This is a 600W 48VDC 12.5A power supply. MEANWELL's LRS-600 series is a single-output, enclosed 600W power supply with a low 41mm profile. Adopting a 115VAC or 230VAC input (switch selectable), the entire series provides an output voltage line of 5V, 12V, 15V, 24V, 27, 36V and 48V.
In addition to high efficiency up to 92%, with the integrated long-life fan, the LRS-600 can operate under -25~ +70℃ at full load. With extremely low no-load power consumption (less than 0.75 W), it enables the final system to easily meet global energy requirements.
The LRS-600 features comprehensive protection functions and 5G anti-vibration capability, and complies with international safety regulations such as IEC / UL 62368-1. The LRS-600 series is a cost-effective power supply solution for a wide range of industrial applications.
| Specifications | |
| Product type | SMPS power supply |
| output | 48V DC 12.5A |
| Input range | 90 - 132VAC / 180 - 264VAC via switch 255 - 370VDC (swith on 230VAC) |
| Input frequency | 47-63Hz |
| Nominal power | 600W |
| Efficiency | 92% |
| Ripple and noise | 200mV |
| Protection | Short circuits / overloads / overvoltages |
| Max. leakage current | 2mA |
| Operating temperature | -20 à +65°C |
| General | |
| Weight | 1kg |
| Dimensions | 225x124x41mm |
| Package | 1x MEAN WELL LRS-600-48 SMPS power supply |
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 43.0 |
| Output voltage (V) | 55.0 |
| Output voltage (V) | 56.0 |
| Output voltage (V) | 48.0 |
| Output voltage (V) | 45.0 |
| Output voltage (V) | 50.0 |
| Output current (A) | NC |
| Input voltage (V) | 210.0 |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 110.0 |
| Input voltage (V) | 120.0 |
| Input voltage (V) | 90.0 |
| Input voltage (V) | 200.0 |
| Input voltage (V) | 220.0 |
| Input voltage (V) | 100.0 |
| Input voltage (V) | 130.0 |
| Input voltage (V) | 230.0 |
| Power Supply | SMPS |
