MEAN WELL RS-15-5 SMPS 15W 5V Switching Power Supply Module
Reference : 8302
9,50 €tax incl.
7,92 € tax excl.
Meanwell RS-15-5 SMPS Power Supply Module 15W 5V 3A
Features:
  • Power: 15 W
  • Power Rating: 5
  • Current Rating: 3A
  • Input voltage: 88 to 264 VAC
  • Input Voltage: 248 to 373 VDC
  • Efficiency: 77%
  • Tension adj. Beach: 4.75 ... 5.5
  • Efficiency: 77%
  • Ripple and Noise: 80 mV
  • AC Input Range 115V / 230V Selectable by Switch
  • Protections: Short circuit / over load / overvoltage
  • Input voltage: 88 ... 132/176 ... 264 V AC (47 ... 63 Hz), 248 ... 373 V DC
  • Input Current Max: 65 A
  • Max Leakage Current: 2 mA
  • Output voltage setting: +10 / -5%
  • Operating Temperature Range: -25 ... +70 ° C
  • Short Circuit Protected: Yes
  • Overload protection: Yes
  • Weight: 130 g
  • Dimensions: 62.5 mm x 51 mm x 28 mm
Download Datasheet RS-15 as PDF
https://www.audiophonics.fr/images/8300_alimentations_RS-15-12_thumbs.png
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output current (A)3.0
Input voltage (V)110.0
Input voltage (V)230.0
Input voltage (V)240.0
Input voltage (V)130.0
Input voltage (V)120.0
Input voltage (V)220.0
Power SupplySMPS
Minuscule et efficace.
Utilisée pour alimenter des DACs à base de ES9023, cette alimentation est simplement parfaite. Minuscule, protégée, sans le moindre bruit ou rayonnement et pas chère, je la recommande chaleureusement.
 (3)
This review has been posted for MEAN WELL RS-15-5 SMPS 15W 5V Switching Power Supply Module
