With LD LT1, FiiO presents a Lightning to USB-B cable using high-purity copper conductors for pure, stable signal transmission. Gold-plated connector contacts resist corrosion and oxidation. This cable ensures interference-free data transmission and limits jitter. Multiple insulations cover the conductors to guarantee a high level of shielding. The cable is then covered with a PVC sheath and a second, braided, high-quality nylon sheath. The body of the connectors is made of an aluminum alloy for robustness and durability. The LD LT1 is perfect for connecting a smartphone, tablet or computer with lightning port to a DAC equipped with USB-B connectivity, such as the FiiO K5 Pro or FiiO K9 Pro, for example.
The cable does not support devices requiring more than 200mA current and is not suitable for recharging the battery of connected devices.
FiiO's LD LT1 Lightning/USB cable has a structure worthy of much more expensive cables, with copper conductors, reinforcing wires and double shielding with aluminium foil and tinned copper braid.
Product type | Lightning / USB cable |
Connectors | 1* Male Lightning 1* Male USB-B |
Length | 0.5m |
Cable conductors material | High-purity copper Tinned copper |
Shielding | Aluminum foil Tinned copper braid |
Cable diameter | Ø5mm |
Sheath | PVC Braided nylon |
Connectors shell material | Aluminum alloy |
Connectors contacts material | Copper alloy |
Connectors contacts plating | Gold |
Max. current | 200mA |
Color | Cable: Black Connectors: Gray and black |
Length (m) | 0.5 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | Lightning |
Connector | USB-B |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
