MEAN WELL MW SE-1000-48 Switching Power Supply SMPS 1000W 48V 20.8A
By buying this product you get 25 loyalty points
Reference : 12114
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 05-08-2025.
Compact and easy to use, this power supply is ideal for integration into your high-power DIY projects for amplifiers in CLASS D from Sure Electronics (Sure AA-AB AB32274) by using two Mean Well MW SE-600 series power supplies, the module can be controlled SURE AA-AB32774 of 2x500w under 8 ohm
(Attention! Request a power input cable with a 3.5mm² cross-section)
PDF of the specifications available in the "Download" tab : Mean well serie 600.
The ventilation system of this power supply is permanently active to ensure proper cooling of its components.
Characteristics:
  • Adjustable output voltage: from 43 to 56V
  • Output voltage adjustment +/- 10%
  • Rated current: 20.8A
  • Power: 1000W
  • Yield: 88%.
  • Protections: Short-circuits / overloads / overvoltages
  • Input voltage: 180 to 264V AC
  • Operating temperature: -20 to 60 °C
  • Ripple: 200mV p-p
  • Control accuracy 0.5%.
  • Weight: 2.1 kg
  • Dimensions: 278x127x63.5mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)45.0
Output voltage (V)50.0
Output voltage (V)43.0
Output voltage (V)55.0
Output voltage (V)56.0
Output current (A)20.8
Input voltage (V)230.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)260.0
Input voltage (V)190.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)180.0
Power SupplySMPS
