FURUTECH FI-E30 NCF (R) Power Plug Schuko Type F Rhodium Plated Pure Copper
4.8 / 5
Reference : 11336
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 07-04-2026.
furutech-fi-e30-ncf-r-embase-schuko-cuiv
FURUTECH FI-E30 NCF
The base Schuko NCF FI-E30 (R) has several recent revolutionary technology developed by FURUTECH expert and global leader of the "Pure Drive".
After long sessions of plays and readings by audiophiles figures of Japanese industry, selected insulation materials are glass fiber and nylon recognized for their insulating properties.
Incorporated into select Furutech products, Nano Crystal² Formula --- NCF is comprised of a special crystalline material that has two “active” properties. First, it generates negative ions that eliminate static and secondly, it converts thermal energy into far-infrared. Furutech then combines this remarkable crystalline material with nano-sized ceramic particles and carbon powder for their additional “Piezo Effect” damping properties.
The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material – only found in Furutech products !
Dimensions and distances
All dimensions are given in millimeters (mm).
conductorsα (Alpha) Pure copper Rhodium plated
Dimensions50.6mm × 50.6mm × 36.0mm ( L×W×H )
Insulation materialsNylon/fiberglass incorporating special “NCF” anti-resonance damping material - nano-sized crystalline, piezo ceramic particles and carbon powder
NCF Treatyceramic particles and nanoscale carbon powder for their "Piezo Effect" (cushioning properties)
Type2-pole +earth
Rating16A 250V A.C
Max cable diameter (mm)2.5
Mounting typeTo screw
ConnecticFemale
ConnectorSchuko
Rated current (A)16.0
13 reviews
Fi e30 ncf
A high end way to start from the wall. In my case folowed by 3ts 762 (fi28r) and MPC5 stealth
This review has been posted for FURUTECH FI-E30 NCF (R) Power Plug Schuko Type F Rhodium Plated Pure Copper
Une prise indispensable...
Quelle amélioration par rapport à une prise schuko ordinaire, mon intégré Roksan chante bien mieux, aération sans commune mesure, un aigu plus fin , le grave est mieux tenu. Coté mécanique rien à redire c'est vraiment fait pour durer.
Pair with an NCF plug
This NCF socket, when paired with Furutech’s NCF plug gives amazing results. Silent background to the music and more inner detail.
Indispensable
Peut-être l'élément le plus important de toute installation hifi. Une fois monté, j'ai l'impression que tous les éléments de mon installation sont montés en gamme. Un bien meilleur rendu général, plus de transparence, un gain sur la scène sonore, en largeur et profondeur. Un grave plus net et profond et de la matière dans le médium. Je suis très satisfait de l'amélioration apporté par cette prise. Et pour le montage murale, j'ai utilisé les plaques proposées par audiophonics spécialement adapté à ce modèle qui m'a permis de monter la prise sans pb dans mon mur et avec un rendu visuel très sympa.
DOMMAGE, ne convient pas pour montage mural
Produit super qualitatif, plutôt solide, borniers a visses montage solide avec plaque alu, mais voilà :
le boitier ne rentre pas dans une boite d'encastrement mural standard (legrand orange ou autre).
Il vous faudra entailler ces boites en plastique très cassantes avant d'installer cette prise au mur. Ca vous évitera d'insister avant et de rayer votre façade.
Aussi, les visses proposées en option pour la plaque murale ne sont pas assez longues, celles fournies dans les boites d'encastrement standard sont mieux.
Sinon le reste est ok.
