Source selector XLR 3 poles 2 to 1 PTFE Wiring
This device allows you to connect several analogue sources to your preamplifier, integrated amplifier or passive speakers.
4.9 / 5
Reference : 13230
85,00 €tax incl.
70,83 € tax excl.
Balanced XLR Source Selector
XLR AB Box HIFI
This device can connect multiple analog sources to your preamplifier, your integrated amplifier or your passive speakers.
Its function is to allow a permanent connection between multiple sources (up to 2) to a single amplifying device.
Once the source selector integrated in a complex audio system, just use the dial to select the active source.
In addition to the comfort of being able to change source without affecting connections, this type of device is particularly useful for increasing the life of the mechanical parts of the installation (connectors, plugs, cables), since these will be less prone to frequent handling.
Connections balanced XLR
XLR source selector
The source selector is designed to operate with balanced XLR sources harbor. It may well agree with advanced DACs and fit in very demanding audio systems.
The commes inputs the outputs of the source selector is done on the port XLR (male and female respectively). A connector is dedicated to each channel to form a balanced structure.
Source selector audiophile aluminum housing
Housing 100% aluminum
In order to ensure good mechanical strength and to isolate the cables, connectors and welds any electromagnetic emission capable of Engendering interference and interfering with the signal, the apparatus is protected by a housing 100% aluminum.
Pleasant and precise rotary knob
The selection of the active source is done simply by turning the knob until the postiion desirée.
Each position is recognizable by marking "A" and "B" readable. This marking is also transposed to the case back to indentiffier easily which port corresponds to which position on the selector button.
This is a three position button. The center position is not intended to select a particular source but serves as office mute. What adds another handy feature on the same device.
XLR with source selector knob 3 positions
XLR source selector Teflon cables
Wiring with PTFE sheath
Each wire has a PTFE sheath, providing excellent chemical inertness and resistance against all the usual factors of audio degradation: corrosion, heat, moisture.
Thanks to this protection, the device will last longer without altering the sound quality.
TypeSource Selector
XLR type3 poles
SignalAnalog
InputsXLR Stereo balanced female x 2
OutputsXLR Stereo balancedl male x 1
Mode selectionRotative Knob
Dimensions214 x 194 x 51mm
Weight1070g
InputXLR
ColorSilver
7 reviews
Très satisfait
Produits bien fabriqué simple et efficace
This review has been posted for Source selector XLR 3 poles 2 to 1 PTFE Wiring
Très satisfait
Je cherchais depuis un moment un sélecteur de source XLR de qualité pour ma configuration studio.
En effet, je possède une paire d’enceintes de monitoring actives et deux sources audio : un système DJ (Pioneer XDJ-RX3) et un synthétiseur. Je voulais que mes deux sources audio soient branchées en permanence vers ma paire d’enceintes de monitoring.
En bien c’est chose faite maintenant, j’ai mes deux branches et je n’ai plus qu’a sélectionner l’une ou l’autre : si je veux faire le DJ je sélectionne la source A (XDJ-RX3), et si je veux faire de la production avec mon synthétiseur, je commute sur source B.
Ce qui me plait aussi avec ce boitier, c’est le design épuré et la qualité de construction. Quant à la qualité du son, il n’y a aucune degradation.
Je recommande donc sans hésitation !
Appareil simple et qualitatif
J'utilise cet appareil en amont de mes enceintes actives pour switcher entre mon ensemble Home-cinéma et mon ensemble Hi-Fi : rien à redire, le bouton de sélection des sources est très agréable à manipuler et je n'ai pas noté de dégradation sur le son.
Solide & performant !
Un beau boitier tout métal, une sélection de source souple et totalement silencieuse, pour l'instant tout est parfait !
Il ne faut pas se tromper à la commande sur les entrées/sorties, le boitier étant stable et relativement lourd, il ne bouge pas même avec 6 câbles XLR connectés.
Super produit
Je voulais un selecteur pour mes pré-ampli HC et stéréo vers mon ampli Mc Intosh, je craignais des pertes, mais non. AU TOP ce produit. Meme pour les installations haut de gamme je recommande vivement.
