Acheté en remplacement d'une alim similaire cramée après 6 ans de bons et loyaux services suite à une mauvaise manipulation.
Excellente qualité de fabrication, composants de qualité, notice très détaillée. Bien sous tout rapport.
By buying this product you get 23 loyalty points
Switching Power Supply Module 1200W 2x64V
The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a nominal power of 1200 Watts in an extremely small footprint. It has been specifically designed and developed by HYPEX to provide the 2 x 64V voltage required for the operation of the brand's UcD™ amplifier modules.
Product type | Switching power supply |
Input voltage range | 190-250V AC (on main power plug 220V) 95-130V AC (on main power plug 110V) |
Output voltage | 2x64V DC |
Max power | 1500W |
Nominal power | 1200W @ 20Hz |
Switching frequency | 100kHz |
Dimensions | 165 x 105 x 55mm |
Weight | 750g |
Protection | Over-voltage |
Input | PCB Connector |
Output | PCB Connector |
Output voltage (V) | 64.0 |
Output voltage (V) | 2x64 |
Output current (A) | NC |
Input voltage (V) | 95.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 110.0 |
Input voltage (V) | 200.0 |
Input voltage (V) | 220.0 |
Input voltage (V) | 250.0 |
Input voltage (V) | 120.0 |
Input voltage (V) | 100.0 |
Input voltage (V) | 190.0 |
Input voltage (V) | 130.0 |
Input voltage (V) | 210.0 |
Input voltage (V) | 240.0 |
Power Supply | SMPS |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Henry G.
