Female USB-C to Male Coaxial Adapter OCC Copper 75 Ohm 24bit 192kHz 65cm
The DD TCA100-COA is a high quality USB-C to coaxial adapter that provides USB connectivity to older DACs and amplifiers that have a digital coaxial input. It is then possible to connect to your devices more recent peripherals via a USB connection. Ideal for using a current smartphone as a source. The cable also supports PCM audio streams up to 24bit 192kHz.
To ensure the best transmission quality, the TC100-COA's coaxial cable center conductor adopts a design using 99.9999% pure OCC copper. The thickness of its conductor provides a constant impedance of 75Ω, crucial for coaxial transmission.
The TCA100-COA is also equipped with a Murata DA101C digital audio transformer. This one ensures a balance between the USB input circuit and the coaxial output circuit for an optimal transmission.
Product type | Coaxial / USB adapter |
Connectors | 1x Male coaxial 1x Female USB-C |
Length | 65cm |
Supported sampling rates | PCM up to 24bit 192kHz |
Cable conductor material | OCC copper |
Cable impedance | 75Ω |
Weight | 65g |
Color | Gris |
Connectic | Male & Female |
Connector | Coaxial |
Connector | USB-C |
Contacts Material (Connector) | N/A |
Contacts Plating (Connector) | Gold |
