BEATECHNIK x LHY AUDIO LPS-A6 MK2 220V Linear Power Supply Module for EverSolo DMP-A6 GEN 1
Designed specifically for the Eversolo DMP-A6 GEN 1 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture, which is entirely hand-assembled. It incorporates a 30VA Multicomp Pro extremely linear voltage with low drop and reduced modulation, even under heavy load.
By buying this product you get 31 loyalty points
Reference : 20989
310,00 €tax incl.
258,33 € tax excl.
Shipping date: 17-11-2026.
Beatechnik x LHY Audio LPS-A6 MK2 220V Linear Power Supply Module for EverSolo DMP-A6 GEN 1
BEATECHNIK x LHY AUDIO LPS-A6-MKII : front view
Designed specifically for the Eversolo DMP-A6 GEN 1 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture, which is entirely hand-assembled. It incorporates a 30VA Multicomp Pro extremely linear voltage with low drop and reduced modulation, even under heavy load. The internal wiring, made of silver-plated copper, optimises conductivity and reduces losses, enhancing the precision and cleanliness of the electrical signal. This rigorous design guarantees a stable, clean and silent power supply, allowing the Eversolo DMP-A6 to reveal its full potential.
The EverSolo DMP-A6 Gen 1 / DMP-A6 Master Edition Gen 1 warranty becomes null and void if the power supply is removed or replaced
In order to maintain the validity of your warranty, if you have already purchased an EverSolo DMP-A6 Gen 1 / DMP-A6 Master Edition Gen 1 from Audiophonics, we offer to install it for you in our workshop. You will be charged a fixed fee for this service, which will be communicated to you by email. To do so, please contact us via the contact form, under the ‘Pre-sales’ tab, selecting ‘Technical information - Advice’ reason.
Product typeLinear power supply kit for EverSolo DMP-A6 Gen 1
Supply voltage220-240VAC 50/60Hz
PackageSold by unit
InputNC
OutputNC
Output voltage (V)NC
Output current (A)NC
Input voltage (V)220.0
Input voltage (V)230.0
Input voltage (V)240.0
Power SupplyRegulated Linear Power Supply
alim Eversolo DMP A6
livré en 3 jours top ! évolution importante sur la qualité d'écoute vraiment un bon achat
This review has been posted for BEATECHNIK x LHY AUDIO LPS-A6 MK2 220V Linear Power Supply Module for EverSolo DMP-A6 GEN 1
Designed specifically for the Eversolo DMP-A6 GEN 1 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands...
