These RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The gold-plated pure copper contacts combine excellent conductivity with flawless protection against oxidation. The teflon insulation and brass connector body greatly limit the impact of interference on the signal. Mounting is simply by soldering, and 4 heat-shrink sleeves are supplied.
Technical specifications
Product type | Male RCA connectors |
Contacts material | Pure copper |
Contacts plating | Gold |
Insulation | Teflon |
Body material | Brass |
Mounting type | To weld |
Max cable diameter | Ø8.5mm |
Dimensions | 15.5 x 43.6mm |
Package | 4x Male RCA connectors 4x Heat-shrink sleeves 1x Allen key |
Max cable diameter (mm) | 8.5 |
Connectic | Male |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
