Refurbished product - Grade A
Product in perfect condition. Damaged packaging.
This product is indeed the new model with DAC ES9017 introduced by MiniDSP in May 2025.
Big brother of the Flex HT, the Flex HTx from MiniDSP is a 2x8-channel multichannel audio processor perfect for integration into a home theater or multichannel sound system. It features 16 analog inputs, 8 on RCA connectors and 8 on balanced 6.35mm jacks. There are also numerous digital inputs, including USB-B, Toslink optical, SPDIF coaxial and HDMI ARC/eARC. It features a full suite of audio processing functions such as bass management, parametric equalizers, crossover adjustment, advanced biquad programming and delay/gain settings.
In terms of performance, the MiniDSP FLEX HTx achieves a very low level of noise and distortion, making it a device of choice. HDMI ARC/eARC and USB inputs support 8 channels of linear PCM. A front-panel OLED display and volume control knob provide easy control of the device. Settings can be easily modified using Stereo Dirac Live® acoustic correction software (DIRAC license not included, but available here).
Output is via 8 channels on RCA connectors or 8 channels on balanced 6.35mm jacks, with THD+N of just 0.00014% and 0.0001% respectively.
Please note that Flex HTx does not support bitstream decoding (e.g. Dolby/DTS). The audio source must be capable of producing linear PCM (LPCM) for multichannel support via HDMI.
| 1 | 8x RCA analog inputs |
| 2 | 8x Balanced TRS 6.35mm analog inputs |
| 3 | Trigger 12V jack 3.5mm |
| 4 | HDMI ARC/eARC input |
| 5 | DC power supply connector |
| 6 | USB-B input |
| 7 | Toslink optical input |
| 8 | SPDIF coaxial input |
| 9 | 8x RCA analog outputs |
| 10 | 8x Balanced analog 6.35mm jack outputs |
| Specifications | |
| Product type | 2x8 channels Audio DSP Processor |
| Inputs | 8x RCA unbalanced 8x balanced 6.35mm jack 1x HDMI ARC/eARC (up to 8 LPCM channels) 1x USB-B (up to 8 channels) 1x Coaxial (Stereo) 1x Optical Toslink (Stereo) |
| Outputs | 8x RCA unbalanced 8x 6.35mm balanced jack |
| Other connectors | Trigger 12V on jack 3.5mm |
| Processor | Analog Devices SHARC ADSP21489 400MHz 32bit floating point |
| Interface USB | XMOS |
| USB compatibility | Windows (ASIO driver) Mac OS Linux (Multichannel configuration up to 7.1 channels) |
| HDMI connectivity | ARC/eARC (up to 8 LPCM channels) Supported sampling rates : 32 - 96 kHz |
| Filter technology | MiniDSP DSP toolbox (routing, bass management, parametric EQ, crossover, gain/delay) Optional software upgrade to Dirac Live® 3.x Full Range (20 Hz - 20 kHz) multichannel correction |
| DSP preset | Up to 4 presets |
| CEC control | HDMI CEC control for Mute/Volume/View |
| Measures | |||
| Balanced Jack TRS 6.35mm | RCA unbalanced | ||
| Analog audio input connectivity | 8 x TRS balanced | 8 x RCA unbalanced | |
| Analog audio input impedance | 200 kΩ | 100 kΩ | |
| Analog audio output impedance | 300 Ω | 150 Ω | |
| Maximum analog input/output level | 4 Veff/4 Veff | 2 Veff/2 Veff | |
| Frequency response | 20 Hz – 20 kHz ± 0,1 dB | 20 Hz – 20 kHz ± 0,1 dB | |
| Digital to analog (input 1 kHz, 0 dBFS) / AES17 20 kHz LPF | RSB | 127 dB(A) | 124 dB(A) |
| THD+N / SINAD | -120 dB (0,0001 %) / 120 dB SINAD | -117 dB (0,00014 %) / 117 dB SINAD | |
| Crosstalk | -132 dB | -120dB | |
| TRS analog to analog (1 kHz input, 4 V RMS) / AES17 20 kHz LPF | RSB | 120 dB(A) | 118 dB(A) |
| THD+N / SINAD | -114 dB (0,0002 %) / 114 dB SINAD | -112 dB (0,00025 %) / 112 dB SINAD | |
| Crosstalk | -130 dB | -120 dB | |
| General | |
| Supply voltage | 12V 1.6A |
| Power consumption | 16.5 W (idle) 3.7 W (standby) |
| Dimensions | 41.5 x 429 x 236mm |
| Package | 1x MiniDSP Flex HTX audio processor 1x Remote control 1x External switching power supply 12V 1.6A |
| Input | USB |
| Input | Jack 6.35mm |
| Input | Optical |
| Input | RCA |
| Input | SPDIF |
| Input | HDMI ARC |
| Output | Jack 6.35mm |
| Output | RCA |
| Max sampling rate | 96kHz |
| Max sampling rate | 48kHz |
| Max sampling rate | 192kHz |
| Color | Black |
| Refurbished Grade | Grade A |
