE's KT88-Z  power tube  offers a soft, warm sound, full and natural, with good balance and no background noise.  PSVANE  offers us a tube with a more...
Très bon tubes
Bonjour as toutes et tous enfin des tubes de très bonnes qualités j'avais toujours acheté des tubes de base et la avec ces tubes je redécouvre mes morceaux préférés beaucoup plus de détails de dynamique et un Bon très significatif en qualité d'écoute
jean francois a.
faite que sa glisse !
Le produit est bien emballé. j'ai eu un peu peur a cause de la viscosité. mais aucun soucis pour l'axe et la bille de ma rega planar 2 :D . attention au dosage il en faut peu car cela marche vraiment bien et crée de par sa viscosité comme un un couvercle hermétique si l'on en mets trop... mon plateau ne touché plus le fond au debut... a par cela tous est parfait et il y en a pour déééééééééés années ;)
Dhafer D.
SINGXER SA-1 V2 Balanced Headphone Amplifier Preamplifier Class A The Singxer SA-1 V2 is a complete, high-performance headphone amplifier and preamplifier based on Class A architecture and fully symmetrical discrete circuits. Version 2 of the...
Facilement recommandable
J'ai été un peu surpris que personne ne parle de cet amplificateur, alros je me lance !!
Le net est plein de revues du modele initial la "V1" mais pas la celui-ci donc je me suis lancé en espérant que ce sera aussi bon.
Coté qualité du son, ce que je peux dire en tout cas pour moi qui utilisait un monolith thx 887 depuis un bon moment , c'est qu'il y a un zest de chaleur en plus et moins de largeur de la scene sonore..
La puissance est suffisente pour ma part ( pour un hd660s et un hifiman ananda).
Ce qui est bluffant par contre c'est le silence, meme avec un iem extremement sensible aux sons parasites comme le KZ ZS10.
Il ne chauffe pas beaucoup et est très bien construit.
Donc pour moi c'est un ampli facilement recommandable auquel je ne trouve pas de defauts particuliers.
Mauro S.
IMR26650 Lithium-Ion 26650 Battery cell 3.7V 5200mAh Rechargeable This massive battery format can both be used with devices that require long battery life and devices that require high energy discharge (15A max).
Good capacity and duration.
Fonctionne trés bien
Ce sélecteur trés pratique offre une transparence étonnante grace aux relais utilisés.
Valentin C.
Ce que je cherchais
Je cherchais un câble plus précis dans les aigus et avec une basse plus maitrisée que celui que j’avais. Je me suis penché naturellement vers le plaqué argent qui m’intriguais. Je possédais le fameux ELACAUDIO HP-25OCC dont j’étais très satisfait.
Une fois reçu, j’ai rapidement essayé ce Viablue SC-2 et bingo ! Les aigus sont de retour, sans agressivité. Les médiums respirent ainsi mieux et donne beaucoup plus de cohérence dans les deux registres. Exactement ce que je cherchais !
Par ailleurs, j’avais peur de perdre un peu en précision sur les bas médiums et basses car je suis passé d’une section de 2x5.1mm à 2x4mm avec celui-ci. Et bien, deuxième surprise, l’assise est non seulement mieux tenue mais les basses sont plus tendues en gardent une belle présence. Aucune frustration ou perte d’informations, tout retourne naturellement à sa place, le son est plus linéaire et épuré.
Bref, j’y gagne aussi sur ce registre autant vous dire que je ne reviendrais pas en arrière et que je suis très satisfait alors qu’à la base je suis un « cablo-septique ». À chaque nouvelle expérience pourtant, les différences sont assez marquantes et biens réelles.
Sinon, très belle, fabrication allemande qui fait la peau dure aux clichés. Je les ai achetés pour 2x3 mètres de câble fixés et soudés à l’argent avec des bananes et des fourches Viborg; elles aussi plaquées argent. L’association est très bonne et fonctionne à merveille.
Vous l’avez compris, je recommande fortement.
Valentin C.
J’étais intrigué par le plaqué argent car je manquais de précision surtout dans les aigus et je ne souhaitais pas faire l’impasse une la section pour les basses. J’avais jusqu’à présent un câble de chez Elecaudio, le fameux HP-25OCC que je trouvais déjà très satisfaisant.
Suite au changement, Bingo. Les Aigus sont de retour. Ils sont là, enfin. Le médium n’a pas bougé mais l’ouverture en haut rend plus cohérent les deux registres. L’inquiétude était sur les basses car le câble est de section 2x4mm contre 2x5.1mm pour le Elecaudio. Et bien les basses sont toujours là, présentent, aucun manque, une assise toujours bien marquée et des basses beaucoup plus tendues. Même dans ce registre j’y ai gagné alors que de satisfaction !
Je précise que je suis plutôt un septique de la «  cablophilie » à la base mais j’en ai eu trois différents et à chaque nouvelle expérience les différences sont assez marquantes.
Sinon très belle fabrication, une qualité allemande donne la peau dur au cliché. Je les ai couple à des bananes et fourches Viborg plaqué argent elles aussi. Impeccable
Valentin C.
J’ai acheté ces supports pour mon amplificateur qui était sujet à des vibrations de meubles du aux basses des enceintes. Depuis, l’amplificateur est bien isolé d’un point de vibratoire du meuble. Difficile de signifier un quel conque impact sur la qualité du son mais l’amplificateur n’est plus sujet aux vibrations. J’imagine que cela est, à minima, bénéfique pour les composants interne de l’ampli. Fait le job. Je recommande.
