[GRADE A] XDUOO TA-32 DAC / Tube Headphones Amplifier
-10%
Refurbished product - Grade A
With the TA-32, xDuoo unveils a balanced Class A headphone amplifier and DAC based on a ROHM BD34301, a 5U4G tube and two 12AU7 tubes. These audiophile components enable it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA via its USB-B input, as well as headphones output power up to 3000mW into 32 ohm.
Reduced price!
Reference : 21492
Refurbished
999,00 €tax incl.
-10%
899,00 €tax incl.
749,17 € tax excl.
Torn packaging box.
xDuoo TA-32 Balanced DAC Class A Tube Headphones Amplifier 12AU7 5UG4 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA
Photo of xDuoo TA-32
With the TA-32, xDuoo unveils a balanced Class A headphone amplifier and DAC based on a ROHM BD34301, a 5U4G tube and two 12AU7 tubes. These audiophile components enable it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA via its USB-B input, as well as headphones output power up to 3000mW into 32 ohm. In addition, a Qualcomm QCC5125 chip provides Bluetooth 5.1 support for a wide range of codecs: SBC, AAC, aptX, aptX LL, aptX HD and LDAC. Versatile, the TA-32 features numerous inputs and outputs for easy integration into any Hi-Fi system, whether as a DAC or headphones amplifier.
xDuoo TA-32 highlights
xDuoo TA-32: Powerful tube headphones amplifier
The xDuoo TA-32 is based on a hybrid design consisting of a 5U4G rectifier tube, two 12AU7 amplifier tubes and Class A transistors. The combination of these components delivers a warm, smooth sound, while enabling output power of up to 300mW under 32 ohm. The TA-32 is therefore able to drive headphones and IEMs with impedances from 32 to 600 ohm via its various headphone outputs: balanced 4.4mm jack, balanced 4-pin XLR and single-ended 6.35mm jack.
The xDuoo TA-32 amplifier circuit
The xDuoo TA-32 DAC chip
xDuoo TA-32: ROHM BD34301 DAC
The TA-32's digital-to-analog conversion is based on a ROHM BD34301 DAC chip. It supports sampling rates up to PCM 32bit DSD512 and MQA via its USB-B input, and PCM 24bit 192kHz via its Toslink optical, coaxial and AES/EBU inputs. What's more, this DAC chip comes in the form of a card that can be easily replaced by another DAC produced by the brand, should you wish to experiment with different types of sound rendering.
xDuoo TA-32: Bluetooth 5.1
The xDuoo TA-32 features Bluetooth 5.1 functionality thanks to a Qualcomm QCC5125 chip supporting high-definition codecs such as aptX, aptX LL, aptX HD and LDAC for the most reliable and stable wireless transmission.
xDuoo TA-32 Bluetooth functionality
xDuoo TA-32 overview
13.12” OLED display
2Control buttons
3Volume/source button
45UG4 tube
52x 12AU7 tubes
6Single-ended Jack 6.35mm headphones output
7Balanced Jack 4.4mm headphones output
8Balanced XLR 4-pin headphones output
9Balanced XLR line output
10AUX RCA DAC / TUBE output
11AUX RCA input
12Balanced XLR input
13AES/EBU input
14Coaxial input
15Toslink optical input
16USB-B input
17Bluetooth antenna
18110/240V mains voltage switch
19IEC power supply / power switch
Product typeDAC
Headphone amplifier
DAC chipROHM BD34301
Amplification components1x 5UG4 Tube
2x 12AU7 tubes
4x Class A transistors
Bluetooth chipQCC5125
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x AES/EBU
1x AUX RCA input
1x Balanced XLR input
Bluetooth
Outputs1x Balanced Jack 4.4mm headphones output
1x Balanced XLR 4-pin headphones output
1x Single-ended Jack 6.35mm headphones output
1x RCA DAC output
1x RCA Tube output
1x Balanced XLR output
Supported sample ratesUSB: PCM up to 32bit 768kHz, native DSD up to DSD512, MQA
Toslink optical, coaxial, AES/EBU: PCM up to 24bit 192kHz, DSD DoP64
Supported bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
OS compatibilityLinux, Windows, MAC OS, IOS, Android
Compatible headphone impedance16-600 ohm
DisplayOLED 3.12"
Single-ended Jack 6.35mm headphones output specifications
Output power2300mW @ 32 ohm
Frequency response20Hz-60kHz (+/-0.5dB)
THD+N≤ 0.01%
SNR116dB
Crosstalk75dB
Balanced Jack 4.4mm / XLR 4-pin headphones output specifications
Output power3000mW @ 32 ohm
THD+N≤ 0.03%
SNR118dB
Crosstalk≥ 104dB
Single-ended AUX OUT RCA specifications
Output level2.0Vrms
Frequency response20Hz-20kHz (+/-0.5dB)
THD+N0.0007%
SNR117dB
Crosstalk≥ 108dB
Balanced XLR output specifications
Output level4.0Vrms
THD+N0.0006%
SNR125dB
Crosstalk≥ 113dB
Power supplyAC 100-120/220-240V
Dimensions31 x 24 x 17cm
Weight5.4kg
ColorGrey
Package1x xDuoo TA-32
1x 5U4G Tube
2x 12AU7 tubes
1x Power supply cable
InputXLR
InputAES/EBU
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipROHM BD34301EKV
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
ColorGray
ClassTube amp
ClassClass A / AB
[GRADE A] XDUOO TA-32 Balanced DAC Class A Tube Headphones Amplifier Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA
Refurbished product - Grade A With the TA-32, xDuoo unveils a balanced Class A headphone amplifier and DAC based on a ROHM BD34301, a 5U4G tube...
