By buying this product you get 74 loyalty points
Refurbished product - Grade A
Damaged cardboard packaging.
DAC Headphone Amplifier Amanero 32bit 384kHz DSD512
The Audio-GD R2R-11 MK2 is THE Swiss army knife for audiophiles. Combining the functions of DAC, preamplifier and headphone amplifier, it will meet most needs. It features a discrete R2R NOS DAC, an Amanero 384 USB interface, a dual stage power supply, selectable digital filters and an MCU controller.
This MK2 version benefits from several notable improvements, aimed at further enhancing the musicality and sound quality of the device.
Equipped with an Amanero Combo 384 USB interface rather than a USB32, it offers both optimal performance and compatibility. It supports sampling rates up to 32bit 384kHz PCM, as well as DXD and up to DSD512. Its design also allows it to enjoy an extremely low jitter level.
The R2R-11 MK2 offers optimal performance thanks to carefully selected components. Thus, in addition to supporting DSD / DXD and sampling rates up to 32bit 384kHz, it benefits from the NFB (Non-Feedback) technology developed by Audio-GD on the ACSS stage. This allows the converter to offer a lesser sound coloration and consequently a faithful restitution, a very low distortion and a great linearity. You thus gain in dynamics, details and neutrality.
The R2R-11 MK2 features four discrete R2R DACs, two per DA-8 module, specially designed and optimized for converting digital to analog signals. These allow support for output sampling rates up to 32bit 384kHz and a signal-to-noise ratio of 100dB.
All components have been carefully selected to offer a device that is as efficient as it is durable.
| Specifications | |
| Product type | DAC Headphone amplifier |
| Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial |
| Outputs | 1x Stereo RCA 1x Jack 6.35mm headphone output |
| SNR | 100dB |
| THD+N | < 0.04% |
| Frequency response | 20Hz - 90kHz (-3dB) |
| Output level | Headphone output : 10Vrms Variable level : 5V Max Fixed output : 2.5Vrms (high gain) / 1Vrms (low gain) |
| Headphone output power | 3800mW @ 25Ω 2400mW @ 40Ω 950mW @ 100Ω 330mW @ 300Ω 165mW @ 600Ω |
| Output impedance | Headphone output: 2Ω DAC output : 2Ω |
| Input sensitivity | Coaxial 75Ω : 0.5Vp-p Optical : 19dBm |
| USB Compatibility | Windows, Mac, iOS, Linux |
| Supported sampling rates | USB : PCM up to 32bit 384kHz, Native DSD up to DSD512 Coaxial : PCM up to 24bit 192kHz Optical : PCM up to 96kHz |
| General | |
| Supply voltage | 220-240VAC 50/60Hz 100-120VAC 50/60Hz |
| Consumption | 15W |
| Dimensions | 280 x 240 x 85mm |
| Weight | 3.5kg |
| Housing material | Aluminum |
| Color | Black |
| Package | 1x Audio-GD R2R-11 MK2 1x Power cable 1x USB cable |
| Input | Optical |
| Input | SPDIF |
| Output | Jack 6.35mm |
| Output | RCA |
| Output | ACSS |
| DAC / ADC Chip | R2R LADDER DAC |
| Max sampling rate | 384kHz |
| Color | Black |
| Networking | No |
| Remote Control | No |
| Refurbished Grade | Grade A |
