By buying this product you get 59 loyalty points
Refurbished product - Grade B
Some small scratches on the case.
Streamer WiFi DLNA AirPlay Bluetooth 4.2 32bit 768kHz DSD512 MQA
The Eweat DMP20 is a powerful and versatile network player, capable of playing many streams, whether your files are stored on a NAS, computer or smartphone connected to your network, or even on a local storage device. Its digital/analog conversion stage based on an AKM AK4493EQ DAC chip allows it to support high sampling rates, up to PCM 32bit 768kHz and DSD512 while offering a clear and rich sound reproduction. This DAC is also associated with a USB interface XMOS XU216 capable of decoding audio files efficiently.
The Eweat DMP20 also offers the ability to decode and playback your MQA (Master Quality Authenticated) files, ensuring sound quality as close as possible to the original studio recording.
1 | ON/OFF LED Indicator |
2 | Hard disk status indicator |
3 | Volume button |
4 | ON/OFF button |
5 | IR Receiver |
6 | Ethernet status indicator |
7 | WiFi status indicator |
8 | Power supply connector |
9 | Balanced XLR output |
10 | WiFi antenna |
11 | Anti-theft lock slot |
12 | Power supply voltage selector |
13 | Single-ended RCA output |
14 | USB-C input |
15 | USB-A Host input |
16 | Ethernet RJ45 input |
17 | HDMI output (for connection to a TV or other screen) |
18 | MAC address and serial number |
Product type | Streamer |
Connectivity | WiFi Dual Band 802.11 a/b/g/n 2.4G/5.8G Bluetooth 4.1 |
Network protocols | DLNA AirPlay Roon Samba |
Inputs | 1x USB-C 1x USB-A 3.0 (USB Host) 1x Ethernet RJ45 1x Slot for 3.5" hard drive (max. 16TB) (hard drive not included) |
Outputs | 1x Balanced XLR 1x Single-ended RCA 1x HDMI (GUI) |
DAC Chip | AKM AK4493EQ |
CPU | ARM Cortex-A53 Quad Core |
RAM | 2Go |
Flash memory | 16Go |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 DxD up to 352MHz |
Supported Bluetooth codecs | aptX |
Frequency response | 20Hz-20kHz (+0.002/-0.0023) |
Dynamic range | 123dB |
SNR | 123dB (20Hz-20kHz, A-Weighting) |
Channel separation | -136dB |
Supported file formats | DSF, DFF, AIF, AIFF, ALAC, FLAC, M4A, MP4, WAV, APE, MP3, AAC, WMA, OGG, ASF |
Supply voltage | 220-240VAC 50/60Hz 110-120VAC 50/60Hz |
Housing material | Aluminium |
Total dimensions | 424 x 275 x 77mm |
Color | Front panel : silver Rest of the chassis : black |
