VIABLUE T6S SCREW RCA Connectors Gold Plated Ø8mm (Pair)
15%
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while providing excellent oxidation resistance for greater durability.
4.7 / 5
Reduced price!
Reference : 17532
Limited special offer
20,40 €tax incl.
-15%
17,34 €tax incl.
14,45 € tax excl.
Shipping date: 07-04-2026.
Viablue T6S Screw
Viablue T6S Screw Connecteurs RCA Plaqués Or Ø8mm (La paire)
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while providing excellent oxidation resistance for greater durability. The connector body is made of matt black aluminium with the most beautiful effect. M4 1.5mm hexagon socket screws allow the cable and connector to be held very securely in the body. The T6S RCA accepts cables from 6mm to 8mm in diameter.
Product typeRCA Connectors
Contact platingGold 24k
Shell materialAluminum
Min/Max Cable diameterMin : 6mm
Max : 8mm
Total length45mm
Shell length30.5mm
Shell diameter13.5mm
ColorMatt black
QuantitySold per pair (1 connector with red ring, 1 connector with black ring)
Max cable diameter (mm)9.5
Mounting typeTo screw
ConnecticMale
6 reviews
Moyen
Fiches de belle qualité mais rien pour fixer la tresse de masse. C'est une fiche sans soudure.
Elle se retourne en arrière sur le câble et vous devez avoir câble de 8mm de diamètre obligatoirement.
Sinon le contact avec le corps de la fiche ne se fera pas.
Heureusement j'ai un câble Viablue de 8mm à monter dessus.
C'est la première fois que je mets autant de temps à monter un câble, un peu galère donc.
La fiche RCA tient fermement sur la RCA femelle, ça c'est bon.
Livraison Audiophonics en 24 heures !!
This review has been posted for VIABLUE T6S SCREW RCA Connectors Gold Plated Ø8mm (Pair)
ViaBlue T6S & Neotech NEI-3004G
Montés sur du Neotech NEI-3004G en modulation, ces connecteurs confirment la qualité allemande : les vis et pas de vis sont d'une précision irréprochable.
Côté sonorité, je suis agréablement surpris par un rendu très neutre et doux. Une excellente affaire, surtout avec les promos Audiophonics .
Loistavia liittimiä!
Loistavia liittimiä. Helppo asentaa ja liitokset ovat hyvät! Ei tarvitse kolvailla!
Nämä ovat aivan loistavia liittimiä. Helppo asentaa ja liitokset ovat hyvät ja tiukat. Plussaa vielä ettei tarvitse kolvata!
Kvalitetno, čvrsto izrađen konektor. Treba malo strpljenja i preciznosti prilikom spajanja vijčanog konektora, ne previše zatezati centralni pin.
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good...
