Separator Cable Female Jack DC 5.5 / 2.1mm to Male / Female USB-C for Power Supply and Data 20cm
This 5.5/2.1mm DC jack to USB-C cable provides a clean power supply for a device or module that is powered via a USB-C connector. The cable has the particularity of offering both a USB-C male connector for power supply and a USB-C female connector for data.
Reference : 14052
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 07-04-2026.
USB-C / Jack DC Adapter cable
Adapter Cable Female Jack DC 5.5/2.1mm to Male / Female USB-C for Power Supply and Data 20cm
Câble Adaptateur Jack DC 5.5/2.1mm Femelle vers USB-C Mâle / Femelle pour Alimentation et Données 20cm
This 5.5/2.1mm DC jack to USB-C cable provides a clean power supply for a device or module that is powered via a USB-C connector. The cable has the particularity of offering both a USB-C male connector for power supply and a USB-C female connector for data. It is therefore possible, with a single cable, to separate the power signal from the data signal, in order to limit interference and therefore the noise generated.
Product typeUSB-C Power Cable
Input1x Female Jack DC 5.5/2.1mm
1x Female USB-C
Output1x Male USB-C
Length20cm
Cheath colorBlack and red
Cable diameter5mm
Length (m)0.2
ShieldingNC
Section (mm²)N/A
ConnectorUSB-C
ConnectorJack DC
This 5.5/2.1mm DC jack to USB-C cable provides a clean power supply for a device or module that is powered via a USB-C connector. The cable has the...
