MULLARD GZ34 Rectifier Tube
The Mullard GZ34 tube is a high-end direct-heated rectifier diode. It is the re-edition of Mullard's most popular rectifier tube ever. Its purpose is to extend the life of other amplifier tubes by allowing them to heat up before voltage is applied.
Reference : 18932
39,90 €tax incl.
33,25 € tax excl.
3 >Month warranty
MULLARD GZ34 Rectifier Tube : Tube and box
MULLARD GZ34 Rectifier Tube : Dimensions
Product typeTube
Tube typeRectifier
Number of pins5
Dimensions87mm x Ø29.6 mm
ELECTRICAL CHARACTERISTICS
Heater current2.1A
Diode anod current180mA - 280mA @ filament voltage 5,0 V, plate voltage 17 V
Rectified current180mA @ filament voltage 5,0 V, plate voltage 17 V
First and second diodes plate current difference± 30 % @ filament voltage 5,0 V, plate voltage 17 V
MAX VALUES
Filament voltage5.5V
Rectified current250mA
Anode current amplitude825mA
Current surge at the turn -on moment3.7A
Anod reverse voltage amplitude1500V
Temperature at the most heated part of the envelope200°C
Contacts number5
Tube typeRectifier
2 reviews
Audiphonics réagit de façon professionnelle en cas de problème
J'ai eu un problème avec une défaillance sur l'un des tubes.
Le SAV m'a proposé plusieurs solutions au choix.
Il y a un grand respect des clients
This review has been posted for MULLARD GZ34 Rectifier Tube (Unit)
One of the very best rectifiers
This the second time I order MULLARD GZ34, it gives me what I want - wide soundstage, good separation, clean sound, exactly my cup of tea. One of two best rectifiers for HiFi along with GL in my opinion.
 (3)
The Mullard GZ34 tube is a high-end direct-heated rectifier diode. It is the re-edition of Mullard's most popular rectifier tube ever. Its...
