Belles, faciles à mettre en œuvre, mais le diamètre n'est pas précis et le serrage n'est pas efficace.
Sur des WBT-0210CuMs, un coup difficile à faire rentrer, un coup ne serre pas bien.
Je ne les recommande pas.
Male RCA Connectors Pure Silver PTFE Ø11mm (Set x4)
Viborg's VR106AG are premium male RCA connectors, using pure silver contacts to provide maximum conductivity. They also feature PTFE insulation and a rugged aluminum body with carbon fiber insert. The connector accepts cable diameters up to Ø11mm.
Product type | Male RCA connectors |
Contacts material | Pure silver (99.998%) |
Body material | Aluminum and carbon fiber |
Insulation | PTFE |
Max cable diameter | Ø11mm |
Mounting | To solder |
Dimensions | 58*Ø14mm |
Quantity | Set de 4 (2* red connectors, 2* black connectors) |
Max cable diameter (mm) | 11.0 |
Mounting type | To weld |
Connectic | Male |
Contacts Material (Connector) | Silver |
Contacts Plating (Connector) | None |
Average votes 4.2 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Alain P.
Serkan A.
Serkan A.
Yannick M.
Guillaume B.
