MUNDORF VN300 Zero Ohm Self Coil 6.8mH
The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced distortions.
By buying this product you get 26 loyalty points
Reference : 17323
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Mundorf VN300 6.8mH
Zero Ohm Self Coil
Mundorf Self Bass Woofer Sub
The central spot of a ZOC is calibrated and adjusted by hand between two laminar rings (a L-shaped and a E-shaped). The volume of the central space determines the inductance of the coil which demands enormous precision in the manufacturing process to ensure there will be no saturation at high load.
These coils are especially suitable for filtering your bass speakers. Their low impedance improves the impulse response.
Dimensions
Dimensions Mundorf Zero Coil
Inductance6.8mH
Tolerance5%
coil wire diameter3mm
CoreFeron
MaterialOFC 99.99% pure
Dimensions130 x 115 x 97
Inductance (mh)6.8
The Zero Ohm Coil (ZOC) is a transformer format coil.  It is made of  Feron , a material with high electronic qualities that...
