FOSI AUDIO LC30 Audio Selector Switch Black Vu-Meter
15%
With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of passive speakers. This device is ideal if you want to take advantage of two Hi-Fi systems, or if you want to carry out comparative tests.
Reduced price!
Reference : 19046
Limited time offer:
165,00 €tax incl.
-15%
140,25 €tax incl.
116,88 € tax excl.
Shipping date: 18-07-2025.
FOSI AUDIO LC30 Audio Selector Switch for Amplifiers / Speakers Black Vu-meter
Fosi Audio LC30 picture
With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of passive speakers. This device is ideal if you want to take advantage of two Hi-Fi systems, or if you want to carry out comparative tests. Fosi Audio has chosen to integrate two relatively impressing VU meters on the front of its LC30 to give it a vintage look. The LC30 also features a remote control for added convenience and a comfortable user experience.
In terms of technical specifications, the LC30 supports up to 2x 250W under 4ohm power and is compatible with most power amplifiers on the market: class A amplifiers, class A/B amplifiers, class B amplifiers, class D amplifiers, mono amplifiers (BTL) and tube amplifiers. A large potentiometer adjusts the intensity of the VU meters according to the input signal power, and a 4-level light intensity setting (100%, 75%, 50%, Off) is also available. All LC30 components are housed in a durable aluminum case.
Rear view of the Fosi Audio LC30
Product typeAudio selector for amplifiers / speakers
Inputs2x Amplifier input on speaker terminals
Outputs2x Speaker output on speaker terminals
Maximum supported power2x 250W @ 4 ohms
Vumeters brightness adjustment4 levels : 100%, 75%, 50%, Off
Anti-pop protectionLoad protection up to 390Ω
Power supply5V DC via USB-C
Dimensions236.6 x 143.5 x 77.4mm
Weight1560g
ColorBlack / Black vu-meter
Package1x Fosi Audio LC30
1x USB-C/A to USB-C cable
1x Remote control
InputSpeaker terminals
OutputSpeaker terminal
Remote ControlYes
With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power...
