Super son . Utilisé avec connexion symétrique casque Audio technica
Full Balanced Headphone Amplifier MUSES8920
The Audiophonics HA-B6120 is a balanced headphone amplifier with excellent sound reproduction thanks to its high-quality design and the use of high-performance components. Thus, the amplifier stage of the device embeds twp TI TPA6120 chips allowing the HA-B6120 to develop an important power in order to accompany high sensitivity earphones as well as high impedance headphones. The amplifier also offers a gain selector on the front panel to match your listening device. This amplifier stage is associated with an input stage, based on double J-FET MUSES8920 AOPs in buffer, offering excellent technical characteristics.
The balanced structure of the HA-B6120 allows a reduction in distortion (0.001%) and an improvement in dynamics for a precise, rich and lively reproduction. The amplifier has a balanced XLR input, a balanced XLR 3-pin headphone output and a balanced XLR 4-pin headphone output. For added versatility, the HA-B6120 also features an unbalanced input on stereo RCA and an unbalanced headphone output on 6.35mm jack. A front-panel switch allows simple selection of XLR or RCA input.
For the rest, the amplifier benefits from an optimized design to deliver a beautiful sound reproduction, in particular through the integration of quality components such as WIMA capacitors, Philips diodes, an ALPS potentiometer or Neutrik connectors. It also incorporates an effective protection system, checking the status of the left and right channels and protecting your headphones. The integrated linear regulated power supply provides a clean electrical signal to all circuits.
Product type | Balanced headphone amplifier |
Amplification chip | Dual TI TPA6120 |
Inputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
Outputs | 1x Balanced stereo 3 poles XLR 1x Balanced stereo 4 poles XLR 1x Single-ended stereo Jack 6.35mm |
Gain switch | H (High) L (Low) |
Sensitivity | L (Low): 1.40V RCA H (High): 0.70V RCA L (Low): 2.80V XLR H (High): 1.40V XLR |
Output level | 9V (RCA) 18V (XLR) |
Frequency response | 2Hz - 20kHz |
Distortion | 0.001% |
Accepted impedances | 18 - 600 Ohm (Recommended: 300 Ohm and above) |
Housing material | Aluminium |
Color | Front panel: Black Rest of the housing: Silver |
Dimensions (without connectors) | 25.2 x 16.1 x 6.2mm |
Weight | 1.94kg |
Power cable | Not inclued |
Average votes 5.0 / 5 10 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Eric K.
Eric K.
LAURENT L.
Philippe c.
