RAS tout marche si vous ne modifiez rien au niveau software (sur Volumio 2.619
This product is supplied as a DIY kit (Raspberry Pi & DAC not included). This kit does not require any welding on your part. The button and the screen are already there, you just have to plug and screw.
We also offer the mounted version: RaspDAC Network Reader for Raspberry Pi .
Audiophonics I-Saber V3 ES9023 and Raspberry Pi 3 Network Player
Designed around a 100% Aluminum case to accommodate the modules of your choice as well as all the necessary components, the RaspDac is developed directly in our workshops. This evolution also includes a slot for micro SD card slot, slot for infrared receiver.
Network Reader Kitt Raspberry Pi, the DAC and the software solution of your choice (Rune Audio, Picoreplayer, Raspbmc, Openelec).
Illustration with the Raspberry Pi 3.0 and the DAC I-Saber V3 ES9023 TCXO (not supplied).
It will allow you to get very simply a high-end Audio or Audio / Video player.
It has all the inputs / outputs necessary for its connection, its power supply (Jack DC 5.5 / 2.1mm), an HDMI port, a piercing for infrared receiver, an emplmicro SD card slot, as well as an OLED display.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility of having a high performance audio solution and achieves excellent value for money.
Display | OLED |
Holes for | 1x Micro SD / 1x RJ45 port / 4x USB-A / 1x ports HDMI / 1x port Analog output RCA stereo / 1x Input Jack DC 5.5 / 2.1mm / 1x Infrared receiver |
Dimensions | 160 x 140 x 50mm |
Display Size | 65 x 16mm |
Weight | 0.9kg |
Housing material | 100% Aluminum |
Color | Black |
This kit contains:
To use this kit without DAC Saber V3 and without ATX power control it is necessary to use a bistable switch
Average votes 4.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Laurent B.
Gerard l.
Gerard l.
