Refurbished product - Grade S
Speaker Cables Spades OCC Copper / Silver 2.5m (Pair)
The Silver Dart OCC speaker cable is the result of 3 years of development and testing on aspects of mechanical transmission, EMI / RFI pollution and quality of materials used. The Silver Dart OCC Graphene offers today a quality of restitution equivalent to the best High End productions of the market, able to be compared to the American and European references.
The H-Wound structure is a threading technique allowing a high quality filling rate with 16 000 spirals/revolutions per meter, without loss of strands during the manufacturing process.
This high precision of assembly and tightening guarantees the same number of wires and the same cross-section for each conductor right up to the end of the final connection, which every enthusiast is entitled to expect from a top-of-the-range loudspeaker cable. This high resolution cable includes a manufacture of the cable in the cable. Thus, after the sheath, there is a classic EMI protective layer separated by two layers of cotton strands. This acts as mechanical anti-vibration decoupling with the conductive and dielectric Graphene part of the cable.
The Silver Dart series conductors and strands are made of high purity OCC Copper and OCC Silver that undergo several treatments. These improve conductivity and promote signal transmission for accurate sound reproduction:
It is a cryogenic treatment at two temperature levels, -186°C and -196°C, depending on the nature of the material used. This processing makes it possible to optimize the conductor crystals with always a unique desire to provide the best possible signal transmission.
After extrusion, the Silver Dart strands go through a high voltage thermal surface cleaning process, close to electrolysis and more efficient than cleaning with a conventional cleaning agent. The result is high purity, completely removing extraction oils and heating residues from the surface. This process also makes it possible to obtain a ready-to-use cable that is already well tuned and offers an optimal result, right from the first musical notes on a high-end HiFi system.
1877Phono Zavfino is the first manufacturer in the world to integrate a screen protector with Graphene, an unparalleled advanced material. It can reject EMI / RFI interference and offer a quantity of high quality microdetails. Graphene is also an excellent protection against electrostatic discharges affecting the signal circulating on the surface of the strands.
You will find a complete article in PDF format on the advantages of Graphene: ZGRAPH LDP 1877Phono.
Conductor material | OCC Copper/ Silver Mono-Cristallin |
Section | 5mm² (10AWG) / H-Wound™ |
Dielectric | High absorption Graphene, PTFE, LDPE |
Specific treatments | Deep Cryo Treated : low temperature treatment at -186°C and -196°C Ultra Sonic 7 : high voltage cleaning |
Sleeve | Anti-static braided sheath |
Cable finish | EVA Anti-vibration |
Total cable diameter | 24mm |
Connectors | 24K Gold platet spades |
Cable length | 2.5m |
Length (m) | 2.5 |
Shielding | Yes |
Section (mm²) | 5.00 |
Connector | Banana / Spade |
Conductors material (Cable) | Copper |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
Refurbished Grade | Grade S |
