ATOHM DIY KIT RAFALE VR3-X Subwoofer (Unit)
-26%
Refurbished product - Grade S
The Rafale VR3-X kit from Atohm is an active subwoofer designed for large systems and the most extreme use cases. Its bass-reflex load carries a 500Weff generative amplification coupled to three exceptional speakers with a diameter of 23cm.
Reduced price!
Reference : 20822
Refurbished
1 490,00 €tax incl.
-26%
1 099,00 €tax incl.
915,84 € tax excl.
Shipping date: 10-11-2026.
Brand new product. Old version: LD230CRA08 speakers
Atohm Kit Rafale VR3-X
Subwoofer 500W (Unit)
Atohm Kit DIY Rafale VR3-X Subwoofer 500W (Unité)
The Rafale VR3-X kit from Atohm is an active subwoofer designed for large systems and the most extreme use cases. Its bass-reflex load carries a 500Weff generative amplification coupled to three exceptional speakers with a diameter of 23cm. This exceptional trio has an equivalent emissive surface area to that of a 38cm and when necessary, the associated electronics allows a membrane excursion of +/-18mm ! With its many connection options, this box can be integrated without limitation into all major HiFi and Home Cinema installations. Capable of reaching absolutely amazing sound levels, even at the lowest notes, the VR3-X is the essential ally to make you experience the most beautiful and intense sensations!
Product typeSpeaker kit
Speaker typeActive subwoofer
LoadBass Reflex 90L
Frequency response27Hz - 150Hz
Power (RMS)500W
Low level input2x RCA
High level input2x Banana plugs 4mm / Direct tightening
Cut out frequencyAdjustable from 38Hz to 150Hz
Phase control0-180°
Filtering slopeAdjustable 12dB-24dB-LFE
Bass/Medium SpeakerLD230CRA08 (x3)
Supply voltage115V / 230V
Consumption700Wmax
Dimensions320*830*530mm (W*H*D)
Weight47kg
Refurbished GradeGrade S
Refurbished product - Grade S The Rafale VR3-X kit from Atohm is an active subwoofer designed for large systems and the most extreme use cases....
