The Fosi Audio VOL20 is a volume control interface for controlling the volume of a multimedia source via Bluetooth or USB connection. As well as offering precise volume control, it incorporates practical features such as play/pause, previous/next and mute/unmute controls. With its customizable RGB LED, 10m Bluetooth range and up to 15 hours of battery life, the VOL20 is ideal for controlling your multimedia devices with ease. All integrated into a robust, modern aluminum chassis.
In addition to controlling the volume of your source, you'll have access to a host of additional functions:
The Fosi VOL20 is compatible with many OS in plug & play (without driver) for immediate use: Windows, macOS, iOS, Android, HarmonyOS.
The RGB LED at the base of the VOL20 can be customized in a wide range of ways.
A 750mAh battery allows the VOL20 to run for up to 15h with its LED on, and up to 500h with the LED off.
| 1 | Multifunction button |
| 2 | LED control knob |
| 3 | Charge indicator |
| 4 | USB DATA/charging port |
| 5 | Ignition switch |
| Specifications | |
| Product type | Bluetooth volume control |
| Connectivity | Bluetooth / USB |
| Bluetooth range | 10m |
| OS compatibility | Windows, macOS, Android, IOS, HarmonyOS |
| Case material | CNC-machined zinc alloy |
| General | |
| Charge | Via USB-C |
| Battery | 750mAh |
| Battery life | 15h with LED / 500h without LED |
| Dimensions | Ø55mm |
| Package | 1x Fosi Audio VOL20 1x USB-C/A to USB cable |
| Input | Bluetooth |
| Input | USB |
| Output | Bluetooth |
| Output | USB |
| Color | Gray |
| Transmission / Reception protocol | Bluetooth |
