Refurbished product - Grade A
Product in perfect condition. Cardboard packaging damaged.
Mini Loudspeakers 4Ω ⌀100mm
This DAYTON AUDIO 10cm midrange driver provides ideal high bass (54Hz) for the design of compact and musical two-way speakers. Its frequency of use up to 5000hz allows a wide choice of compatible high-frequency speakers that are easy to filter. An excellent affordable, easy-to-use speaker that will find its booster with a low-cost D-class music class amp.
| Various Technical | |
| Type loudpseakker | Woofer |
| Power | RMS : 40W |
| Impedance | 4Ω |
| Sensibility | 86.8dB @ 1W/1m |
| Response frequency | 55Hz - 5000Hz |
| Diameter coil | 25mm |
| DC resistance coil (Re) | 3.2Ω |
| Inductance coil (Le) | 0.97mH |
| Frequency resonance (Fs) | 53.8Hz |
| mehcanical quality(Qms) | 3.14 |
| Electrical quality (Qes) | 0.4 |
| Total Quality coefficient (Qts) | 0.35 |
| Movement air mass (Mms) | 9.9 gr |
| (Cms) | 0.88mm/N |
| Emissive area surface(Sd) | 50.3cm² |
| Force factor (BL) | 5.2Tm |
| Volume of air mass equivalent to mobile crew compliance (Vas) | 3.1l |
| Linear excursion max (Xmax) | 4.0mm |
| material membrane | polypropylene |
| Suspension material | Caoutchouc |
| Magnet material | Neodyme |
| Total diameter | 108mm |
| Total depth | 65mm |
| Magnet Diameter | 80mm |
| Coil diameter | 25mm |
| membrane Color | Black |
| Speaker Power (W RMS) | 40.0 |
| Speaker Type | Midbass |
| Speaker Type | Full range |
| Impedance (Ω) | 4 |
| Loudspeaker diameter (mm) | 100.0 |
| Diaphragm type | Paper |
| Efficiency / Sensitivity (dB) | 87.0 |
| Max Linear Excursion (Xmax) (mm) | 4.0 |
| Lowest frequency (Hz) | 55 |
| Highest frequency (Hz) | 5000 |
| Refurbished Grade | Grade A |
