BEATECHNIK X LHY AUDIO LPS-A6-MKII Linear Power Supply Module for EverSolo DMP-A6 Gen 2
Designed specifically for the Eversolo DMP-A6 GEN2 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture, which is entirely hand-assembled. It incorporates a 30VA NORATEL toroidal transformer, ensuring a stable and silent power supply. The regulation circuit is based on an LT3042 ultra-low noise regulator, combined with a PNP power transistor, to provide an extremely linear voltage with low drop and reduced modulation, even under heavy load.
By buying this product you get 31 loyalty points
Reference : 20973
310,00 €tax incl.
258,33 € tax excl.
Shipping date: 07-05-2026.
Beatechnik x LHY Audio LPS-A6-MKII Linear Power Supply Module for EverSolo DMP-A6 Gen 2
BEATECHNIK x LHY AUDIO LPS-A6-MKII : front view
Designed specifically for the Eversolo DMP-A6 GEN 2 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture, which is entirely hand-assembled. It incorporates a 30VA NORATEL toroidal transformer, ensuring a stable and silent power supply. The regulation circuit is based on an LT3042 ultra-low noise regulator, combined with a PNP power transistor, to provide an extremely linear voltage with low drop and reduced modulation, even under heavy load. The internal wiring, made of silver-plated copper, optimises conductivity and reduces losses, enhancing the precision and cleanliness of the electrical signal. This rigorous design guarantees a stable, clean and silent power supply, allowing the Eversolo DMP-A6 to reveal its full potential.
The EverSolo DMP-A6 Gen 2 / DMP-A6 Master Edition Gen 2 warranty becomes null and void if the power supply is removed or replaced
In order to maintain the validity of your warranty, if you have already purchased an EverSolo DMP-A6 Gen 2 / DMP-A6 Master Edition Gen 2 from Audiophonics, we offer to install it for you in our workshop. You will be charged a fixed fee for this service, which will be communicated to you by email. To do so, please contact us via the contact form, under the ‘Pre-sales’ tab, selecting ‘Technical information - Advice’ reason.
If you would like to purchase an EverSolo DMP-A6 Master Edition Gen 2 with the LPS-A6 MKII power supply pre-installed, as well as a remote control, please visit the EverSolo DM-A6 Master Edition Gen 2 Upgrade product page.
Product typeLinear power supply kit for EverSolo DMP-A6 Gen 2
Supply voltage220-240VAC 50/60Hz
PackageSold by unit
InputNC
OutputNC
Output voltage (V)NC
Output current (A)NC
Input voltage (V)220.0
Input voltage (V)230.0
Input voltage (V)240.0
Power SupplyRegulated Linear Power Supply
3 reviews
Parfait
Pour remplacement d'une alim de DMP-A6 gen2 HS. Le remplacement est simple à réaliser pour tout bricoleur. Le niveau du son est peut-etre un peu plus "élevé" que sur l'alimentation native. Tres content de cet achat. Le son du DMP-A6 couplé a un Roksan K3 V2 + AE320 toujours aussi ouaaa.
This review has been posted for BEATECHNIK X LHY AUDIO LPS-A6-MKII Linear Power Supply Module for Eversolo DMP-A6 GEN 2 220V
Great product
Good quality product! The Eversolo sounds very good.
The price is a bit high, and the warranty period could be longer.
(The original power supply for the Eversolo isn't great. There's actually a design flaw in a component.)
Très satisfait
Produit très bien conditionné et livré rapidement.
Qualité de fabrication au rendez-vous et très facile
à installer dans mon Eversolo DMP-A6 Gen2.
Fonctionne parfaitement, j'attends une période
de rodage pour constater les améliorations à l'écoute.
Merci à Audiophonics
Designed specifically for the Eversolo DMP-A6 GEN2 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out...
