Male USB-C 3.1 to Male USB-C 3.1 Super Speed 3A 5Gbps 2m
This USB cable has a USB-C 3.1 connector on both sides and allows you to connect two devices with this connection, such as a smartphone and a recent laptop or tablet. The cable delivers 3A load and transfer rates up to 5 Gbps.
Fast Charge
The cable can deliver up to 3A, allowing you to quickly charge devices like your smartphone, tablet or any other battery-powered device with a USB-C charging port.
USB 3.1 Gen 2
With this new USB 3.1 standard, this cable offers file transfer speeds up to 5 Gbps.
Reversible Design
Type C connectors are reversible and therefore cannot be inserted in the wrong direction, greatly facilitating connection.
Cable type | Male USB-C 3.1 to Male USB-C 3.1 |
Max transfer bandwidth | 5 Gbps |
Max current | 3A |
Length | 2m |
USB-IF Certification | Yes |
Cable section | 30AWG (0.0509mm²) |
Cable diameter | 5.2mm |
Color | Black |
Length (m) | 2.0 |
Shielding | NC |
Section (mm²) | 0.0509 |
Connector | USB-C |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
