Refurbished product - Grade B
Reconditioned by the manufacturer. Some scratches, marks or impacts on the case.
Highly anticipated, FX-AUDIO's X7 DAC is a real concentrate of technology that uses the best components of the moment to achieve a sound clarity and accuracy rarely achieved. From the point of view of its electronic construction, the DAC X7 is optimized for a very respectful conversion of the musical nuances in order to preserve the richness and the depth of the sound signal.
The DAC X7 is based on the excellent converter AK449 and provides sound resolutions usually found only in advanced professional devices. It allows to enjoy each sound in its smallest detail with a level of distortion almost null. In addition, its signal-to-noise ratio is one of the best in the market with a score of 120 dB. Used in parallel with an XMOS chip, the X7 can take advantage of what the market is currently doing best in terms of 32-bit USB interfacing.
As powerful as it is versatile, the DAC X7 has all the necessary ports for easy integration into your Hi-Fi system. Toslink, Coaxial, USB & Micro-USB input & RCA output with two headphone outputs. A digital display on the front panel displays the essential parameters such as the active source as well as the sampling frequency, a very practical tool that will greatly facilitate the installation and handling of the device to arrive quickly to an optimal rendering.
The FX-AUDIO X7 has a very accessible volume knob on the front panel. In this, it stands out from the bulk of its direct competitors like the SMSL M6 that offer a similar level of performance and price range without having this option.
The Dac X7 is a must-have item that will easily find its place in any advanced audio installation.
" This DAC-X7 FX-Audio offers quality sound performance with fine and precise reproduction and uncommon decoding capabilities. "
USB sample rate | 32bit / 384kHz |
Coaxial / optical Sample rate | 24bit / 192kHz |
DSD | 64 / 128 / 256 |
Input | Optique, USB, Coaxiale, Micro USB, AUX |
Output | Variable RCA / Jack 6.35mm & Jack 3.5mm |
Impedance | 16-300Ω |
Alimentation | 12V 1A |
DAC | AK4490 |
USB Interface | XMOS |
S/PDIF Chip | CS8422 |
Headphone amplifier | TPA6120 |
Signal Amplifier | OPA2604 |
Package Contents | |
1x | DAC X7 |
1x | US Power cord / Wall adapt |
1x | USB-A / USB-B cable 1.5m |
Input | SPDIF |
Input | RCA |
Input | Optical |
Output | RCA |
Output | Jack 6.35mm |
Output | Jack 3.5mm |
DAC / ADC Chip | AK4490 |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
Color | Black |
Networking | No |
Remote Control | No |
Refurbished Grade | Grade B |
